A Cat Mainsheet System #258363
03/16/13 07:07 PM
03/16/13 07:07 PM
G
gdaddy182 Offline OP
G
I have recently purchased a home made A Cat in the Tampa area. Due to the homemade nature of this boat I have no idea how the mainsheet runs and how it is attached to the center of the trapoline. Any help would be great!
A Cat owner
Re: A Cat Mainsheet System [Re: gdaddy182] #258364
03/16/13 07:51 PM
03/16/13 07:51 PM
lesburn1 Offline
lesburn1  Offline
pictures would help
lesburn1.blogspot.com
A-Cat USA 49
18Sq 49
Re: A Cat Mainsheet System [Re: gdaddy182] #258365
03/16/13 08:56 PM
03/16/13 08:56 PM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Re: A Cat Mainsheet System [Re: gdaddy182] #258369
03/16/13 09:33 PM
03/16/13 09:33 PM
Sarasota Florida
Angelo190471 Offline
Sarasota Florida
He needs help with center sheeting
Re: A Cat Mainsheet System [Re: gdaddy182] #258375
03/17/13 08:29 AM
03/17/13 08:29 AM
Southern Ontario
fredsmith Offline
fredsmith  Offline
Southern Ontario
Go to Sailing Anarchy under Multihulls find the thread on A Class mainsheet systems lots of good info.
Re: A Cat Mainsheet System [Re: gdaddy182] #258396
03/18/13 07:16 AM
03/18/13 07:16 AM
M
MN3
MN3
M
Looks like you have an old Harken (or other) mainsheet blocks. Exactly how it is reveed depends on how many sheeves it has ... (rollers)... go to the Harken website and find an example of your blocks (5:1, 0r 6:1) and see how they are run.
I would suggest you get the seller to help you rig the boat 1 time if possible. Take notes and pictures.
Re: A Cat Mainsheet System [Re: gdaddy182] #258399
03/18/13 09:20 AM
03/18/13 09:20 AM
On a trampoline sheeted main, you normally have a purchase system at the back of the boom to the traveler (8:1, 9:1 or similar). The sheet line goes from one of the top blocks forward to a block in the middle of the boom. It then goes down to a block mounted on the trampoline and you sheet from there.
Personally, I don't like the trampoline mounted block. I think it makes the mainsheet spongy and reduces feedback. I had a trampoline mounted sheet but I removed the trampoline hardware and reconfigured the boom so the ratchet block was at the middle of the boom. I like it there much better.
Keep in mind, you need a substantial boom to support center sheeting.
0 registered members (), 454 guests, and 39 spiders.
