| Re: Major rudder problem!!!
[Re: mrw1]
#25263 10/20/03 07:21 PM 10/20/03 07:21 PM |
Posts: 14 | The rudder itself broke, Correction:, it did break around the bolt for the arm that locks down, not for the frame like i said before. So just imagine that where the bolt for the arm attaches to the rudder, broke off so that the bolt cant hold anymore. Pretty much a chunk of the rudder broke off....ughh Im guessing im just gonna have to buy a new rudder right? there 100$..not to bad. how much is a whole rudder assembly with everything?
[Re: yankyfan2O00]
#25264 10/20/03 09:35 PM 10/20/03 09:35 PM |
Joined: Sep 2003 Posts: 270 Nepean (Ottawa) Ontario Canada Frozen
Posts: 270 Nepean (Ottawa) Ontario Canada | Depending on how and where it broke, I would be tempted to drill through one piece into the other and epoxy in some kind of long slender screw or two or three.
Of course if it rebreaks you might end up having a great afternoon of sailing terminated by a crawling back to the marina.
Cheers Alan F
Tiger
[Re: mrw1]
#25266 10/21/03 08:40 AM 10/21/03 08:40 AM | Anonymous
| Anonymous
Unregistered | I did the same thing on one of the rudders on my 72 16. Didn't want to spend any money on the repair, so I fixed it with machine screws and 2-part expoxy. Its held so far for two years no problems. Nate | | | Re: Major rudder problem---no problem
[Re: yankyfan2O00]
#25269 10/21/03 05:40 PM 10/21/03 05:40 PM |
Posts: 84 ms/fl | been there done that.....use epoxy---I like the west system....i used x-ray film to wrap around the rudder, taped it down, poured epoxy/harder/hidensity filler--(consistancy of peanut butter)...let it dry. then i sanded to make the rudder back to the original shape. drilled the hole, and went sailing......no problemo....t
A-class #19
[Re: fuzzy]
#25270 10/21/03 08:05 PM 10/21/03 08:05 PM |
Posts: 14 | How strong is it though? I am wondering if it will hold with all the stress when you turn and everything...I wouldnt want it to break when im sailing.
[Re: yankyfan2O00]
#25271 10/22/03 09:12 AM 10/22/03 09:12 AM |
Posts: 84 ms/fl | the rudder i fixed, i have used for 3 years now.....oh, ya might want to drill some vertical holes where the part broke off to give the epoxy more surface to hold...say about 1/2 inch deep.....................t
A-class #19
2,546
guests, and 300
Mod | | Forums35 Topics22,989 Posts268,931 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
