| Daggarboard questions #255800 12/19/12 01:58 PM 12/19/12 01:58 PM |
Joined: Dec 2001 Posts: 5,590 Naples, FL waterbug_wpb OP
Posts: 5,590 Naples, FL | The curvy daggarboards are too hard for my pea-brain to comprehend, so I'll stick with the simple canted-daggar style.
Am I correct in presuming that a canted daggarboard is more effective going downhill than uphill?
Would the vertical (zero cant) orientation be better upwind to counter the leeway? Or would there be some benefit of vertical lift (i.e., lifting the hull out of the water) with the heeled boat going upwind?
If this is true, is there a good "average" degree of cant that works for beachcats with spins (typically heeled about 15-20 degrees already)?
| | | Re: Daggarboard questions
[Re: Mike Fahle]
#255893 12/26/12 09:50 AM 12/26/12 09:50 AM |
Posts: 5,590 Naples, FL | I was thinking more of the canting keel concept, except for daggars whereby you could cant zero degrees upwind and move it to 10 degrees or so (inward cant from hull centerline) downwind.
But a curved foil may do that more easily? Instead of moving the cant, you just raise/lower the curved foil?
2,669
guests, and 772
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online7,715 4 hours ago | | | |
