Rear foot strap mounting recommendations #248361
05/14/12 04:45 PM
05/14/12 04:45 PM
sailqs Offline OP
sailqs  Offline OP
Just wondering what the consensus was for attaching rear foot-straps? Is drilling a hole and using a washer sufficient? Any concern with glass fatigue or exposure because of the holes? Someone suggested glassing in a wooden block on the inside of the hull but it seemed overboard. Would appreciate any suggestions and if anyone had any downsides to drilling through the hull long term? Using the Dakine rears.
Thanks,
Dave
Re: Rear foot strap mounting recommendations [Re: sailqs] #248366
05/14/12 09:50 PM
05/14/12 09:50 PM
Drill hole. Silicone hole. Silicone washer. Insert bolt/footstrap/washer/nut. Tighten. Break foot off.
Re: Rear foot strap mounting recommendations [Re: Karl_Brogger] #248368
05/15/12 01:28 AM
05/15/12 01:28 AM
sailqs Offline OP
sailqs  Offline OP
I think I will try and avoid the last step ;-)
Re: Rear foot strap mounting recommendations [Re: sailqs] #248372
05/15/12 05:22 AM
05/15/12 05:22 AM
It helps to put them under a small outward angle.
Makes it easier to get into and your crew's feet wont inderfere with the rudders smile
Karl: Didnt you already lose two feet when you went from the C2 to the Viper? wink
Re: Rear foot strap mounting recommendations [Re: Tony_F18] #248382
05/15/12 11:20 AM
05/15/12 11:20 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Karl never had a C2, but he does have stick envy.
F18 USA 242
http://www.solarwind.solar
Re: Rear foot strap mounting recommendations [Re: sailqs] #248418
05/15/12 07:27 PM
05/15/12 07:27 PM
I've always been a little envious of Ding's stick. What can I say....
I'd mount them so they're as loose as possible also. They never seem to open enough if you've got clown feet.
Re: Rear foot strap mounting recommendations [Re: sailqs] #248549
05/17/12 10:58 PM
05/17/12 10:58 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
I attach the fwd side of the strap to the rear beam, to minimize the number of holes drilled in the deck. Make the opening wide enough so that there's still some slop with booties on. I twist my foot in the strap to secure it, untwisting in an emergency makes exiting easy and somewhat safer.
Dave
Re: Rear foot strap mounting recommendations [Re: sailqs] #248635
05/19/12 10:23 PM
05/19/12 10:23 PM
forgive me for contributing in the land of the F18s... but here is my suggestion. my boat has HMWPE squares as backing plates for hardware using large sheet metal SS screws. Works well.
The Dakine footstraps are nice but don't last in the sun at all. Sew up some nice ones yourself using polyester webbing. burn a hole in either end and put the screws through the holes using a washer. Costs about 2 dollars in materials. might create a cleaner break too when you break your foot off.
Re: Rear foot strap mounting recommendations [Re: sailqs] #248646
05/21/12 06:26 AM
05/21/12 06:26 AM
Most F18s use this Magic Marine footstrap, its simple, light, and very strong:
http://www.magicmarine.com/products/Accessories/General/FOOTSTRAP_LIGHT
IMHO best way to mount it is to fix one end on the transom and the other on the hull.
Re: Rear foot strap mounting recommendations [Re: Tony_F18] #248702
05/22/12 08:02 AM
05/22/12 08:02 AM
dr5e14w Offline
dr5e14w  Offline
if using the magic marine footstraps make sure that the velcro does not open from the front of the boat otherwise all the water running down the side of the boat has a tendency to open them (or at least the top layer of velcro)
Re: Rear foot strap mounting recommendations [Re: sailqs] #248725
05/22/12 11:47 AM
05/22/12 11:47 AM
Newport, RI
wildtsail Offline
wildtsail  Offline
Newport, RI
+1 for the magic marine footstraps... best footstrap out tehre. they are hard to locate in the U.S. I have a few sets coming in soon if you want to drop me a note.
No need for backing plates and mount the footstrap as far back as you can, there is no where else to put it. You need your crew as far back as they can go. Some of the newer boats are designed with a chine on the back corner which works perfect for mounting the footstrap.
Re: Rear foot strap mounting recommendations [Re: sailqs] #248761
05/22/12 09:08 PM
05/22/12 09:08 PM
Boston, Ma
Jeff.Dusek Offline
Jeff.Dusek  Offline
Boston, Ma
Todd, I could use a set.
USF18 Eastern Area Rep
Nacra Infusion USA 753
Re: Rear foot strap mounting recommendations [Re: PTP] #249134
06/04/12 11:14 AM
06/04/12 11:14 AM
Is there any provision in this system for adjustibility? I boat-ho on several beachcats, and sometimes have to adjust the footstrap size because I wear shoes
Re: Rear foot strap mounting recommendations [Re: sailqs] #249343
06/07/12 03:57 PM
06/07/12 03:57 PM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Whats the price on those MM straps? My boat has 3 pairs of dakines straps on it that all need replacing from the sun eating them up.
Re: Rear foot strap mounting recommendations [Re: sailqs] #249355
06/07/12 07:18 PM
06/07/12 07:18 PM
Newport, RI
wildtsail Offline
wildtsail  Offline
Newport, RI
Bacho... You bought that worrell harness from me, shoot me an email Todd dot Riccardi at gmail dot com
Re: Rear foot strap mounting recommendations [Re: wildtsail] #249377
06/08/12 10:51 AM
06/08/12 10:51 AM
california
F-18 5150 Offline
F-18 5150  Offline
california
I bought a Worrell harness from you too and it split after 3 uses. Did you give him the good one?
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
R.Vilvens@yahoo.com
Fairfield, Ca
F-18 5150
Re: Rear foot strap mounting recommendations [Re: sailqs] #249380
06/08/12 11:49 AM
06/08/12 11:49 AM
Newport, RI
wildtsail Offline
wildtsail  Offline
Newport, RI
Did it really?!? I know they had that issue but they semed to have fixed it. I had one split the 2nd day I used it on the first leg of the Tybee... Randall from Aquata had a new one sitting outside his office for me to pick up that night... give them a call though it might be worth just getting it stiched by a loft... I'll buy you a drink or two in Long Beach.
0 registered members (), 657 guests, and 140 spiders.
Posts267,056
