| Rule change #257436 02/13/13 05:12 PM 02/13/13 05:12 PM |
Posts: 5,525 | How does one petition USS for a change in rules? Is it even possible?
The only serious incident I've been around since I bought the F16 involved a cavalier port tacker. That incident resulted in a destroyed boat and nearly a fist fight.
I suggest we remove ALL responsiblity to avoid collisions from starboard tack boats and see if the attitude of those port tackers remains unchanged. My guess is their judgement will be altered immediately.
Pete Pollard Blade 702
| | | Re: Rule change
[Re: pgp]
#257443 02/13/13 06:21 PM 02/13/13 06:21 PM |
Posts: 3,906 Clermont, FL, USA | How does one petition USS for a change in rules? Is it even possible?
I suggest we remove ALL responsiblity to avoid collisions from starboard tack boats and see if the attitude of those port tackers remains unchanged. My guess is their judgement will be altered immediately. Bad BAD idea. Back in the day it used to be that way or it seemed to be and I saw more than one the starboard tack boat take off the outboard of a port tack 4ksb and there were also some nasty t-bones that caused very serious damage and put people at risk. In no way is removing the no contact obligation a good idea. The rules are the way the are for a very good reason and they have the history to back them up! Saying protest and taking it to the room is MUCH better way to deal with the issue. For the record, if I have to wiggle to avoid you get a comment and a pass, if I have to do it again we go to the room, yes Beth I'm looking squarely at you. Ricky if it's you... yeah we're going to the room at the very least it will keep you from getting wrecked and being in a pissy mood the next day because you feel like crap.
| | | Re: Rule change
[Re: David Ingram]
#257444 02/13/13 06:47 PM 02/13/13 06:47 PM |
Posts: 1,246 Orlando, FL |
thanks for not calling out my skipper....she's new at sailing (but pretty) and I have a blind spot in my right peripheral vision. Stay clear of USA1231
USA 777
| | | Re: Rule change
[Re: pgp]
#257445 02/13/13 07:50 PM 02/13/13 07:50 PM |
Posts: 12,310 South Carolina | How does one petition USS for a change in rules? Is it even possible?
I suggest we remove ALL responsiblity to avoid collisions from starboard tack boats and see if the attitude of those port tackers remains unchanged. My guess is their judgement will be altered immediately. Pete, starboard will still be smiling all day long even if he has to slightly avoid the port boat. The port boat now has to do turns...which is fair punishment for misjudging the crossing situation - wouldn't you agree? At no time can you setup the rules to allow someone to hit and damage another boat. It leads to chaos. How many (rule knowledgeable) port tackers have you ever had to duck? I misjudge a port starboard cross ~perhaps~ once a year and it's not some big, huge, "HOLY ****!" moment. The other boat sees me coming and just has to make a tiny maneuver to avoid. I do between 12 and 18 regattas a year and it's a lot of crossing. I call foul on probably 5 to 10 people crossing me per year. It's part of racing. The rules work very well in this regard.
Jake Kohl | | | Re: Rule change
[Re: pgp]
#257462 02/14/13 08:38 AM 02/14/13 08:38 AM |
Posts: 5,525 | Not all discussions are about you. I'm still thinking of the boat that was destroyed, the sailor who left the sport, and the ill will that still exists as a result of a port/starboard foul. A foul that could have been avoided had the port tacker accepted the onus of the rule.
As a minimum, I believe the rule should be changed to an automatic dsq.
| | | Re: Rule change
[Re: pgp]
#257466 02/14/13 08:55 AM 02/14/13 08:55 AM |
Posts: 5,525 | The current rule has led to an unintended consequence: the willingness of port tackers to abandon the onus of the rule.
| | | Re: Rule change
[Re: tback]
#257468 02/14/13 08:58 AM 02/14/13 08:58 AM |
thanks for not calling out my skipper....she's new at sailing (but pretty) and I have a blind spot in my right peripheral vision. Stay clear of USA1231 The expiration date on the new sailor thing has got to be expired by now don't you think? How many years has she been pointing your boat in the right direction for you? I'll just be sure to yell louder and earlier and give you friendly advice like "you're not gonna make it" or "don't go in there" you know becuase I'm a giver and Chris is pretty.
| | | Re: Rule change
[Re: David Ingram]
#257472 02/14/13 09:06 AM 02/14/13 09:06 AM |
Posts: 5,525 |
thanks for not calling out my skipper....she's new at sailing (but pretty) and I have a blind spot in my right peripheral vision. Stay clear of USA1231 The expiration date on the new sailor thing has got to be expired by now don't you think? How many years has she been pointing your boat in the right direction for you? I'll just be sure to yell louder and earlier and give you friendly advice like "you're not gonna make it" or "don't go in there" you know becuase I'm a giver and Chris is pretty. Pretty is the controlling factor and extends newbie indefinitely.
| | | Re: Rule change
[Re: pgp]
#257473 02/14/13 09:08 AM 02/14/13 09:08 AM |
Posts: 3,906 Clermont, FL, USA | Not all discussions are about you. I'm still thinking of the boat that was destroyed, the sailor who left the sport, and the ill will that still exists as a result of a port/starboard foul. A foul that could have been avoided had the port tacker accepted the onus of the rule.
How was my post about me Pete? I sited examples I witnessed not something that was hearsay to make the point that the idea of removing the obligation to avoid contact is a bad idea. Keep us posted on the progress of your petition.
| | | Re: Rule change
[Re: David Ingram]
#257474 02/14/13 09:10 AM 02/14/13 09:10 AM |
Posts: 5,525 | It wasn't, my bad. I was refering to another post all together.
| | | Re: Rule change
[Re: orphan]
#257476 02/14/13 09:16 AM 02/14/13 09:16 AM |
Posts: 12,310 South Carolina | May be a change sould be an extra turn for a port/starboard infrigement. Something that would highly discourage risky behavior. The problem I have with risky crossings with cats are. 1. The closing speeds of the boats. 2. The acceleration that a cat has that a mono does not. This keeps the starboard boat from just turning down to duck. 3. The time/distance lost for the boat that has right away if they have to turn up hard or tack to avoid.
To me a simple turn does not make up for totally scewing up someone elses race. How often does this scenario you state happen? You guys are proposing fixes to a hypothetical problem that doesn't exist.
[Re: orphan]
#257484 02/14/13 09:42 AM 02/14/13 09:42 AM |
Posts: 12,310 South Carolina | I can name a few and one was damage to my boat. I can too - and I was on starboard. Totaled two boats. The guilt was properly assigned. The whole thing was regrettable but it worked out. I wouldn't think I, as starboard boat, should shed any hint of responsibility to avoid damage to boat, life, or limb just because of the angle of my boat.
#257485 02/14/13 09:47 AM 02/14/13 09:47 AM |
Posts: 3,906 Clermont, FL, USA | May be a change sould be an extra turn for a port/starboard infrigement. Something that would highly discourage risky behavior. The problem I have with risky crossings with cats are. 1. The closing speeds of the boats. 2. The acceleration that a cat has that a mono does not. This keeps the starboard boat from just turning down to duck. 3. The time/distance lost for the boat that has right away if they have to turn up hard or tack to avoid.
To me a simple turn does not make up for totally scewing up someone elses race. How often does this scenario you state happen? You guys are proposing fixes to a hypothetical problem that doesn't exist. Agree, you guys are trying to fix something that is not broken. Jeff when was the last time you were in 60+ boat fleet going around A mark or better yet the gate with a bunch of jacked up A type personalities? The rules in their current form work really well in my opinion. If you feel that storngly about it put it in your SI's, test the water.
| | | Re: Rule change
[Re: orphan]
#257495 02/14/13 10:36 AM 02/14/13 10:36 AM |
Posts: 5,525 | The real question should be "When was the last time there was unneeded boat damage or injury in those conditions that could/should have been avoided but were not because someone felt the right of way boat could/would just avoid contact if they misjudged?"
I am not proposing that we change the rules but something that would reduce the behavior.
Restore the historical rule, dsq.
| | | Re: Rule change
[Re: David Ingram]
#257496 02/14/13 10:41 AM 02/14/13 10:41 AM |
I'm not sure you are allowed to change (technically speaking) those rules in the SI's...per the rules.
Jake Kohl | | |
325
guests, and 44
