| Raid Ybel #249322 06/07/12 08:08 AM 06/07/12 08:08 AM |
Posts: 5,525 | http://connect.garmin.com/player/91690890Time to do Raid Ybel again and see if we can take some time off last years run. Jay? Anyone?
Pete Pollard Blade 702
| | | Re: Raid Ybel
[Re: pgp]
#249863 06/20/12 01:15 PM 06/20/12 01:15 PM |
Posts: 5,590 Naples, FL | I'm good. what's your schedule like?
| | | Re: Raid Ybel
[Re: pgp]
#249867 06/20/12 01:38 PM 06/20/12 01:38 PM |
Posts: 5,525 | Open, except for this weekend. Be sure to check your make up, I just bought a Go Pro.
| | | Re: Raid Ybel
[Re: pgp]
#249881 06/21/12 09:08 AM 06/21/12 09:08 AM |
Posts: 4,119 Northfield Mn | I keep wanting to mount a GoPro to the underside of a hull behind the daggerboard. It'd be a cool shot when the hull lifts clear of the water.
Probably a death sentence for the camera though. Damage or loss is pretty likely I think.
| | | Re: Raid Ybel
[Re: pgp]
#249883 06/21/12 09:41 AM 06/21/12 09:41 AM |
Posts: 5,525 | I see a lot of them mounted forward of the spin pole. Is that a stock item you can buy or are people just cobbling stuff together?
First thing I want to buy is a tripod. An egret stops by every year about this time and helps himself to my goldfish and I want to get it on video.
| | | Re: Raid Ybel
[Re: pgp]
#249884 06/21/12 10:27 AM 06/21/12 10:27 AM |
Posts: 1,152 tampa, fl | I use a section of broken spin pole (seems that I have a lot of that laying around) taped to the spin pole to get the camera out in front. In a pinch, you could probably cut a piece of broom stick for the same result.
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Raid Ybel
[Re: pgp]
#249885 06/21/12 11:03 AM 06/21/12 11:03 AM |
Posts: 5,525 | I dunno, seems like expensive kit to be hanging off the end of a broom stick.
Mine does have it's own pfd, so IF I remember to attach a tether all should be good. I have heard of one Go Pro at the bottom of the Atlantic, or maybe it was the Gulf.
| | | Re: Raid Ybel
[Re: pgp]
#249886 06/21/12 11:49 AM 06/21/12 11:49 AM |
Posts: 4,119 Northfield Mn | There's clamps you can get. Tie a safety line to it for sure.
A lot Karl? Really? Way to play it down. Beth's C2 should be named "99 spin poles, but straight ain't one"
| | | Re: Raid Ybel
[Re: Karl_Brogger]
#249888 06/21/12 12:17 PM 06/21/12 12:17 PM |
Posts: 1,152 tampa, fl | A lot Karl? Really? Way to play it down. Beth's C2 should be named "99 spin poles, but straight ain't one"
Bravo!
[Re: ksurfer2]
#249891 06/21/12 12:44 PM 06/21/12 12:44 PM |
Posts: 4,119 Northfield Mn | A lot Karl? Really? Way to play it down. Beth's C2 should be named "99 spin poles, but straight ain't one"
Bravo! I can't talk. I've got a pile of expensive broken carbon tiller extensions.
| | | Re: Raid Ybel
[Re: Karl_Brogger]
#249899 06/21/12 03:30 PM 06/21/12 03:30 PM |
Posts: 3,906 Clermont, FL, USA | I can't talk. I've got a pile of expensive broken carbon tiller extensions.
I've heard they are easily fixed.
| | | Re: Raid Ybel
[Re: David Ingram]
#249901 06/21/12 04:01 PM 06/21/12 04:01 PM |
Posts: 4,119 Northfield Mn | I can't talk. I've got a pile of expensive broken carbon tiller extensions.
I've heard they are easily fixed. I wouldn't think the adjustable ones would be too easy. Maybe? Plus I just keep cutting them down until I can't reach em anymore, then replace just the inner part. I've only had one explode the whole length.
| | | Re: Raid Ybel
[Re: Karl_Brogger]
#249902 06/21/12 05:29 PM 06/21/12 05:29 PM |
I've heard they are easily fixed. I wouldn't think the adjustable ones would be too easy. Maybe? Plus I just keep cutting them down until I can't reach em anymore, then replace just the inner part. I've only had one explode the whole length. I broke the outside sleeve of my carbon Hobie hot stick and it was easily repaired. I repaired it the way Jake described and it turned out well. I also repaired my battlestick and sleeved it the way Bret told me to and I'm very pleased with the repair. I also figured out how to make it perfectly straight. If it wasn't straight I'd never hear the end of it from Bret.
588
guests, and 22
