L Boards? #247964
05/08/12 04:10 PM
05/08/12 04:10 PM
Karl_Brogger Offline OP
Are the not legal because they don't come out the top?
Re: L Boards? [Re: Karl_Brogger] #247966
05/08/12 04:50 PM
05/08/12 04:50 PM
M
MarkMT
MarkMT
M
http://www.formula16.net/content/view/13/36/lang,en/
1.6.4 (Added by vote, August 2007) For the avoidance of doubt, daggerboards/centerboards will conform to the following :
a) Curved/’Banana’ boards will not be allowed.
b) Assymetrical cross-section profile boards will be allowed.
c) Fore/aft movement of the boards when in the down position will not be allowed.
d) End fences/horizontal appendages below the waterline will not be allowed. The board shall be capable of removal, without tools, via the upper opening of the case.
e) There will be no limitation on the daggerboard/centerboard length
Re: L Boards? [Re: Karl_Brogger] #247971
05/08/12 05:33 PM
05/08/12 05:33 PM
Part D is what I'm curious about. There's two statements there.
Re: L Boards? [Re: Karl_Brogger] #247984
05/08/12 10:47 PM
05/08/12 10:47 PM
M
MarkMT
MarkMT
M
The first rules them out explicitly, the second implicitly.
Re: L Boards? [Re: ] #247985
05/09/12 12:59 AM
05/09/12 12:59 AM
FL
sail7seas Offline
sail7seas  Offline
FL
If one had a straight board that bent enough without breaking you would have a curved board?
Re: L Boards? [Re: sail7seas] #247987
05/09/12 02:09 AM
05/09/12 02:09 AM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
If it has a "bend" is it then not "straight"?
BEND [bend]
verb (used with object)
1. to force (an object, especially a long or thin one) from a straight form into a curved or angular one, or from a curved or angular form into some different form: to bend an iron rod into a hoop.
STRAIGHT [streyt]
1. without a bend, angle, or curve; not curved; direct: a straight path.
USA 777
Re: L Boards? [Re: ] #247988
05/09/12 05:51 AM
05/09/12 05:51 AM
waynemarlow Offline
waynemarlow  Offline
Something that can be done is getting a straight board with a smaller 45 degree tip down a cassette box if the cassette box is setup like the modern adjustible A Class style, with the addition of a small flap on the inside of the hull. A 12 degree incline + say 45 degrees gives very nearly the optimal board shape. Is the additional small end piece ( the bit that gives the vertical lift ) an end fence, not in my book.
I hope they leave this get out clause in there for future experiment with what is effectively L boards.
Re: L Boards? [Re: tback] #248037
05/09/12 09:47 PM
05/09/12 09:47 PM
FL
sail7seas Offline
sail7seas  Offline
FL
To rephrase, use a low mudulus material than that bends easily, and stays in the elastic zone to preclude a permanent curve/bend.
0 registered members (), 20,217 guests, and 543 spiders.
Most Online22,490
Yesterday at 08:14 AM
