| Re: dry-suit???
[Re: Krisu13]
#25679 11/01/03 10:34 AM 11/01/03 10:34 AM |
Posts: 12,310 South Carolina | Must be breathable (otherwise, you will still be wet when you get out of it). I recommend that the zipper be accessable while you are in it (I have a Gill on which the zipper is in the back and I have to have help to get in and out). A relief zipper (i.e. in the crotch) would be REALLY nice.
Jake Kohl | | | Re: dry-suit???
[Re: Krisu13]
#25682 11/03/03 08:27 AM 11/03/03 08:27 AM |
Posts: 20 SE Michigan | My wife and I have used drysuits for quite a bit of cool weather sailing. Off season and a couple of high latitude expeditions. Yes, heavy weight GoreTex is the ticket. You can spend all day in a GoreTex dry suit and remain dry. Our first suits were not breathable, what a difference!
Also recommend latex socks and relief zips. The socks solve the cold feet problem since you can then really layer up your tootsies. You have to wear them under some kind of high top footgear though, to protect the latex. The relief zips are key also. You'll regret it if you don't get your suit with one.
We have Kokatat suits that we bought about 6 years ago. They have held up well though we have been through a complete set of seals in that time. The protective cuffs at neck, wrists, ankles are a good feature.
George
Hobie 21 SC
| | | Re: dry-suit???
[Re: Krisu13]
#25683 11/03/03 09:48 AM 11/03/03 09:48 AM |
Posts: 887 Crofton, MD | I have a Kokatat breathable and its great. They are designed for paddling which requires a lot of upper body freedom. Once I cut the gaskets to the correct size, (tight enough to not allow water in, but not so tight that circulation is cut off) I can sail and actually forget that it is even on. Most sailors in our club are either using this kind or are going to it shortly. They are real expensive, but the are worth it. Don't miss the wetsuit even a little bit. I will be sending it back to Kokatat to have them add the relief zipper over the winter and probably the thigh pocket. I bought it at REI. I suggested to my whole family that if they were getting a gift for me for christmas and/or the impending birthday, that they get gift cert. at REI. I actually bought the suit before thanksgiving last year and after Christmas and that-there-birthday, cashed in the gift certs on the suit. After the gift certs where credited and the rei member cash back, the suit cost me about $300. www.rei.comhttp://www.kokatat.com/ | | | Underthingies
[Re: Chris9]
#25684 11/03/03 01:14 PM 11/03/03 01:14 PM |
Posts: 5,590 Naples, FL | I agree that sailing is colder (or at least feels that way) than skiing.
One thing I learned in years of spring/cave diving is that there is no such thing as a gasket that won't leak. With the neck, it's due to the constant head turning. With the arms, it's the flexing of the forearm (when working sheets and tillers).
I prefer some sort of wicking undergarments, and then layer on the fleece before entering the drysuit. The wicking keeps the skin surface dry, and fleece can stay warm(er) even when wet. I think wool is the only other thing that claims this - and it's heavier.
I'll be picking up another dry-suit (Kokatat most likely) this year, and certainly will add the relief zipper. I'm still debating about the booties/no booties design...
AND DON'T FORGET A NICE HOOD. Gill has a nice one that's fleece. It's form fitting, fleece, and not as tight as a diving hood... Still experimenting with this though...
2,455
guests, and 294
