| Re: Carnac 2012 - results
[Re: Gilo]
#247855 05/06/12 09:47 AM 05/06/12 09:47 AM |
Posts: 1,021 Australia | If the boat is balanced and fast upwind but has lee helm downhill then it's not so good to mess with mast rake or rudder rake, it is much better to move the board position forward. It will have none or super small effect upwind (In a reasonable range) but will fix the lee helm. The slot effect is minimal compared to the increase in air to the front of the kite. There are two things that make you faster downwind:- 1. Longer luff length 2. Longer pole If I could have a 4.5m long pole on the F18 I would. But right now I will be happy that I can paint my boats | | | Re: Carnac 2012 - results
[Re: macca]
#247863 05/06/12 11:50 AM 05/06/12 11:50 AM |
Posts: 893 | If the boat is balanced and fast upwind but has lee helm downhill then it's not so good to mess with mast rake or rudder rake, it is much better to move the board position forward. It will have none or super small effect upwind (In a reasonable range) but will fix the lee helm. The slot effect is minimal compared to the increase in air to the front of the kite. There are two things that make you faster downwind:- 1. Longer luff length 2. Longer pole If I could have a 4.5m long pole on the F18 I would. But right now I will be happy that I can paint my boats Moving the board forward will I guess move more effort onto the board and away from the rudder, the A's seem to have such small boards that the A has to take some of the loadings onto the rudders to compensate and the rigs position becomes far more critical to balance things up a bit. The F18's seem to be going the other way with almost all of the lateral effort placed on huuuuuuge loooooooong high aspect boards with diddy small rudders just touching the water at the back. I guess thats all to do with the change of balance of the boat when that big spinnaker goes up. Still not convinced about the spinnaker not forming some form of slot, the Shadow used to have a mere hankerchief as Spinny run straight from the bow, it was a very fast boat considering how little sail area it had. The new X version seems to be more normal in its spinny arrangement and seems to go just as well with a larger area. I guess one will have to give it a try some time, I guess just like being able to paint your boats ( thought that had been resolved in your favour ) | | | Re: Carnac 2012 - results
[Re: waynemarlow]
#247864 05/06/12 01:14 PM 05/06/12 01:14 PM |
Posts: 571 Hamburg | Still not convinced about the spinnaker not forming some form of slot Make you free of thinking of "slot effect". The first sail is always in the upwash of the second one, which is always in the downwash of the first one. The more seperated the sails are the lower the drag by the way. But aerodynamic drag is not very important on downwind legs. To increase lift the slot must be very narrow (about 40 mm to give you a number), stable and form a convergent nozzle with the mast. All of this is not present on todays soft sail designs, hence no slot effect. Hence, as macca said, a longer pole is better (for exact the reasons he mentioned above) as long as you can steer the boat. Another question is, is leehelm a bad thing (a bit of lee-helm, not massive)? I have the feeling that with leehelm the rudder pushes the stern down and bows up. Hence you can have abit more power in the rig before you start to submerge. Cheers, Klaus | | | Re: Carnac 2012 - results
[Re: waynemarlow]
#247872 05/06/12 06:32 PM 05/06/12 06:32 PM |
Posts: 9,582 North-West Europe | boards on the Taipan arre far back as the V-ed bows runs deep and narrow like a plate, but the aft sections have rounded keel. There is always a play between boards, rudders AND the hull. Rounded keel line on the bow required different board placements. Can 't easily compare board positions on boats with significantly different keel lines.
I shied aways from making complete new daggerboard wells over gaining 0.25 mtr pole length. Sue me !
BTW lots of leehelm is bad under spinnaker as rudders act like a brake then. I know because I tried. My current setup is the fastest without completely rebuilding the hulls or the daggerboard wells.
568
guests, and 127
