| Re: Hobie 18 cracked Hull repair
[Re: Just Another Sailor]
#255757 12/17/12 09:03 AM 12/17/12 09:03 AM |
Posts: 1,884 Detroit, MI | Has anyone separated the deck from the hull completely? You cannot do this without completely destroying the boat. Your best course of action is not to repair, but to replace. A "crack" big enough to cause the hull to sink is a fatal structural failure - in a place where the boat doesn't usually fail. I'm guessing that the boat has wings. If you want to reinforce the hulls at the crossbars, you do it via deck ports - two are already there. Has it occurred to you that sailing an old boat in the open Gulf of Mexico - alone - may not have been the smartest thing to do? Were you prepared to be out there for several days? What if your radio hadn't worked? You're lucky that it wasn't the USCG that responded. They would have taken you off the boat, back to the CG station (Key West) AND you would still be responsible for recovering the boat. | | | Re: Hobie 18 cracked Hull repair
#255759 12/17/12 09:20 AM 12/17/12 09:20 AM |
Posts: 1,884 Detroit, MI | Yes the boat has wings and the crew is big 500 lb total. Replacing the hull does not stop the other hull from failing or a replacement hull as well. I was thinking that it would be best to reinforce both hulls to avoid future problems. If you want to avoid future problems, get a different boat. You're too big for an old Hobie 18 with wings. | | | Re: Hobie 18 cracked Hull repair
#255763 12/17/12 12:17 PM 12/17/12 12:17 PM | Mac m
| Mac m
Unregistered | I've got an 84 TheMightyHobie18 port hull that could be had cheap, it's structurally sound but needs some attention. I'm in South Carolina | | | Re: Hobie 18 cracked Hull repair
[Re: ]
#255765 12/17/12 12:31 PM 12/17/12 12:31 PM |
Posts: 10 | | | | Re: Hobie 18 cracked Hull repair
[Re: ]
#255766 12/17/12 12:33 PM 12/17/12 12:33 PM |
[Re: Mike Fahle]
#255773 12/17/12 08:24 PM 12/17/12 08:24 PM |
Posts: 5,582 “an island in the Pacifi... | Everyone who is telling you to get a different boat is giving you good advice. I had a hobie 18 for 20 years and raced many long distance races on beach cats, so I know from experience. There is a boat listed in the ad section of Catamaran Sailor right now (and it is in Florida, too) for a great price and has been raced in longer races: G-Cat 20 -- Built in 1999, boat is in good condition, rigged for racing, double trapped includes beach wheels and trailer, with additional parts. Boat came in second in division in the 2011 Miami-Key Largo Race. $2900. Located in Fort Lauderdale, FL 954-786-1049 home or 954-914-9207 cell (FL)(Nov2)
You need more boat for that much weight and that usage! It is not too late to get another boat! $2900 is way cheaper then what the TheMightyHobie18 repair will cost in time and materials. Plus, if you've had one major failure there may be more surprises down the road. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: Hobie 18 cracked Hull repair
#255774 12/17/12 09:14 PM 12/17/12 09:14 PM |
Posts: 932 Solomon's Island, MD | I had the pleasure of sailing a g-cat 18 on vacation a few years ago, it is a fantastic boat and the 20 is faster. For the price that is a steal. I'm not sure if the 20 has daggerboards, but I doubt it, they still go to weather the same as the TheMightyHobie18 and you have less to worry about breaking.
Scorpion F18
#255779 12/18/12 05:23 AM 12/18/12 05:23 AM | Mac m
| Mac m
Unregistered | I sent you a pm on that TheMightyHobie18 hull | | | Re: Hobie 18 cracked Hull repair
[Re: BLR_0719]
#255789 12/18/12 04:53 PM 12/18/12 04:53 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | If those are the Pic's. Typical Mid 80's H product.
If you decide to fix that, ( I wouldn't ) have you checked the lip at the front cross bar and the shroud anchor? Any cracks around those points?
Bottom line. The chance of it happening again is very good. You would be putting yourselves at greater risk and you may put someone that has to rescue you at risk unnecessarily.
666
guests, and 164
