| Re: Blade F16
[Re: waterbug_wpb]
#257325 02/11/13 05:21 PM 02/11/13 05:21 PM |
Posts: 5,525 | Huh? In a wood laminate?
I see it as just the opposite.
Pete Pollard Blade 702
| | | Re: Blade F16
[Re: waterbug_wpb]
#257330 02/11/13 06:28 PM 02/11/13 06:28 PM |
Posts: 4,119 Northfield Mn | Am I missing something? We're talking smoothness as in like glass is smooth, sandpaper is not right?
| | | Re: Blade F16
[Re: waterbug_wpb]
#257331 02/11/13 07:16 PM 02/11/13 07:16 PM |
Posts: 5,525 | I think technique is the answer. Once the shape is fair at 220 grit then it is more a case of polishing.
| | | Re: Blade F16
[Re: waterbug_wpb]
#257357 02/12/13 12:45 PM 02/12/13 12:45 PM |
Posts: 5,525 | "...negative template gauge" as always check Gougeon Brothers, lots of stuff there.
I like to spray the work area with a light dusting of black lacquer, it shows the contours nicely with only a little sanding.
| | | Re: Blade F16
[Re: waterbug_wpb]
#257400 02/13/13 09:01 AM 02/13/13 09:01 AM |
Posts: 5,525 | I'm not likely to find out, surfaces with that level of finish are all but impossible to maintain.
I think primer sanded to 320, then painted followed by 600,800,1000 grit wet sanding plus polish. Even then, normal usage will mar that finish so it will be maintained with soap and water.
| | | Re: Blade F16
[Re: waterbug_wpb]
#257402 02/13/13 09:27 AM 02/13/13 09:27 AM |
Posts: 4,451 West coast of Norway | What Phill gave us was a good method to determine fairness by looking at the surface. I think it was a very good post in its clarity. With "perfect" fairness and surface finish the performance will still be good as the surface detoriates. If fairness and finish is inferior to begin with the performance will decrease faster while maintenance will be harder. I have a hard time trying to think of an easy to follow procedure to produce that level of fairness within a reasonable amount of time, by hand. CNC have its advantages. Next question could be what level of fairness and surface finish an "off the shelf" product has, and how they are produced? From "back then" I think Phills foils used a homebrew CNC mill to produce cores and moulds. He would finish the cores and moulds by some hand sanding. It has been some time since I read this so please dont quote me and take this as gospel. During the development of foiling Moths they hand built the foils to "good enough" performance to make them fly efficiently. It is surely still possible if one has the Zen  | | | Re: Blade F16
[Re: waterbug_wpb]
#257409 02/13/13 10:36 AM 02/13/13 10:36 AM |
Posts: 5,525 | Imo, the first place to start is selecting a foil shape. How does one go about choosing? Btw, all I've seen are simple line drawings are there more accurate descriptions somewhere?
| | | Re: Blade F16
[Re: waterbug_wpb]
#257425 02/13/13 03:02 PM 02/13/13 03:02 PM |
Posts: 5,525 | Thanks Phil. And I like your slogan, seems we're tuned into the same station.
| | | Re: Blade F16
[Re: waterbug_wpb]
#257428 02/13/13 03:30 PM 02/13/13 03:30 PM |
Posts: 5,525 | http://www.profili2.com/Looks a little complicated. All I have is a simple Epson printer. Has anyone used this with a home pc?
| | | Re: Blade F16
[Re: waterbug_wpb]
#257456 02/14/13 06:05 AM 02/14/13 06:05 AM |
Posts: 4,451 West coast of Norway | There is a trial version that can be downloaded and tested. The software itself is relatively lightweight in normal use. It runs fine on my 8 years old laptop. The software is complicated becouse the topic is non-trivial  (at least I find it a complicated subject when trying to do the math by hand) I liked the new functionality in Profili 2 Pro for saving 3D design files and even producing G-Code for male or female moulds. Take the file to a CNC shop and have the mould or core machined with very little overhead for them ($$$ to set up CAM and produce G-code) | | | Re: Blade F16
[Re: waterbug_wpb]
#257465 02/14/13 08:50 AM 02/14/13 08:50 AM |
Posts: 932 Solomon's Island, MD | Ok now I'm intrigued. When generating STL files from Profili 2 Pro, can you specify the wing washout at each span-wise station? I have non-linear washout requirements...
XFLR5 is free and worth every penny. Pete, this is a non-trivial subject matter; I have a 4 year degree in Aero Engineering and I still feel like a newbie when it comes to foil design, and an even lesser man when it comes to hydrofoils. Guys make entire careers out of this subject (Tom Speers for example, Boeing engineer and BMW Oracle foil specialist). My #1 suggestion is to call or email Matt and get a quote on the long boards, I think you'll be pleasantly surprised and quickly realize you can't do this for less. My #2 suggestion is start with a NACA 0010. My #3 suggestion is simply extend your existing Blade foils to the desired length.
Scorpion F18
| | | Re: Blade F16
[Re: waterbug_wpb]
#257469 02/14/13 08:59 AM 02/14/13 08:59 AM |
Posts: 5,525 | I'm fearful this will quickly become an exercise in futility for all the reasons you cite.
#3 has occurred to me and will be the first step in any case.
I'm beginning to suspect that using aero foils (if I may use that term)for hydro foils may be a mistake. I cited an article from Vesta sail rocket to that effect.
Bernard Smith may well have the last word in the matter.
| | | Re: Blade F16
[Re: waterbug_wpb]
#257489 02/14/13 09:54 AM 02/14/13 09:54 AM |
Posts: 5,525 | Well, I'm going to start with some cheap materials to make a model. Then whittle away to suite my fancy.
If I can make any sense out of the data I'll try to apply it.
541
guests, and 616
