| Taper Warpspeed #25107 10/14/03 07:54 PM 10/14/03 07:54 PM |
Joined: May 2003 Posts: 139 Daytona Beach FL TheoA OP
Posts: 139 Daytona Beach FL | Ok, so I've got a new 8:1 mainsheet system I need to figure out how to taper this stuff, as I went with 3/8's line, and with the cover on it's rubbing against each other. I need to taper to the core, and then splice the core around the lower block becket.
Looking, but I don't find anything online.
94 N5.5SL
| | | Re: Taper Warpspeed
[Re: TheoA]
#25108 10/14/03 08:19 PM 10/14/03 08:19 PM |
Posts: 139 Daytona Beach FL | btw, I've searched and found instructions about this, but in the pictures and directions, the cover is still pictured ????
94 N5.5SL
| | | Re: Taper Warpspeed
#25110 10/14/03 08:52 PM 10/14/03 08:52 PM |
Posts: 139 Daytona Beach FL | Got that part Jake, thanks!
Any idea on how to splice an eye in the end of the warpspeed, Core ONLY??? Can it been done?
94 N5.5SL
| | | Re: Taper Warpspeed
[Re: TheoA]
#25112 10/15/03 09:45 AM 10/15/03 09:45 AM |
Posts: 1,307 Asuncion, Paraguay | Samson's site has specific instructions for eye splices in the core of stripped class 2 ropes, which are almost exactly the same as for 12 braid class 2 ropes but for one detail: Warpspeed's core is 8 braid, not 12 braid.
However, the only difference is in the procedure for cutting some strands for tappering the bitter end before buriyng - not really complicated to figure out alone, if necessary.
Cheers, Luiz
Luiz
| | | Re: Taper Warpspeed
[Re: Luiz]
#25113 10/16/03 10:33 AM 10/16/03 10:33 AM |
Posts: 139 Daytona Beach FL | After being completly confused, a call to sampson cleared it up
It's a 24 strand double braid according to them.
Use the destructions for class 2 double braid. Don't let the core be exposed to UV for extended (read days) periods of time. Who leaves there mainsheet blocks on their boat???!?!?
94 N5.5SL
| | | Re: Taper Warpspeed
#25115 10/16/03 01:55 PM 10/16/03 01:55 PM |
Posts: 139 Daytona Beach FL | The section Class 2 double braids. Has 3 DL's, one of which is eye splicing core only, other one is tapering and stripping the core, third ??? BTW, could you tell me about the sheet you stripped and tapered? is it stiffer in anyway where you put the cover back into the core? I don't want to ruin 200$ worth of mainsheet by making the taper so stiff that it won't run through the blocks
94 N5.5SL
| | | Re: Taper Warpspeed
[Re: TheoA]
#25116 10/16/03 03:38 PM 10/16/03 03:38 PM |
Posts: 12,310 South Carolina | I just did a test piece with a short new piece of 1/4" that wasn't made to strip the core from (the core was a bit fuzzy) - I can't really be of any help there.
Jake Kohl | | | Re: Taper Warpspeed
#25117 10/16/03 08:57 PM 10/16/03 08:57 PM |
Posts: 1,307 Asuncion, Paraguay | Guys, I have the old color scheme Warpspeed (blue core) and spliced it myself. It is a double braid and the core is 8 strand. The splicing instructions (I agree they can be "destructions" depending on your patience) can be downloaded from here. Choose one of the three "Class 2 Double Braid" instructions. In my opinion Dyneema (the core) is VERY easy to work with. Just follow the instructions. One detail: when splicing the core only, I prefer the Brummel splice for extra safety. There are online instructions somewhere, but I can't remember where. I probably have them. If you are interested, just let me know. Cheers,
Luiz
436
guests, and 52
