Re: Ultra Ever Dry? Effect on foils? [Re: Tony_F18] #263463
09/10/13 08:12 AM
09/10/13 08:12 AM
Dunedin Causeway, FL
David Parker Offline
If nothing to the coating,
HOW DOES THE COATING STICK TO SURFACES???
I often wonder how any non-stick is applied.
Re: Ultra Ever Dry? Effect on foils? [Re: bacho] #263488
09/10/13 02:20 PM
09/10/13 02:20 PM
Originally Posted by bacho
I was in Home Depot today and saw a product that looked very similar. It was rust oleum never-wet. Seemed to have many of the same demonstrations and a similar color. It was $18 for 2 spray cans.
Rustoleum bought the rights to the stuff.
Re: Ultra Ever Dry? Effect on foils? [Re: Jake] #263489
09/10/13 02:30 PM
09/10/13 02:30 PM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Interesting, I may pick a pack up to experiment with.
Re: Ultra Ever Dry? Effect on foils? [Re: David Parker] #263492
09/10/13 02:42 PM
09/10/13 02:42 PM
Most non-stick coatings (nylon, teflon, etc.) are a powder coating/heat treating process.
Re: Ultra Ever Dry? Effect on foils? [Re: Jake] #263530
09/10/13 04:21 PM
09/10/13 04:21 PM
if you apply a hydrophobic substance on foils, would that allow air to cause cavitation more quickly?
Re: Ultra Ever Dry? Effect on foils? [Re: waterbug_wpb] #263552
09/10/13 08:54 PM
09/10/13 08:54 PM
Air doesn't "cause" cavitation.
Cavitation results when the local pressure on the foil surface gets below the water vapor pressure and bubbles of water vapor form and explosively collapse - which is a real problem on propellers (the force can erode stainless steel). On catamaran foils - not so much, if ever.
What most people think of as "cavitation" is actually ventilation - the local foil pressure drops below the surface air pressure and draws air down from the free surface. And since air is 1000 times less dense than water, the foil loses it's lift.
A hydrophobic coating is probably going to promote the ventilation process, since the surface tension will create a natural crevice for the air to bleed down the foil. Wetting agents would have the opposite effect.
Re: Ultra Ever Dry? Effect on foils? [Re: mbounds] #263588
09/11/13 11:09 AM
09/11/13 11:09 AM
my apologies... you are correct. I was referring to ventilation rather than cavitation
Re: Ultra Ever Dry? Effect on foils? [Re: waterbug_wpb] #263589
09/11/13 11:11 AM
09/11/13 11:11 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
SCHOOL'D!
F18 USA 242
http://www.solarwind.solar
Re: Ultra Ever Dry? Effect on foils? [Re: David Ingram] #263591
09/11/13 11:16 AM
09/11/13 11:16 AM
oh, like that's never happened to me before? smile
Every day I walk through the door I get school'd about SOMETHING...
until my evil master plan gets off the ground, that is....
Re: Ultra Ever Dry? Effect on foils? [Re: waterbug_wpb] #263950
09/16/13 02:28 PM
09/16/13 02:28 PM
Will_R Offline
Will_R  Offline
Yup, you WANT water to stick to your hull and foils, but not just b/c of cavitation.
Re: Ultra Ever Dry? Effect on foils? [Re: Tony_F18] #283632
10/12/16 01:50 AM
10/12/16 01:50 AM
U
ULTRA EVER DRY Offline
U
0 registered members (), 3,753 guests, and 721 spiders.
