Ultra Ever Dry? Effect on foils? #257558
02/18/13 08:58 AM
02/18/13 08:58 AM
Tony_F18 Offline OP
Tony_F18  Offline OP
Anyone seen this viral video of this stuff that you treat a surface with make it hydrophobic?
What would the effect be when you would treat your foils with this, or even the whole boat?
Re: Ultra Ever Dry? Effect on foils? [Re: Tony_F18] #257559
02/18/13 09:04 AM
02/18/13 09:04 AM
Just saw that recently. Looks interesting, although I'd be curious how you would get it off of something...
The water behaves similar to a highly waxed or oiled surface, so I would suspect that it might be worth trying on a hull. Not sure about a foil (for fear of increased cavitation)?
Re: Ultra Ever Dry? Effect on foils? [Re: Tony_F18] #257561
02/18/13 09:41 AM
02/18/13 09:41 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Pretty cool but pricey. My concern would be being able to ever remove it for repairs.
Re: Ultra Ever Dry? Effect on foils? [Re: Tony_F18] #257564
02/18/13 10:17 AM
02/18/13 10:17 AM
Interesting. First use that comes to mind is an undercoating on vehicles.
Walls on a hog barn would be sweet for washing too.
I wonder how long it lasts? In a chute with cement? I'm guessing not very long.
Re: Ultra Ever Dry? Effect on foils? [Re: Tony_F18] #257565
02/18/13 10:21 AM
02/18/13 10:21 AM
pgp Offline
pgp  Offline
Wouldn't it disrupt laminar flow?
Pete Pollard
Blade 702
Re: Ultra Ever Dry? Effect on foils? [Re: Karl_Brogger] #257566
02/18/13 10:25 AM
02/18/13 10:25 AM
RickWhite Offline
RickWhite  Offline
Interesting uses for the stuff.., say sunglasses while sailing to keep from spotting. Gloves and spray suit to keep dry.
Since it started water beading immediately, from what I have heard, it may not be good for a hull. One theory is you don't want the water to bead.
Rick
Rick White
www.onlinemarinestore.com
Re: Ultra Ever Dry? Effect on foils? [Re: Tony_F18] #257567
02/18/13 10:37 AM
02/18/13 10:37 AM
Boston, Ma
Jeff.Dusek Offline
Jeff.Dusek  Offline
Boston, Ma
I could probably run a couple quick tests in the towing tank to see if it reduces drag on a hull. Not sure the difference in force will be of great enough magnitude to differentiate from the noise.
USF18 Eastern Area Rep
Nacra Infusion USA 753
Re: Ultra Ever Dry? Effect on foils? [Re: Tony_F18] #257568
02/18/13 11:10 AM
02/18/13 11:10 AM
It would probably make the boat float higher since it repels water! wink
Re: Ultra Ever Dry? Effect on foils? [Re: Jake] #257569
02/18/13 11:15 AM
02/18/13 11:15 AM
but seriously, though, I'm wondering about it's epoxy mold release properties and how smooth the surface is if sprayed.
Re: Ultra Ever Dry? Effect on foils? [Re: Tony_F18] #257573
02/18/13 01:32 PM
02/18/13 01:32 PM
I wonder if its slippery? It'd be kinda cool if your tramp and lines could stay dry.
Re: Ultra Ever Dry? Effect on foils? [Re: Tony_F18] #257575
02/18/13 02:31 PM
02/18/13 02:31 PM
Repels water? Perfect! Apply to sails, and away with workaday capsizes.
Re: Ultra Ever Dry? Effect on foils? [Re: Karl_Brogger] #257577
02/18/13 03:10 PM
02/18/13 03:10 PM
If that's your problem, Tad's got a number of solutions:
sunscreen
bananas
McLube Sailcoat
Re: Ultra Ever Dry? Effect on foils? [Re: Tony_F18] #257578
02/18/13 03:26 PM
02/18/13 03:26 PM
I meant without making the surfaces slippery. There has to be some advantage of not carrying around the extra weight of water for no reason.
Re: Ultra Ever Dry? Effect on foils? [Re: Karl_Brogger] #257579
02/18/13 04:21 PM
02/18/13 04:21 PM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
That was my thought, using it above the water line to shed water quickly.
Re: Ultra Ever Dry? Effect on foils? [Re: bacho] #257604
02/19/13 07:03 AM
02/19/13 07:03 AM
RickWhite Offline
RickWhite  Offline
another use would be on the sail where the telltales are located. When they get wet the often will stick and you are back to reading the luff like the old days of yore.
Rick White
Re: Ultra Ever Dry? Effect on foils? [Re: Tony_F18] #257605
02/19/13 08:23 AM
02/19/13 08:23 AM
Good call Rick. I wonder if Rain-X would even work for that?
Re: Ultra Ever Dry? Effect on foils? [Re: RickWhite] #257609
02/19/13 10:00 AM
02/19/13 10:00 AM
great point, although I wonder if both surfaces (sail and telltale) are coated, would the water bead up between the two and hold it together similar to what it does untreated?
Re: Ultra Ever Dry? Effect on foils? [Re: Tony_F18] #257612
02/19/13 12:16 PM
02/19/13 12:16 PM
Tony_F18 Offline OP
Tony_F18  Offline OP
Came across this article which talks about a potential performance gain of 8%, but by the looks of it not worth the hassle! (good read though)
http://forum.sailingscuttlebutt.com/DISCUSSION_C6/Dock_Talk_F5/Hull_coatings_P8414/
I think it could be useful to treat the tramp and snufferbag, also because it has UV protection built in.
Might even be useful to spray the inside of the hulls with as well smile
Re: Ultra Ever Dry? Effect on foils? [Re: Tony_F18] #257623
02/19/13 04:58 PM
02/19/13 04:58 PM
I got distracted... "Will the Riblets return?" sounded like barbeque....
Re: Ultra Ever Dry? Effect on foils? [Re: Tony_F18] #263460
09/10/13 07:44 AM
09/10/13 07:44 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
I was in Home Depot today and saw a product that looked very similar. It was rust oleum never-wet. Seemed to have many of the same demonstrations and a similar color. It was $18 for 2 spray cans.
0 registered members (), 19,133 guests, and 1,208 spiders.
Most Online22,490
13 hours ago
