wings #255804
12/19/12 03:43 PM
12/19/12 03:43 PM
pgp Offline OP
pgp  Offline OP
I'm thinking about having a set of wings made for the Blade. Has anyone given any thought to dimensions?
Pete Pollard
Blade 702
Re: wings [Re: pgp] #255806
12/19/12 06:06 PM
12/19/12 06:06 PM
My FXone, they came out two feet(ish) and up at an angle about 8-10 inches.
Re: wings [Re: pgp] #255809
12/19/12 06:32 PM
12/19/12 06:32 PM
pgp Offline OP
pgp  Offline OP
thx. Same gauge tuging as the H17?
Pete Pollard
Blade 702
Re: wings [Re: pgp] #255814
12/20/12 08:18 AM
12/20/12 08:18 AM
They were about two inches in diameter. I don't really remember they wall thickness.
Re: wings [Re: pgp] #255815
12/20/12 09:38 AM
12/20/12 09:38 AM
pgp Offline OP
pgp  Offline OP
Any guess as to weight?
Pete Pollard
Blade 702
Re: wings [Re: pgp] #255817
12/20/12 10:14 AM
12/20/12 10:14 AM
Punta Gorda, FL
jkkartz1 Offline
jkkartz1  Offline
Punta Gorda, FL
Re: wings [Re: pgp] #255819
12/20/12 10:59 AM
12/20/12 10:59 AM
pgp Offline OP
pgp  Offline OP
No. They idea is to avoid trapezing all together. I just don't feel safe trapezing when day sailing.
I trapezed off the wings of my H17 and TheMightyHobie18 but that was many moons ago.
Do you know anyone who could fabricate a set?
Pete Pollard
Blade 702
Re: wings [Re: pgp] #255820
12/20/12 11:25 AM
12/20/12 11:25 AM
Punta Gorda, FL
jkkartz1 Offline
jkkartz1  Offline
Punta Gorda, FL
Any of the many marine aluminum fabricaters near you. Try the phone book.
Re: wings [Re: pgp] #255821
12/20/12 01:02 PM
12/20/12 01:02 PM
18 pounds a side.
Re: wings [Re: pgp] #255822
12/20/12 01:06 PM
12/20/12 01:06 PM
pgp Offline OP
pgp  Offline OP
thx.
Pete Pollard
Blade 702
Re: wings [Re: pgp] #255838
12/21/12 12:02 AM
12/21/12 12:02 AM
Mike Fahle Offline
Mike Fahle  Offline
I have wanted to make a set also. I am pretty sure that I can get the local Midas shops to bend the tubing to the shape I want for a pretty reasonable price and pretty quickly (I asked about it when I did some consulting for them a few years ago); they bend steel tubing as needed for exhaust systems. I suspect someone else would have to do any welding but I have a friend who has a shop that does that. Do you know what tubing thickness to use (I would want to be able to trapeeze and to hold at least two people on the wing). I had a 1984 Hobie Magnum with lightweight yet robust wings but never took measurements.
Re: wings [Re: pgp] #255839
12/21/12 01:12 AM
12/21/12 01:12 AM
pgp Offline OP
pgp  Offline OP
I also had an 18 Magnum. But no, I didn't take any measurements.
Pete Pollard
Blade 702
Re: wings [Re: pgp] #255846
12/21/12 12:29 PM
12/21/12 12:29 PM
Daytona Beach Florida
O
orphan Offline
orphan  Offline
O
I recently took a pair of 18M wings and fitted them to my mystere 6.0. I think these would be about 2 feet to long for an F16 and way to much weight. Total weight about 38 pounds. Not much effect on a 450 pound boat but a lot on an F16. Fabricating something using carbon fiber tubes with alum bends would be much lighter.
Re: wings [Re: orphan] #255853
12/21/12 05:06 PM
12/21/12 05:06 PM
Mike Fahle Offline
Mike Fahle  Offline
The Hobie 18 Magnum early years had much lighter wings (and shorter) than what followed later. I do not know what year they changed but I know that the ones I had were surprisingly light, especially for the amount of weight they would hold.
Re: wings [Re: pgp] #255880
12/23/12 06:34 AM
12/23/12 06:34 AM
Punta Gorda, FL
jkkartz1 Offline
jkkartz1  Offline
Punta Gorda, FL
Pete,
Have you talked to Matt about how to attach them to the hulls?
Re: wings [Re: pgp] #255883
12/23/12 09:53 AM
12/23/12 09:53 AM
pgp Offline OP
pgp  Offline OP
No, I don't think he'd have much interest. In any case I've already decided they would insert into the cross bars. Not sure how though.
I have three possible plans:
* add some wings so it will be safer to sail unsupported
* modify it into a small tri, just because.
* sail it as is. This is where the smart money goes.
Merry Christmas.
Pete Pollard
Blade 702
Re: wings [Re: pgp] #255886
12/23/12 06:51 PM
12/23/12 06:51 PM
Mine went into the beams. Pretty simple setup, and I think they worked pretty well.
Re: wings [Re: Karl_Brogger] #255889
12/24/12 10:37 AM
12/24/12 10:37 AM
WEST. MICH. USA
DVL Offline
DVL  Offline
WEST. MICH. USA
I have a very good set of Magnum wings. If anyone needs measurements or wall thickness let me know via personal e-mail and I will get you what dimensions you need.
dale.vanlopik"at" ATT."net"
Re: wings [Re: pgp] #255895
12/26/12 07:59 PM
12/26/12 07:59 PM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
I can manufacture a set, I would not count on a place like Midas to make nice bends, even if they have a mandrel bender its likely their dies will gouge the tube. I would purchase bends online, they are not all the expensive and weld from there. A short piece of smaller tube for making sleeves makes things easier. I considered them on my I20 but concluded that I didn't even use them all that much on the old hobie.
Not familiar with a blade, is there a track in the beams that could be use? Otherwiser some AL plate could be cut on a water jet to support the tube inside of the beam.
Re: wings [Re: pgp] #256047
01/07/13 10:29 AM
01/07/13 10:29 AM
Punta Gorda, FL
jkkartz1 Offline
jkkartz1  Offline
Punta Gorda, FL
0 registered members (), 285 guests, and 47 spiders.
