| Re: Spinnaker pole pulling out
[Re: ferminj]
#258408 03/18/13 02:32 PM 03/18/13 02:32 PM |
Posts: 5,590 Naples, FL | is there any pre-bend in the pole? This usually keeps it on the crossbeam pin.
Perhaps the bridle wires aren't angled enough to put aft pressure on the pole?
[Re: ferminj]
#258409 03/18/13 02:43 PM 03/18/13 02:43 PM |
Posts: 12,310 South Carolina | These are normally kept in place with pressure from the rigging and don't require a keeper of any kind - basically the angle of the end-pole bridles should keep plenty of pressure on the pole base / pin to keep it engaged. Can you show a picture of your setup?
Jake Kohl | | | Re: Spinnaker pole pulling out
[Re: ferminj]
#258416 03/18/13 05:27 PM 03/18/13 05:27 PM |
Posts: 12,310 South Carolina | That still doesn't completely explain it. If you have any tension on your end-pole bridles, the last direction it should move is away from the front beam.
[Re: ferminj]
#258419 03/18/13 09:52 PM 03/18/13 09:52 PM | Scarecrow
| Scarecrow
Unregistered | Do you have the bow stays going to the forward end of the pole? If they are and there is any tension at all the pole won't be able to move forward. | | | Re: Spinnaker pole pulling out
[Re: ferminj]
#258429 03/19/13 12:04 PM 03/19/13 12:04 PM |
Posts: 12,310 South Carolina | mmmmm...yeah...need pictures. We should be able to suggest an improvement if we can see it.
[Re: ferminj]
#258436 03/20/13 01:42 PM 03/20/13 01:42 PM |
Posts: 337 Arizona | If you have the standard end pole hoop that most run, then you should be running the spin pole bridle to the tip of the hoop.There should be a stainless steel double eye bolt at the tip of the hoop. The top eye is for the tack of the spin to attach to. The bottom eye is for the bridle. During setup,if you attach one of the bridles to this eye, the pole should already be under compression. You should have to push the hoop down and away from the first attached bridle to attach the second bridle line. Once both bridles are attached, you should be able to pick up the whole front of the boat by pushing up on the tip of the hoop. Your pole should have an arch of about 3 inches minimum. Your attachment at the forestays should not be providing upward pressure to induce bend in the pole, but should instead be holding the pole in place(column). The bend in the pole should be induced by the foreword pole bridle inducing compresson. The tip of your pole should be about 3' in front of your bows. +_. If properly set up, you could hang your boat in a tree by the tip of the pole to dry out after a day of sailing without it coming off that pin. Your mast rake will have no effect. Rig tension will have little effect.(only in that it will help hold the center of the spin pole in column).
Auscat MKV 444 A class NACRA I-20- 440/CATHATKA | | | Re: Spinnaker pole pulling out
[Re: AzCat]
#258437 03/20/13 02:04 PM 03/20/13 02:04 PM |
Posts: 12,310 South Carolina | If you have the standard end pole hoop that most run, then you should be running the spin pole bridle to the tip of the hoop.There should be a stainless steel double eye bolt at the tip of the hoop. The top eye is for the tack of the spin to attach to. The bottom eye is for the bridle. During setup,if you attach one of the bridles to this eye, the pole should already be under compression. You should have to push the hoop down and away from the first attached bridle to attach the second bridle line. Once both bridles are attached, you should be able to pick up the whole front of the boat by pushing up on the tip of the hoop. Your pole should have an arch of about 3 inches minimum. Your attachment at the forestays should not be providing upward pressure to induce bend in the pole, but should instead be holding the pole in place(column). The bend in the pole should be induced by the foreword pole bridle inducing compresson. The tip of your pole should be about 3' in front of your bows. +_. If properly set up, you could hang your boat in a tree by the tip of the pole to dry out after a day of sailing without it coming off that pin. Your mast rake will have no effect. Rig tension will have little effect.(only in that it will help hold the center of the spin pole in column). 3" of prebend is more than I remember with the older carbon end-pole hoop system...are you sure that's correct?
[Re: ferminj]
#258440 03/20/13 02:40 PM 03/20/13 02:40 PM |
Posts: 337 Arizona | I always had about 3"maybe a little less. Never had a problem. But that dosnt mean I wouldn't eventually have had a problem. Ferminj, I would go with whatever these guys have in mind, they are much more knowlagable than me. As for the rest, you get the idea I hope. Pics would help.
[Re: ferminj]
#258441 03/20/13 03:12 PM 03/20/13 03:12 PM |
Posts: 6,049 Sebring, Florida. | Has anyone mentioned the benefits of...
Duct Tape?
It's not just for sails and hulls anymore!
Blade F16 #777
[Re: ferminj]
#258442 03/20/13 04:22 PM 03/20/13 04:22 PM |
Posts: 4,119 Northfield Mn | You should send a few rolls over to Airbus, might improve things drastically
[Re: bacho]
#258445 03/20/13 05:42 PM 03/20/13 05:42 PM | MN3
| MN3
Unregistered | what happens if you demast? On my boat, the pole could pull out if the rig tension was "really" loose. He said it was loose in the original post, so just how loose is it? | | | Re: Spinnaker pole pulling out
[Re: ferminj]
#258455 03/21/13 06:57 AM 03/21/13 06:57 AM |
Joined: Jan 2007 Posts: 139 Hernando, Florida Mlcreek
Posts: 139 Hernando, Florida | Wow, 3" that costs me a repair job on the connection between tubes. I only slightly load it. No more than an inch.
Forrest I-20 USA 645
" There ain't enough rum in the drum!"
[Re: Mlcreek]
#258458 03/21/13 08:16 AM 03/21/13 08:16 AM |
Posts: 5,590 Naples, FL | There may have been a prior issue with that pole, causing the crack. But maybe the 3" prebend is a bit heavy.
I recall the aluminum spin poles bent like the golden arches..
[Re: waterbug_wpb]
#258460 03/21/13 09:17 AM 03/21/13 09:17 AM |
Posts: 1,304 Gulf Coast relocated from Cali... | I must admit that mine did have a bit of UV damage ALOT of abuse. Over 400 lbs crew weight, double trap spinn reaching on many occasions...something's gonna give. A stainless hose clamp saved the day.
Lee
[Re: waterbug_wpb]
#258461 03/21/13 09:44 AM 03/21/13 09:44 AM |
Posts: 12,310 South Carolina | There may have been a prior issue with that pole, causing the crack. But maybe the 3" prebend is a bit heavy.
I recall the aluminum spin poles bent like the golden arches.. True - the aluminum pole prebend is a totally different matter and it got to be more and more over time as the spinnaker luffs got longer.
Jake Kohl | | |
20,780
guests, and 1,475
