| Re: Best Traveller System
[Re: barrylay]
#250245 06/28/12 06:39 PM 06/28/12 06:39 PM |
Posts: 12,310 South Carolina | I've had a few cats in my life, and all have had crappy traveller systems in my opinion. It is dead difficult to use the traveller to best effect with the systems that come with Hobies, Prindles and Nacras. Granted, I have only had older boats, so maybe on the later boats these systems are improved.
To use the mainsheet to tension the main and the traveller to set the angle of the main I want to be able to have better control of the traveller than the traveller sheet anchored at the middle of the rear beam, then passing through the block on top of the car, and then to my hand. This is effectively a 1:1 system when the traveller is dead center and a 2:1 system when it is eased out. Mostly it is close to center.
What's a better solution?
I am putting together a P18-2 and would like to get it right.
Thanks Barry Barry, this is pretty much what all of us are running. It works well as long as the bearings and the track are clean and in good shape. A bearing replacement usually makes a big difference (you can buy the torlon ball bearings at places like McMaster.com and save a little $).
Jake Kohl | | | Re: Best Traveller System
#250246 06/28/12 07:59 PM 06/28/12 07:59 PM |
Posts: 1,911 South Florida & the Keys | I agree with Jake. Having suffered for years with the ARC forward option with sheet runing through several blocks, the simplest most direct option is the best. When you relaese the tension, regardless of the wind pressure, you want to see the traveler move. I feel like the Hobie set up is best. Maybe a little tweak with a pig tail on the end at the beam in order to get you dead center or beyond.......
All the best,
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: Best Traveller System
[Re: mikekrantz]
#250289 06/29/12 10:48 AM 06/29/12 10:48 AM |
Posts: 5,590 Naples, FL | That sounds ideal, Mike. Why don't more boats have them? Too difficult to engineer along a straight rear beam?
I was wondering why the larger cruising cats don't use curved tracks in lieu of the traveler/boom vang combination.
[Re: barrylay]
#250309 06/29/12 12:06 PM 06/29/12 12:06 PM |
Posts: 12,310 South Carolina | Thanks everyone. I guess I'll try Jake's suggestion first, but when I searched McMaster's I see all kinds of bearings, but not sure of the exact description of the bearings on the car. I'm guessing they're thrust bearings of some kind. The curved track sounds ideal, but not sure how to pull that one off. Never welded aluminum either. Any help on the exact type of bearing would be cool. Thanks Barry Search for "Torlon Balls"...not sure if this link will work correctly. I ~think~ the standard Harken traveler uses 3/16" balls - but I recommend you measure them before ordering. http://www.mcmaster.com/#torlon-balls/=i6ukv6
[Re: barrylay]
#250311 06/29/12 12:10 PM 06/29/12 12:10 PM |
Posts: 5,525 | Where's the shirt? "cat sailors have torlon balls".
Pete Pollard Blade 702
1 registered members (Talus1),
680
guests, and 163
