Hobie tramp on Freestyle 474? #247460
04/25/12 05:53 PM
04/25/12 05:53 PM
Freestyle Offline OP
what are the dimensions of the hobie 16 or 18 trampoline? I just bought a Freestyle 474 in Big Bear City CA and am trying to get it ready for the water on the cheap...
Re: Hobie tramp on Freestyle 474? [Re: Freestyle] #247466
04/25/12 09:15 PM
04/25/12 09:15 PM
I'm just going to come out and say it, NO. It'll more than likely a jury rigged mess and not work. Have someone make you a tramp using the old one as a pattern.
Do the Glaser's make tramps?
Re: Hobie tramp on Freestyle 474? [Re: Freestyle] #247467
04/25/12 09:37 PM
04/25/12 09:37 PM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
Unless Rick has some kicking around, try here.
Re: Hobie tramp on Freestyle 474? [Re: Freestyle] #247504
04/26/12 10:04 PM
04/26/12 10:04 PM
Well I really wasn't talking about trying to use the hobie piece directly but more like just trying to find out the dimensions of a hobie tramp. The idea was to buy a cheap hobie tramp on ebay for like $50 and have it cut and sewn to fit on the 474. How much does tramp fabric cost new? I would go with the ones linked, but I've been told that having only lacing on one side that it will stretch and sag. Appparently the 474 originally had a tramp with bolt rope on two sides adjacent to each other and lacing on the other two sides....so it could be kept tight in both directions.
Re: Hobie tramp on Freestyle 474? [Re: Freestyle] #247515
04/27/12 08:43 AM
04/27/12 08:43 AM
Houston
carlbohannon Offline
Houston
Tramp material is cheap.
http://www.sailrite.com/Trampoline-Mesh-Black-74
If you cut out the tramp, lay it out and then pin or tape everything together so that the sailmaker only has to sew it together, they will only charge you a couple of hours labor. I use thin beads of hot glue or heat applied tape to hold everything together.
You can sew it yourself. A home machine will sew it easily. The learning curve is steep. I think my first one took 10 hrs and my second one about 2 hours to sew and for my third one $100 in labor at the sailmaker seemed cheap.
Re: Hobie tramp on Freestyle 474? [Re: carlbohannon] #247567
04/30/12 12:36 PM
04/30/12 12:36 PM
Took a closer look at the SLO sail website. I was short sighted at first, but they do have non-bias cut tramps with lacing on two sides for a Freestyle 474....my bad. After thinking it over, time is money and $300 isn't bad for one. Although Im going to have them make me one without grommets, with a tubes for lacing.
0 registered members (), 326 guests, and 14 spiders.
