Raid Ybel #249322
06/07/12 08:08 AM
06/07/12 08:08 AM
pgp Offline OP
pgp  Offline OP
http://connect.garmin.com/player/91690890
Time to do Raid Ybel again and see if we can take some time off last years run. Jay? Anyone?
Pete Pollard
Blade 702
Re: Raid Ybel [Re: pgp] #249863
06/20/12 01:15 PM
06/20/12 01:15 PM
I'm good. what's your schedule like?
Re: Raid Ybel [Re: pgp] #249867
06/20/12 01:38 PM
06/20/12 01:38 PM
pgp Offline OP
pgp  Offline OP
Open, except for this weekend. Be sure to check your make up, I just bought a Go Pro.
Pete Pollard
Blade 702
Re: Raid Ybel [Re: pgp] #249881
06/21/12 09:08 AM
06/21/12 09:08 AM
I keep wanting to mount a GoPro to the underside of a hull behind the daggerboard. It'd be a cool shot when the hull lifts clear of the water.
Probably a death sentence for the camera though. Damage or loss is pretty likely I think.
Re: Raid Ybel [Re: pgp] #249883
06/21/12 09:41 AM
06/21/12 09:41 AM
pgp Offline OP
pgp  Offline OP
I see a lot of them mounted forward of the spin pole. Is that a stock item you can buy or are people just cobbling stuff together?
First thing I want to buy is a tripod. An egret stops by every year about this time and helps himself to my goldfish and I want to get it on video.
Pete Pollard
Blade 702
Re: Raid Ybel [Re: pgp] #249884
06/21/12 10:27 AM
06/21/12 10:27 AM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
I use a section of broken spin pole (seems that I have a lot of that laying around) taped to the spin pole to get the camera out in front. In a pinch, you could probably cut a piece of broom stick for the same result.
Re: Raid Ybel [Re: pgp] #249885
06/21/12 11:03 AM
06/21/12 11:03 AM
pgp Offline OP
pgp  Offline OP
I dunno, seems like expensive kit to be hanging off the end of a broom stick.
Mine does have it's own pfd, so IF I remember to attach a tether all should be good. I have heard of one Go Pro at the bottom of the Atlantic, or maybe it was the Gulf.
Pete Pollard
Blade 702
Re: Raid Ybel [Re: pgp] #249886
06/21/12 11:49 AM
06/21/12 11:49 AM
There's clamps you can get. Tie a safety line to it for sure.
A lot Karl? Really? Way to play it down. Beth's C2 should be named "99 spin poles, but straight ain't one"
Re: Raid Ybel [Re: Karl_Brogger] #249888
06/21/12 12:17 PM
06/21/12 12:17 PM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
Bravo!
Re: Raid Ybel [Re: Karl_Brogger] #249889
06/21/12 12:20 PM
06/21/12 12:20 PM
Massachusetts
tzilinski Offline
tzilinski  Offline
Massachusetts
I have the suction cup mount. I mounted it on the inside of the hull near to/tied to the bridle. It worked great until I dove the hull down and the camera got tilted towards the water. Next I put it on top of the hull in the same general location and it worked great. I did get the spin sheet caught on it once though.
Re: Raid Ybel [Re: ksurfer2] #249891
06/21/12 12:44 PM
06/21/12 12:44 PM
Bravo!
I can't talk. I've got a pile of expensive broken carbon tiller extensions.
Re: Raid Ybel [Re: Karl_Brogger] #249899
06/21/12 03:30 PM
06/21/12 03:30 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
I've heard they are easily fixed.
F18 USA 242
http://www.solarwind.solar
Re: Raid Ybel [Re: David Ingram] #249901
06/21/12 04:01 PM
06/21/12 04:01 PM
I wouldn't think the adjustable ones would be too easy. Maybe? Plus I just keep cutting them down until I can't reach em anymore, then replace just the inner part. I've only had one explode the whole length.
Re: Raid Ybel [Re: Karl_Brogger] #249902
06/21/12 05:29 PM
06/21/12 05:29 PM
Clermont, FL, USA
Clermont, FL, USA
I broke the outside sleeve of my carbon Hobie hot stick and it was easily repaired. I repaired it the way Jake described and it turned out well. I also repaired my battlestick and sleeved it the way Bret told me to and I'm very pleased with the repair. I also figured out how to make it perfectly straight. If it wasn't straight I'd never hear the end of it from Bret.
F18 USA 242
1 registered members (FredL), 446 guests, and 68 spiders.
