| My F16 Blade build #255393 12/02/12 04:54 PM 12/02/12 04:54 PM |
Joined: May 2003 Posts: 4,451 West coast of Norway Rolf_Nilsen OP
Posts: 4,451 West coast of Norway | I am unable to find my old "build" thread, if there ever was one.. Lots of water have passed into the sea and lots of stuff have happened in my life but the build is still ongoing. We build 1-3 hours a week so this is taking forever to finish if you look at the calendar. If counting hours it is not that bad but it would be nice to go sailing soon. Anyway, what I was going to do was to give you some input on installation of the main deck. First you need a hull with a load bearing structure of course silly. Then a 4mm gaboon ply piece to fit as the deck. Notice deck beams with thick paper glued on to hold the thickened epoxy for fillets as the deck is installed. The centerboard case is clearly visible, as is the carbon chainplate. http://woodastic.blogspot.no/2012/12/main-deck.htmlThe underside of the deck is first covered in unthickened epoxy and put aside. Then an hour is spent preparing all surfaces and fillets on the hull. Last thing I do before installing the deck is to add another rather thick layer of inthickened epoxy. This is the waterproofing for the underside of the deck.. Then it is only a matter of positioning the deck, slap it on, and apply pressure to force it down on to the hull. If no thickened glue is pressed out, you now have a real issue to handle http://woodastic.blogspot.no/2012/12/main-deck-in-place.htmlYou can NOT have too many straps.. All in all a 3 hour job for a single person.
| | | Re: My F16 Blade build
[Re: Rolf_Nilsen]
#255395 12/02/12 05:50 PM 12/02/12 05:50 PM |
Posts: 5,525 | Looks good. You are a patient man!
Pete Pollard Blade 702
[Re: Rolf_Nilsen]
#255418 12/03/12 10:22 AM 12/03/12 10:22 AM |
Posts: 5,590 Naples, FL | looks very nice. Could you estimate the materials cost (or the amount of material you've used so far)?
Where did you get the plans / scantling drawings?
[Re: Rolf_Nilsen]
#255439 12/03/12 04:54 PM 12/03/12 04:54 PM |
Posts: 4,119 Northfield Mn | Everytime I see a boat being built outta wood, all I can think is you are nuts, but I play with wood all day, and at the end of that day, I don't care to do anymore.
Looks very nice Rolf. I've been kicking around building a boat plug in a semi similar fashion.
[Re: Rolf_Nilsen]
#255458 12/04/12 10:17 AM 12/04/12 10:17 AM |
Posts: 932 Solomon's Island, MD | Rolf you do very nice work! Its great that you are building a boat, most of us just talk and never do. Part of that for me is the money doesn't make sense. I can scrounge (have more boat parts than I care to admit) but the major costs of mast, rigging, beams and sails aren't going anywhere and still run $10K if bought new  I guess if you built molds for the hulls, molds for the mast you could build an exotic boat for cheaper than buying, excluding labor. Would be a fun group project.
Scorpion F18
[Re: samc99us]
#255471 12/04/12 01:34 PM 12/04/12 01:34 PM |
Posts: 4,451 West coast of Norway | Rolf you do very nice work! Its great that you are building a boat, most of us just talk and never do. Part of that for me is the money doesn't make sense. I can scrounge (have more boat parts than I care to admit) but the major costs of mast, rigging, beams and sails aren't going anywhere and still run $10K if bought new  I guess if you built molds for the hulls, molds for the mast you could build an exotic boat for cheaper than buying, excluding labor. Would be a fun group project. Depends. I have scrounged two set of beams, two masts and lots of fittings and stuff over the years. Sails we will purchase pre-cut and assemble ourself, or cut the panels ourself as well. If the money is there, it absolutely is best to purchase. If the interest and lack of money is bad enough, building and accepting the compromises and investment in time is the only way to get on the water in the boat you would like. | | | Re: My F16 Blade build
[Re: waterbug_wpb]
#255472 12/04/12 01:42 PM 12/04/12 01:42 PM |
Posts: 5,525 | Here's my next build: poifek
[Re: Rolf_Nilsen]
#255478 12/04/12 08:06 PM 12/04/12 08:06 PM |
Posts: 6,049 Sebring, Florida. | Jay, why do I think the words, "Here, hold my Beer." were involved with the design of this craft?
All you need now is an F18HT mast and a spin pole!
PS, didn't know you were an Alabama fan, but it's all starting to make sense now...
Blade F16 #777
[Re: pgp]
#255486 12/05/12 10:07 AM 12/05/12 10:07 AM |
Posts: 5,590 Naples, FL | Pete, imagine how cheap the one-design build would be?
We could have a huge fleet in no time. Don't need a trailer, don't even need an RC/PRO. Just plenty of Jack Daniels
Heck, you could even demolition derby those things.
Perhaps only in canals or other areas with stagnant water and there would be a class limit on the number of teeth the operator possesses.
[Re: Rolf_Nilsen]
#255490 12/05/12 11:20 AM 12/05/12 11:20 AM |
Posts: 5,525 | jeez, a PDQ catman style.
[Re: Rolf_Nilsen]
#255906 12/27/12 05:11 PM 12/27/12 05:11 PM |
Posts: 4,451 West coast of Norway | Quick update: Both main decks now installed. Tomorrow I plan to put on the rear decks of both hulls. Then trim and glass over the weekend. The hulls will then be structurally complete and we can move on to the fittings we will build. In that regard it looks like my CNC mill will be ready just in time. I might not have mentioned here that part of the project includes building a CNC mill to produce fittings and some other stuff which is too expensive to purchase (and besides quite fun to build, including building the tools to build the parts.. No wonder this boatbuilding takes time  ). Today I did the first cut controlled by computer on the X and Z axis (pic below). Z axis will be the next step before cleanup, finalizing and G(eek)-code learning. Test was a very simple circle G-code program, but the thing seems to work pretty well. | | | Re: My F16 Blade build
[Re: Rolf_Nilsen]
#255917 12/29/12 10:39 AM 12/29/12 10:39 AM |
Posts: 5,525 | Rolf, you are a patient man. I couldn't complete your project in two life times. Now, let's talk about modifying a Blade to a small tri, using the Blade hull as the main hull.
740
guests, and 448
