| Nacra 5.0 diamond wires? #252878 09/30/12 05:18 PM 09/30/12 05:18 PM |
Posts: 337 Arizona | I picked up an "83 N5.0 and it has diamond wires. I'm wondering if their stock. The top attachment is on the front of the mast and is a single point attachment. The spreader is a straight bar and looks to be in the correct position. The bottom attachment is single with a turnbuckle. The wire is slack to the point that I can squeeze them together about 20" above the turn buckle. It seems to me that the mast will invert or bend backward under load. I guess that it may just bend on its small access w the slack diamonds.
Anyway, is this a stock diamond setup for the 5.0?
Also, I have a "76- 5.2 and the wires run from center top to a straight spreader, and to center at the. Ottom attachment with a bottle adjuster at the bottom
Auscat MKV 444 A class NACRA I-20- 440/CATHATKA | | | Re: Nacra 5.0 diamond wires?
[Re: Andinista]
#253082 10/03/12 06:51 PM 10/03/12 06:51 PM |
Posts: 337 Arizona | Did the original 5.0 have wires? this looks like a factory setup bu i cant see how it would help shape the mast in a positive way. seems like the straight spreader would bend forward and collapse. I dont really like the idea of having a great big hole drilled in the mast. If I take the current spreader out it will leave the hole un supported. Gives me the creeps.
[Re: AzCat]
#253115 10/04/12 09:49 AM 10/04/12 09:49 AM |
Joined: Aug 2003 Posts: 351 Santiago, Chile Andinista
Posts: 351 Santiago, Chile | I read your first post again and I think your concern is about the attachment points being in the front of the mast, therefore bending it the opposite way. I'd say that with this straight spreader you need less tension than with adjustable ones, because you are not using the diamong wires to pre-bend the mast. The pictures above are from a friend's 5.0, I checked other pictures and it seems they are also attached in the front.
[Re: Andinista]
#253185 10/05/12 11:47 AM 10/05/12 11:47 AM |
Posts: 337 Arizona | As long as I know that it was a factory setup I guess I'll leave It as is for now, according to today's logic, it didn't seem right, and I'm sure it isn't right to induce the correct / wanted bend in the mast. The boat is pretty basic right now, I'll sail it simple for a while and see how it does. I'll be racing a P-16, P-18, 18ht, tiger, G-Cat 18 and 16ht this weekend, p-16 is the only boat that rates higher than the 5.0. No line honors for me this time. It ill kick butt on Portsmouth! Bring it on boys!
[Re: AzCat]
#253186 10/05/12 12:49 PM 10/05/12 12:49 PM |
Posts: 12,310 South Carolina | As long as I know that it was a factory setup I guess I'll leave It as is for now, according to today's logic, it didn't seem right, and I'm sure it isn't right to induce the correct / wanted bend in the mast. The boat is pretty basic right now, I'll sail it simple for a while and see how it does. I'll be racing a P-16, P-18, 18ht, tiger, G-Cat 18 and 16ht this weekend, p-16 is the only boat that rates higher than the 5.0. No line honors for me this time. It ill kick butt on Portsmouth! Bring it on boys! Practically every catamaran prior to 1985 had straight spreaders that stuck through a hole in the mast. The hot boats started introducing raked spreaders and masts with prebend setups...it didn't take long for the rest to follow suit. The straight spreader has been around a long time - there's nothing wrong with it structurally...it's just not quite as tunable.
Jake Kohl | | | Re: Nacra 5.0 diamond wires?
#253229 10/07/12 09:53 PM 10/07/12 09:53 PM |
Posts: 337 Arizona | Is there any precident for removing the straight and adding a raked spreader? Or would it require a new mast?
[Re: AzCat]
#253246 10/08/12 09:05 AM 10/08/12 09:05 AM |
Posts: 12,310 South Carolina | I'm sure it's been done, but raked spreaders put considerably more loading on the mast...and you've got a hole right where that load is highest. Where you might have run 10 or 30 lbs of diamond wire tension with the straight spreaders, you're probably looking at upwards of 500 lbs or more with the raked spreaders...I probably wouldn't mess with it.
[Re: AzCat]
#253350 10/09/12 11:46 PM 10/09/12 11:46 PM |
Posts: 337 Arizona | Yea Jake, I was leaning in that direction. That's a pretty big hole an I don't want to do anything that hasn't been done successfully by other brave souls, thanks all for your input.
[Re: Andinista]
#253385 10/11/12 10:11 AM 10/11/12 10:11 AM |
Posts: 778 Houston | In simple terms, mast inversion is when the mast bends forward instead of aft. When the mast is inverted, you no longer have the expected aft curve that matches the luff curve on your sail. When your mast is inverted, your sail shape is "not fast". This is normally, the worst you see.
When your mast is inverted, you can also get "S" shapes and even more complicated shapes. When the mast starts to move or oscillate in "S" shapes, that is very bad, your mast may fail.
Raking the spreaders aft, with tight diamond wires, puts a force on the mast that try's to bend it the way you want it to and (I am told) stiffens it against motion in other directions.
The problem is worse on the 5.5 uni or NACRA 18sq, which use the same extrusion but, the mast is longer and square top mains make it worse. I have seen 18 sq's rip the top of the sail out or break the mast. This normally happened, downwind in heavy puffy air.
Minor inversions happen on a lot boats and are not that bad. Big inversion or complex shapes that move are very bad. When the mast is oscillating, the wrong load in the wrong direction, cab break the mast.
Tapered, pre-bent masts are the next step. You make the mast easy to bend in the directions you want. at the same time you make it stronger down low and stiffer in directions you don't want it to bend. | | | Re: Nacra 5.0 diamond wires?
[Re: Andinista]
#253417 10/12/12 10:10 AM 10/12/12 10:10 AM |
Posts: 5,590 Naples, FL | does the Nacra 5.5sl have straight spreaders? I was thinking of picking one up for singlehanding and slapping a small spin on it...
[Re: waterbug_wpb]
#253424 10/12/12 10:49 AM 10/12/12 10:49 AM |
Posts: 1,152 tampa, fl | does the Nacra 5.5sl have straight spreaders? I was thinking of picking one up for singlehanding and slapping a small spin on it... The ones I have seen had raked spreaders. One even had a carbon mast.
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Nacra 5.0 diamond wires?
[Re: waterbug_wpb]
#253427 10/12/12 11:48 AM 10/12/12 11:48 AM |
Posts: 12,310 South Carolina | does the Nacra 5.5sl have straight spreaders? I was thinking of picking one up for singlehanding and slapping a small spin on it... You're doing a lot of "thinking" lately. Feeling OK?
Jake Kohl | | |
2,718
guests, and 82
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online4,027 Yesterday at 09:43 PM | | |
