| Re: Leaving your boat outside during winter
[Re: Arjan13]
#255711 12/14/12 08:40 AM 12/14/12 08:40 AM |
Joined: Jun 2009 Posts: 524 Petten Netherlands northsea junkie
Posts: 524 Petten Netherlands | I also left all my cats in the netherlands outside in wintertime. (Though just this summer I built a open shed around it).
There are three issues which I always carefully check (besides the possible water inside the hulls):
Each cat has a depressurize inlet/outlet and drainplugs. When you let the drainplugs out, take care for possible waterinlet. When you leave them in, be sure that the depressurizing works.
Also make sure that the beams are level to each other on the trailer (beams in each others horizon), so there is no torsion in the connection points. Support the girders for the hulls on the trailer if necessary seperately.
Be sure that the lying mast has no waterinlet.
succes
ronald
ronald RAIDER-15 (homebuilt)
[Re: Arjan13]
#255716 12/14/12 01:05 PM 12/14/12 01:05 PM |
Posts: 4,119 Northfield Mn | A boat should only be outside when sailing.
[Re: Arjan13]
#255742 12/16/12 03:05 AM 12/16/12 03:05 AM |
Posts: 1,203 uk | Surely you are not on one of the North Sea beaches? They even dismantle the clubhouses and take them off of the beach for winter along there! I have seen boats on those beaches that are nice and shiny on their high side, but the side that faces the sea all the time has been sand-blasted right into the gelcoat
[Re: Arjan13]
#255743 12/16/12 04:08 AM 12/16/12 04:08 AM |
Joined: Oct 2006 Posts: 119 Bernhards Bay, N.Y. popeyez7
Posts: 119 Bernhards Bay, N.Y. | ~~ HHMM ??? Where to start? A long long time ago, ok.. just messing here... A few years ago I didn't cover my 17 in time before winter came. Thought I'd be able to get my butt out there and get the snow off of it. One time it snowed for 3-4 days straight and I couldn't see the boat anymore. I said screw it.Come spring time, both rear rollers dissapeared into the hulls. Yep, you guessed it fiberglass time. The following years I built an "A" frame to put my cats under. (I covered them first) My seat sockets always had a slow leak in them so antifreeze won't help you, put duct tape over them to keep snow/water out. I put a bead of silicone around them after I put the seat in for the summer...I'am not sure how to put picts up here but ya can send me a PM or [email protected] for picts.~~
~~Don't fear the ''SPEED''~~ Fear the''ADDICTION'' ~17,18 Hobies, ~Jet boat~Speedster 150 ~2 Kayaks~ ~~~~VIETNAM VET. 69-71~~~~
2,523
guests, and 702
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online7,715 2 hours ago | | |
