Why not repair with carbon? Carbon fibre is 29X stronger than fibreglass?
Websites for carbon materials:
http://www.fibreglast.com/http://www.acp-composites.com/What I did a long time ago was epoxy 1" Carbon tape on the underside of the lip
all around the boat, since it was basically cracking everwhere.
(If you question the legality of this the 1989 Worlds TheMightyHobie18's where carbon reinforced.)
While you are at it you might as well do the rear beam area next,
as it will start to crack once you stiffen up the front.
In addition, As I recall, I took old aluminum rudder pins and West System'ed them
under the lip at all four beam beam attachment points. (Aluminum is 10X fibreglass?)
At first I only did this at the main beam, but then the ream beam area cracked
and the boat would mysteriously fill up with water.
