| Re: Rear foot strap mounting recommendations
[Re: sailqs]
#248366 05/14/12 09:50 PM 05/14/12 09:50 PM |
Posts: 4,119 Northfield Mn | Drill hole. Silicone hole. Silicone washer. Insert bolt/footstrap/washer/nut. Tighten. Break foot off.
[Re: Tony_F18]
#248382 05/15/12 11:20 AM 05/15/12 11:20 AM |
Posts: 3,906 Clermont, FL, USA | It helps to put them under a small outward angle. Makes it easier to get into and your crew's feet wont inderfere with the rudders  Karl: Didnt you already lose two feet when you went from the C2 to the Viper? Karl never had a C2, but he does have stick envy.
[Re: sailqs]
#248418 05/15/12 07:27 PM 05/15/12 07:27 PM |
Posts: 4,119 Northfield Mn | I've always been a little envious of Ding's stick. What can I say....
I'd mount them so they're as loose as possible also. They never seem to open enough if you've got clown feet.
[Re: sailqs]
#248635 05/19/12 10:23 PM 05/19/12 10:23 PM |
Posts: 2,921 Michigan | forgive me for contributing in the land of the F18s... but here is my suggestion. my boat has HMWPE squares as backing plates for hardware using large sheet metal SS screws. Works well. The Dakine footstraps are nice but don't last in the sun at all. Sew up some nice ones yourself using polyester webbing. burn a hole in either end and put the screws through the holes using a washer. Costs about 2 dollars in materials. might create a cleaner break too when you break your foot off.
[Re: PTP]
#249134 06/04/12 11:14 AM 06/04/12 11:14 AM |
Posts: 5,590 Naples, FL | Sew up some nice ones yourself using polyester webbing. burn a hole in either end and put the screws through the holes using a washer. Is there any provision in this system for adjustibility? I boat-ho on several beachcats, and sometimes have to adjust the footstrap size because I wear shoes
[Re: wildtsail]
#249377 06/08/12 10:51 AM 06/08/12 10:51 AM |
Posts: 1,430 california | Bacho... You bought that worrell harness from me, shoot me an email Todd dot Riccardi at gmail dot com I bought a Worrell harness from you too and it split after 3 uses. Did you give him the good one? | | |
2,646
guests, and 612
