| More properly, trimming the main only in light air
[Re: carlbohannon]
#25467 10/27/03 06:05 PM 10/27/03 06:05 PM |
Posts: 64 Sandy, UT | Okay, I needed to be more specific. Generally reading the wind on the water isn't going to help you trim the main in light breezes. Also feeling the breeze isn't going to help you to know which way you need to trim/adjust course in light air when it can change a lot. I can trim and change course well off the jib telltales, but until the wind blows over about 8-10kts, I can't pick up reliable (to me) info off the main telltales. I appreciate your input, Carl, but I noticed when sailing with a friend who has the sail area of my main only, I found I needed to trim the main radically (I was way oversheeted) when I furled the jib, and I had to use him to read the wind in light air. What I mean by read the wind is how to trim the main/adjust course primarily going to weather. I have streamers on my bridle, but I'm inquiring about conditions when they barely flow. In those conditions I do just fine off the jib info, as soon as I furl, I can't get diddly off the main. I've been experimenting for several years on doing without the jib, but the jib seems just too wonderful in light air to give it up. | | | Re: More properly, trimming the main only in light air
[Re: SteveBlevins]
#25469 10/28/03 04:23 AM 10/28/03 04:23 AM |
Posts: 267 Switzerland | Hi Steve
Here in Switzerland sometimes we have races in almost no wind. Telltales in the sail, in super light air don't work! They stick on the sailcloth. This can be reduced by using sail-lube for the telltales.
My solution for not over sheeting the main is, that I use a light air mark on the sheet. You have to practice, to figure out the right place for the mark on your sheet. An other good indicator are the back-telltales on the leach of main, they shood fly about have of the time (in light air). Also good are long (3 feet) streamers of videotape (VCR) from the bridle wires. The position of them is so, that they point to the backside of the mast, when close to the wind.
Hope this helps...
The more wind the more fun! Greetings from switzerland
[Re: SteveBlevins]
#25470 10/28/03 10:32 AM 10/28/03 10:32 AM |
Posts: 778 Houston | It looks like I didn't understand your question.
Telltales a useful tool, but not the complete story. It's like when your calculator tell you, that you have $352.4599999999... in the bank.
First, you have to know what they are saying. For example, with the crew over sheeting the jib, the main about right and sailing at about the right angle, I know what they look like on my boat. To find out what they look like on your boat practice a little. Fall off a little, trim the sails and see what things look like. Pinch a little and do the same. Is there a difference that depends on the course and not how the sails are trimmed? Now with the sails fixed, fall off and head up. See what this does to the tell tales and the feel of the boat. Now do this in every possible wind speed (This might take a couple of years). Get in the habit of running through a short version between races so you will know what they are supposed to look like.
Flowing straight is not always fastest. My boat and sails go upwind best with the top telltales fluttering a little less than half the time. This is not uncommon.
Light air sailing is an art that requires experience. I learned fun sailing on a lake. If I couldn't sail back, I had to paddle. When the wind is really light I set the main using where the taper goes into the mainsheet and then use a feather wind indicator to steer the boat
A lot of this is experience. Try and remember what works and what doesn't and avoid what doesn't work.
21,430
guests, and 646
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,979 3 hours ago | | |
