Page 3 of 3 1 2 3
Re: A bunch of Nacra Inter 20 questions [Re: timtower] #250046
06/26/12 10:44 AM
06/26/12 10:44 AM
M
MN3
MN3
M
Originally Posted by timtower
Where/how do I mount a cleat for the tack? I'd probably put it right next to the spinnaker halyard, starboard side, and use a similar cleat. I also need to mount a cleat for my jib furling line. Port side with a similar cleat as the spin halyard?
I was reluctant to respond since i don't sail a I20/N20 but... I (personally) have my jib cleat on the port side of my front beam. My tack line is in the same type of cleat (ronstan alum teeth) but on the stbd side of my mast (on the beam). I use different color lines so i can yell at crew Pull the RED...etc
My spin halyard runs through a spin lock about 1.5' up my mast. Some had issues with spin locks but i think the issues were resolved when they went to alloy inside the spin lock. I have a very thin halyard and no problems with it.
If you have regular crew, and they like to STAND UP while raising the spin... many people put the spinlock a few feet higher up the mast.. .i sail solo often and don't want to stand to raise it (or increase my odds of it self locking while i am snuffing)
PS the halyard/retrieval is continuous on my cat, tack is separate.
Re: A bunch of Nacra Inter 20 questions [Re: ] #250070
06/26/12 03:27 PM
06/26/12 03:27 PM
Hawaii
timtower Offline OP
timtower  Offline OP
Hawaii
Thanks for the info
Sabotage
USA 302
Nacra Inter 20
https://TurnoverBnB.com
Re: A bunch of Nacra Inter 20 questions [Re: timtower] #250129
06/27/12 10:26 AM
06/27/12 10:26 AM
M
MN3
MN3
M
glad to help
Re: A bunch of Nacra Inter 20 questions [Re: timtower] #250156
06/27/12 10:56 PM
06/27/12 10:56 PM
Arizona
AzCat Offline
AzCat  Offline
Arizona
Notice that on a lot of boats the original position for the rotationcleats has been abandoned and that it's been run different ways also that the rotation has been changed to basically an on off does anyone have some pictures of the on off for the rotation I kind of like the rotation in the position that it's currently in For fine adjustments ,but it does seem to come uncleated quite often , especially when I tie off to the trapeze line. Seems like it needs Bungie going over the top of it so that it doesn't come on cleaded quite so easily. I'm thinking about trying to run the end of the rotation line into the main beam but I'm thinking that that may just pull it out of the Cleat, also tied off to a bungee in the main beam
Auscat MKV 444 A class
NACRA I-20- 440/CATHATKA
Page 3 of 3 1 2 3
0 registered members (), 323 guests, and 36 spiders.
