| Re: hobie 18 forestay problems
[Re: djm]
#85630 09/27/06 07:34 AM 09/27/06 07:34 AM |
Posts: 12,310 South Carolina | Some dry lube and a thurough cleaning of the swivel might help things - you should use McLube Sailkote or a dry silicone lubricant. Be careful with some of the dry silicone lubricants because the can still remain a little tacky - and that's bad because it will collect sand and dust. If that doesn't work, you probably need to rebuild the swivel by replacing the bearings or simply replace it.
I don't recall what the jib halyard block looks like but it sounds like something may be bent allowing too much room beside the sheave. I seem to recall that that Hobie 18 wire block has a pin and ring that hold the assembly together. It's possible that the pin is too long leaving the assembly sloppy.
Jake Kohl | | | Re: hobie 18 forestay problems
[Re: djm]
#85634 09/27/06 09:36 AM 09/27/06 09:36 AM |
Posts: 1,459 Annapolis,MD | Thanks for the information everyone. Looks like I need to start with a good cleaning of the swivel and an inspection of the sheave.
Keith - you've got me thinking that I may be tightening the rig too much - does anyone have any base guidlines for right tension by wind speed? This is something I can probably Google, but thought I may ask (I've got a gauge) I personally wouldn't even bother with a gauge on the 18, and in fact any of the tuning guides I've seen don't reference a gauge. In most conditions I'd have the rig tight enough so it didn't flop on shore unloaded, with it being a little tighter in windy stuff. When sailing upwind with the main cranked you'll notice that the leeward shroud is loose. No big deal. Your mast should rotate freely as well - if it doesn't your rig is too tight. There is a performance tuning guide for the 18, some of it is a bit outdated. I believe it was written Phil Berman, not sure if it is still available. I may have mine still, can't remember if went with the boat or not, I can check. | | | Re: hobie 18 forestay problems
[Re: djm]
#85635 09/27/06 09:57 AM 09/27/06 09:57 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Just get a new spinner for the top. I believe it's attached to the pig tail and it's probaly a good idea to replace that anyway if it's been a while. Another thing to think about is if that thing is binding that bad it may fall apart and you know what that means.
The jumping off haylard is easy to fix. Pull the pin that the shive pivots on and remove the shive. Use vise grips,vise or something similar, squeeze the outer shell of the block closed a bit then reassemble. Just like new.
[Re: djm]
#85637 09/27/06 12:02 PM 09/27/06 12:02 PM |
Posts: 1,187 38.912, -95.37 | Rebuilding the drum located the actual problem at the swivel on our 18. Our dealer (Jim Sohn) stated that over time, and without periodic lubrication, the swivel will develop "flat" spots. Lubrication got us by (needed replacement).
Berman describes marking the shrouds at three feet above the deck and stretching a tape measure straight across these points. I recall a six inch deflection, when pressing inward on one shroud, to be the heavy air setting. His book (the Hobie 18 Performance Manual) is filled with these type of measurements. A similar method is described for diamond tension by pressing inward to within one inch of mast and measuring up from their attachment points (12", 24" & 36") for varying conditions of "the three W's", wind, water and weight.
[Re: djm]
#85641 09/29/06 08:31 AM 09/29/06 08:31 AM |
Posts: 12,310 South Carolina | I'm pretty sure that the TheMightyHobie18 I used to have had a wire luff halyard for the jib too. Sister clips are two little clips - usually flat pieces of stainless - that have a tiny slot on the side that opens into the round interior. You put two clips at 90 degrees to each other and they will slide inside each other. They have no moving parts and stay connected when they can be protected like in the jib luff. Makes it easy to remove the halyard tail used to hoist the sail.
#85642 09/29/06 02:05 PM 09/29/06 02:05 PM |
Posts: 1,382 Essex, UK | sister clips are also known as Inglefield clips or hooks. They are also sometimes known as flag clips since they are most often used on signal flags.
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: hobie 18 forestay problems
[Re: soulofasailor]
#253176 10/05/12 08:48 AM 10/05/12 08:48 AM |
Posts: 12,310 South Carolina | I have been having helm issues my boat would fall off really bad so i messed with my fore-stay, i loosened it up allot then went sailing! Before the boat was falling off re bad now it rounded up with it real loose! so I tightened it a little but still real loose now it is doing better but i think the forestay is really to loose yet, hmm I know its not a Hobie but does anyone have a rule of thumb? if i had chop in the waters i sail i would not go out like this! Forestay tightness will not have much effect on helm. Two major adjustments will help. 1) Mast Rake. Sailing under way, the sideways resistance is provided by the daggerboard(s), sideways force is generated by the sails. If you rake the mast forward, you move the sideways force generated further in front of the primary resisting force (the daggerboards) and have more lee-helm (your condition here). To reduce lee-helm, rake the mast further aft to bring the sail plan closer to the daggerboards or even aft of the daggerboards to generate weather-helm. All other things being neutral (see #2), a slight amount of weather-helm is desirable because it puts your foils to their best use (allowing both the rudders and daggerboards to generate some lift). #2) rudder rake. This affects how the boat turns and how how the tiller feels. It is often confused with performance tuning of the foils - it is not. Rudder rake is used make the helm feel more or less neutral but the effeciency of the foils through the water depends NOT on what you feel in the tiller, but what forces are acted on them by the mast rake/sail plan. If your rudders are raked such that the center of effort is in front of the pivot axis (the pintles), the rudders will react opposite of the sail/daggerboard remaining force (weather-helm or lee-helm) and neutralize it somewhat. If the rudder rake puts the center of effort of the rudders through the water BEHIND the pivot axis, the feel of the helm will be more affected by the sail/daggerboard reaction. To make a clean setup, set your sails to sail to weather, have daggerboard(s) fully extended, and raise your rudders clear (or nearly clear) of the water. The boat should round up into the wind. If it remains neutral or rounds down to lee, you need to rake your mast aft. Once you have a decent amount of weather helm, now adjust your rudder rake until your helm feels like you want it to. If, with rudders now down, the boat changes and turns to the lee, rake your rudders more aft - i.e., further away from being under the boat. If, with rudders down, the boat turns much harder into the wind, rake the rudders forward. Most people like their helms setup with just a little weather helm. It gives boat boards the opportunity to work and is safer (if you should drop the helm or something break, the boat rounds up instead of bearing away and accelerating).
Jake Kohl | | |
4,696
guests, and 1,292
