| vacuum bag #249128 06/04/12 09:16 AM 06/04/12 09:16 AM |
Posts: 5,525 | Can the weight of water be used to pull a vacuum?
If I place a small mold inside a vacuum bag at waist height and connect it to an elevated water reservoir which is in turn connected to a tube, will releasing water into the tube evacuate the bag? Any physics to support your answer(s)?
Pete Pollard Blade 702
| | | Re: vacuum bag
[Re: pgp]
#249129 06/04/12 09:26 AM 06/04/12 09:26 AM |
Posts: 51 Richmond, Va | Seems to me that this isn't going to work. In order to have a complete vacuum in the mold bag (top bag) with no air bubbles then you would have to have a completely closed system. By this I mean that there would have to be no air in the reservoir (bottom bag). If there is air in the bottom bag or if you were looking to do this over a bucket or something you would then have air moving up into the top bag to replace the void of the water. In a closed system I don't think you are going to find gravity, your only force, creating enough of a "vacuum" to do what you are looking for. Please someone correct me if I'm wrong, I have no experience in Vacuum Bagging, just throwing out what I think is possible.
Brian C. H14 H16
| | | Re: vacuum bag
[Re: Will_R]
#249140 06/04/12 12:46 PM 06/04/12 12:46 PM |
Posts: 141 | No reason that this wouldn't work except for practicality. You'll have to displace more water than you have air to remove for it to work. It's basic fluid dynamics.
The difficulty as I see it would be the volume of air to be removed relative to the amount of water you are able to "drop". i.e. once you've pulled all the vacuum that you can with the water, it may not be enough to remove the air from the carbon/resin and produce a vacuum of sufficient quantity if at all. In order to pull 1 atmosphere of vacuum with water you need 33 feet. Not very practical. Not sure I understand your description of the system, but as mentioned it must be closed. | | | Re: vacuum bag
[Re: mini]
#249143 06/04/12 12:54 PM 06/04/12 12:54 PM |
Posts: 5,525 | No reason that this wouldn't work except for practicality. You'll have to displace more water than you have air to remove for it to work. It's basic fluid dynamics.
The difficulty as I see it would be the volume of air to be removed relative to the amount of water you are able to "drop". i.e. once you've pulled all the vacuum that you can with the water, it may not be enough to remove the air from the carbon/resin and produce a vacuum of sufficient quantity if at all. In order to pull 1 atmosphere of vacuum with water you need 33 feet. Not very practical. Not sure I understand your description of the system, but as mentioned it must be closed. It isn't that I doubt you, but how do you know that? Would a 33' coil work? I'm considering a very small volume and considering using Luer lock, standard I.V. equipment. In fact, I was thinking of an i.v. bag on a pole.
| | | Re: vacuum bag
[Re: pgp]
#249149 06/04/12 01:10 PM 06/04/12 01:10 PM |
Posts: 5,525 | I'm not buying any more gadgets to get used once, then gather dust for decades.
Besides, I'm obsessed with the question...
| | | Re: vacuum bag
[Re: pgp]
#249155 06/04/12 01:33 PM 06/04/12 01:33 PM |
Posts: 12,310 South Carolina | I'm not buying any more gadgets to get used once, then gather dust for decades.
Besides, I'm obsessed with the question... Well, on the surface, absolute vacuum will only generate atmospheric pressure on the item in the bag...which equates to about 14.5 psi. You can try to pull "more" vacuum on it but once you have removed all of the air, there is nothing else to pull. So, the vacuum bag can only match the differential pressure between the outside and the inside of the bag...i.e. 14.5psi atmospheric and 0psi inside the bag = 14.5psi total...and you can't generate less than 0 inside the bag because there's nothing left to draw out. That said, you CAN increase the external pressure on the bag to increase the differential and the pressure on the item inside the bag. This is the principle of an autoclave. You first draw a vacuum on the bag, insert the bag into a pressure vessel, pump up the pressure inside the vessel and put a lot more pressure on the part. Hall Spars builds masts this way (and the Autoclaves normally employ heat as well). You ~could~ also take your vacuum bag and lower it into water to create more differential in the pressure in the same way the autoclave works.
Jake Kohl | | | Re: vacuum bag
[Re: pgp]
#249158 06/04/12 01:42 PM 06/04/12 01:42 PM |
Posts: 51 Richmond, Va | No reason that this wouldn't work except for practicality. You'll have to displace more water than you have air to remove for it to work. It's basic fluid dynamics.
The difficulty as I see it would be the volume of air to be removed relative to the amount of water you are able to "drop". i.e. once you've pulled all the vacuum that you can with the water, it may not be enough to remove the air from the carbon/resin and produce a vacuum of sufficient quantity if at all. In order to pull 1 atmosphere of vacuum with water you need 33 feet. Not very practical. Not sure I understand your description of the system, but as mentioned it must be closed. It isn't that I doubt you, but how do you know that? Would a 33' coil work? I'm considering a very small volume and considering using Luer lock, standard I.V. equipment. In fact, I was thinking of an i.v. bag on a pole. That is a basic SCUBA concept, every 33' you go down the pressure increases by 1atm, so no a coil will not work to create that additional atm you would need a column of water. To elaborate on Jake's idea, the idea of a one-way valve on the bag and attaching the bag to an anchor in 33' of water comes to mind (try this on something replaceable first) with the valve pointing up so you don't get an air bubble.
Brian C. H14 H16
| | | Re: vacuum bag
#249160 06/04/12 01:42 PM 06/04/12 01:42 PM |
Besides, I'm obsessed with the question... Well, on the surface, absolute vacuum will only generate atmospheric pressure on the item in the bag...which equates to about 14.5 psi. You can try to pull "more" vacuum on it but once you have removed all of the air, there is nothing else to pull. So, the vacuum bag can only match the differential pressure between the outside and the inside of the bag...i.e. 14.5psi atmospheric and 0psi inside the bag = 14.5psi total...and you can't generate less than 0 inside the bag because there's nothing left to draw out. That said, you CAN increase the external pressure on the bag to increase the differential and the pressure on the item inside the bag. This is the principle of an autoclave. You first draw a vacuum on the bag, insert the bag into a pressure vessel, pump up the pressure inside the vessel and put a lot more pressure on the part. Hall Spars builds masts this way (and the Autoclaves normally employ heat as well). You ~could~ also take your vacuum bag and lower it into water to create more differential in the pressure in the same way the autoclave works. Is there a standard? X amount of resin per square meter of cloth, for instance? IF .5 atmospheres is all that is required for most applications, I suspect vacuum bagging operations are designed to handle relatively large amounts of air in commercial operations.
| | | Re: vacuum bag
[Re: pgp]
#249161 06/04/12 01:46 PM 06/04/12 01:46 PM |
Posts: 12,310 South Carolina | Ahh, but now I see that you just want to generate the vacuum with a column of water.
The coil won't work - you need 33.5 vertical feet in a column of water to match 14.5 psi. It's the only way to get the gravity to add up.
[Re: pgp]
#249163 06/04/12 01:59 PM 06/04/12 01:59 PM |
Posts: 5,525 | Umm, I'm probably using the wrong approach. I need to know how much resin my piece needs for maximum strength, then I can just roll it out by hand.
| | | Re: vacuum bag
[Re: pgp]
#249165 06/04/12 02:07 PM 06/04/12 02:07 PM |
Posts: 5,525 | "Straight out of Felder and Rousseau, "Elementary Principle of Chemical Process"
thx
| | | Re: vacuum bag
[Re: Will_R]
#249170 06/04/12 03:05 PM 06/04/12 03:05 PM |
Posts: 12,310 South Carolina | Straight out of Felder and Rousseau, "Elementary Principle of Chemical Process"
1atm = 33.9 ft H20 at 4 deg C.
Jake, I disagree. If the pressure (vacuum) gauge reads lower (less) than 0 psia then you are exerting more than 1 atm of pressure on the item in the bag. The benefit of the autoclave is that you can reach the high activation temperatures required for prepeg AND put it under pressure. I think we're saying the same thing - you can't have a bag out in the open space (at atmospheric pressure), at full vacuum, and have more than one atmosphere on it. You can't achieve more vacuum than complete vacuum. You CAN increase the pressure outside the bag in order to increase the pressure inside the bag by using an autoclave to get better than atmospheric pressure.
#249178 06/04/12 04:21 PM 06/04/12 04:21 PM |
Joined: Jun 2001 Posts: 890 Dunedin Causeway, FL David Parker
Posts: 890 Dunedin Causeway, FL | Ahh, but now I see that you just want to generate the vacuum with a column of water.
The coil won't work - you need 33.5 vertical feet in a column of water to match 14.5 psi. It's the only way to get the gravity to add up. If you have a column of water descending 33 feet creating a vacuum space above it, then the water at the surface of that column will, in essence, boil. The vacuum space will have a considerable amount of water vapor in that volume. Will the presence of that "dampness" have an adverse effect on the curing process? | | | Re: vacuum bag
[Re: David Parker]
#249197 06/05/12 06:55 AM 06/05/12 06:55 AM |
The coil won't work - you need 33.5 vertical feet in a column of water to match 14.5 psi. It's the only way to get the gravity to add up. If you have a column of water descending 33 feet creating a vacuum space above it, then the water at the surface of that column will, in essence, boil. The vacuum space will have a considerable amount of water vapor in that volume. Will the presence of that "dampness" have an adverse effect on the curing process? Ahhhh...great point! Because the water will boil/evaporate, you will never achieve a consistent maximum vacuum that way - the water vapor will continue to fill the vacuum space and reduce it somewhat.
Jake Kohl | | |
1 registered members (FredL),
446
guests, and 68
