Taper Warpspeed #25107
10/14/03 07:54 PM
10/14/03 07:54 PM
Daytona Beach FL
TheoA Offline OP
TheoA  Offline OP
Daytona Beach FL
Ok, so I've got a new 8:1 mainsheet system
I need to figure out how to taper this stuff, as I went with 3/8's line, and with the cover on it's rubbing against each other. I need to taper to the core, and then splice the core around the lower block becket.
Looking, but I don't find anything online.
94 N5.5SL
Re: Taper Warpspeed [Re: TheoA] #25108
10/14/03 08:19 PM
10/14/03 08:19 PM
Daytona Beach FL
TheoA Offline OP
TheoA  Offline OP
Daytona Beach FL
btw, I've searched and found instructions about this, but in the pictures and directions, the cover is still pictured ????
94 N5.5SL
Re: Taper Warpspeed [Re: TheoA] #25109
10/14/03 08:48 PM
10/14/03 08:48 PM
Samson Rope Splicing Page
In there you want the file for a type 2 as follows:
Stripping Cover from Core-Dependent Class 2 Double Braids
I just used these instructions last night while watching the Falcons get clobbered by the Rams . At least it gave me something to be proud about for the evening.
Re: Taper Warpspeed [Re: Jake] #25110
10/14/03 08:52 PM
10/14/03 08:52 PM
Daytona Beach FL
TheoA Offline OP
TheoA  Offline OP
Daytona Beach FL
Got that part Jake, thanks!
Any idea on how to splice an eye in the end of the warpspeed, Core ONLY??? Can it been done?
94 N5.5SL
Re: Taper Warpspeed [Re: TheoA] #25111
10/14/03 10:19 PM
10/14/03 10:19 PM
The core of that warpspeed (looking at the picture on the web) looks like a 12 strand Class 2 on the Samson website. You just might be able to pull that off (that would be cool!). Try the eye-splice for the Class 2 12-strand rope. I did a couple of those last night as well on some 1/8" Amsteel Blue and they came out really cool...Although, I had to make a splicing needle to use in place of a fid because of the small diameter.
Re: Taper Warpspeed [Re: TheoA] #25112
10/15/03 09:45 AM
10/15/03 09:45 AM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
Samson's site has specific instructions for eye splices in the core of stripped class 2 ropes, which are almost exactly the same as for 12 braid class 2 ropes but for one detail: Warpspeed's core is 8 braid, not 12 braid.
However, the only difference is in the procedure for cutting some strands for tappering the bitter end before buriyng - not really complicated to figure out alone, if necessary.
Cheers,
Luiz
Luiz
Re: Taper Warpspeed [Re: Luiz] #25113
10/16/03 10:33 AM
10/16/03 10:33 AM
Daytona Beach FL
TheoA Offline OP
TheoA  Offline OP
Daytona Beach FL
After being completly confused, a call to sampson cleared it up
It's a 24 strand double braid according to them.
Use the destructions for class 2 double braid. Don't let the core be exposed to UV for extended (read days) periods of time. Who leaves there mainsheet blocks on their boat???!?!?
94 N5.5SL
Re: Taper Warpspeed [Re: TheoA] #25114
10/16/03 11:32 AM
10/16/03 11:32 AM
So what about the core?
Re: Taper Warpspeed [Re: Jake] #25115
10/16/03 01:55 PM
10/16/03 01:55 PM
Daytona Beach FL
TheoA Offline OP
TheoA  Offline OP
Daytona Beach FL
The section
Class 2 double braids.
Has 3 DL's, one of which is eye splicing core only, other one is tapering and stripping the core, third ???
BTW, could you tell me about the sheet you stripped and tapered? is it stiffer in anyway where you put the cover back into the core? I don't want to ruin 200$ worth of mainsheet by making the taper so stiff that it won't run through the blocks
94 N5.5SL
Re: Taper Warpspeed [Re: TheoA] #25116
10/16/03 03:38 PM
10/16/03 03:38 PM
I just did a test piece with a short new piece of 1/4" that wasn't made to strip the core from (the core was a bit fuzzy) - I can't really be of any help there.
Re: Taper Warpspeed [Re: Jake] #25117
10/16/03 08:57 PM
10/16/03 08:57 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
Guys,
I have the old color scheme Warpspeed (blue core) and spliced it myself. It is a double braid and the core is 8 strand.
The splicing instructions (I agree they can be "destructions" depending on your patience) can be downloaded from here. Choose one of the three "Class 2 Double Braid" instructions.
In my opinion Dyneema (the core) is VERY easy to work with. Just follow the instructions.
One detail: when splicing the core only, I prefer the Brummel splice for extra safety. There are online instructions somewhere, but I can't remember where. I probably have them. If you are interested, just let me know.
Cheers,
Luiz
0 registered members (), 490 guests, and 38 spiders.
