Inter Rudders #248105
05/10/12 02:39 PM
05/10/12 02:39 PM
Y
yurdle Offline OP
yurdle  Offline OP
Y
Hi, I've got an Inter17 with the original rudders -- I've got two questions about them.
1. Has anyone found it necessary to drop a rivet through the top of the rudder head casting to tighten up the little bit of slop in the tiller arm/casting connection?
2. Are the original rudders the same as the originals on the I18/20? Are the 2nd gen the same as the 2nd gen for the I18/20? Murray's shows the I17s as the same as the 570/580, but the nacra parts manual shows the I17s as the same as the 18/20.
Thanks!
Re: Inter Rudders [Re: yurdle] #248127
05/10/12 09:35 PM
05/10/12 09:35 PM
BadLatitude1337 Offline
yes the n17 18 and 20 all same rudders.
Open20NA 1337 FOR THE WIN!!!
Re: Inter Rudders [Re: yurdle] #248142
05/11/12 08:03 AM
05/11/12 08:03 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Before you re-rivet the tiller arms, put some epoxy in the socket to stop it coming loose again
Re: Inter Rudders [Re: yurdle] #248147
05/11/12 10:01 AM
05/11/12 10:01 AM
Y
yurdle Offline OP
yurdle  Offline OP
Y
I PVA'ed one of the arms before putting it back in, just in case I'd need to inject some epoxy, but figured I'd try the rivets alone first.
I didn't do the other, and the holes in that one are a little corroded and oversized, leading to that connection being a little sloppy...figures.
Re: Inter Rudders [Re: TEAMVMG] #248153
05/11/12 10:15 AM
05/11/12 10:15 AM
What he said ^^^
I've had them riveted on top and bottom, side and top, bottom and side, wrapped it in plastic, made spacers, wedged crap in it...they all eventually came loose but thickened epoxy and two bottom rivets served me well for multiple years with no problem.
The epoxy solution would make repair a little more difficult - but epoxy eases with heat and all you would need to do would be to cook it for a little while to get the epoxy to let go of the aluminum arm.
0 registered members (), 3,220 guests, and 102 spiders.
