| Sail setting and sailing techniques #258903 04/12/13 03:39 AM 04/12/13 03:39 AM |
Joined: Jun 2012 Posts: 97 The Netherlands Arjan13 OP
Posts: 97 The Netherlands | This year we started with a new jib, and a new main on our Inter 18. We also installed a self tacking jib. We've sailed it twice now and our experiences are sometimes good, sometimes bad. We haven't changed anything else on the boat. We've put an Infusion sail on the Inter which means we had to make an adjustment to the boom. (is done before should work) We connected the main to the boom with a line (3 times double without tightening it to any point of the boom) When starting sailing we very fast learned that this wasn't working, and we had to fix it to the end of the boom so it wouldn't slide towards the mast. After we did that the boat behaved a lot better, but still we're experiencing the following: When sailing half wind, with a little bit rougher conditions 16-20 knots) it seems we cannot turn the power into speed. We feel there is more power than speed. The boat is "hiccing" a little with the lee bow in the water, and has more intention to dive than it's had ever before. It is less stable than before which causes maybe a little less conident behavior from our side. Even stranger is that it seems that going in 1 direction we have lesser problems, than going 180dgrs in the other direction) We're trying to find out the possible reasons, maybe someone here has the right idea? We are thinking about the following variables: 1) Can anybody give me an indication on the tension of the line which connects the sail to the end of the boom with the Nacra Infusion original system? Is this line only keeping the sail at its place, or is it putting force on it? 2) We sailed the jib about 10 cm from the end of the rail with about as much tension on the sheet as possible. Is this right? 3) The downhaul was on a very reasonable tension 4) Mast rotating system was also on a very reasanable tension 5) Due to this "setting problems" the helmsman stayed on board (not in the wire) causing that I couldn't put to many force on the sheet. The sail was twisting more open as you looked up. Could this be a reason? Can it be that if we go in the wire with two persons and putting more force on the sheet (so the sail will flatten out)that it will be more stable? 6) The new sail has another shape (larger area in the top) Has this got to do anything with it? We also have some on film. Via this link you can see the boats drive to incline diagonal over the lee bow. (please do not mind the rest of the sailing, a lot of uncertainty is causing bad behaviour)First you see the first direction, afterwards the other direction (with the problems) http://youtu.be/NP9knLteLkEDo not mention the outfit (it's still cold in Holland!) Every help would be appreciated! | | | Re: Sail setting and sailing techniques
[Re: Arjan13]
#258904 04/12/13 05:29 AM 04/12/13 05:29 AM |
Joined: Jun 2009 Posts: 524 Petten Netherlands northsea junkie
Posts: 524 Petten Netherlands | Good to see you out there in the cold, Arjan.
What I see is that on the problem-direction the mainsail is opening more in the top (so pressing the bow more downwards). It also looks that in that direction the mast rotation is more then on the other side. (But I don't know if there is a setting-difference on the Inter for both sides.)
Anyway it is a clear and visible problem you have there.
ronald RAIDER-15 (homebuilt)
[Re: northsea junkie]
#258905 04/12/13 07:42 AM 04/12/13 07:42 AM |
Posts: 12,310 South Carolina | the video is good. A couple of things:
1) it does not look like you have enough tension on the forestay and the jib luff. Rigging tension looks soft but this could be because you are not sheeting hard enough on the main sail.
2) you are not sheeting hard enough on the main sail - not close...not by a kilometer. I normally control the mainsheet while driving and with a 10:1 sheet purchase in that kind of breeze, I have two wraps on my hand as I bend my legs and I put the finishing touch on the mainsheet tension by extending my legs with everything I have. crank it. The leech of the mainsail should be very tight and you control the twist with the downhaul.
What is happening with the loose mainsheet is that as the boat pumps the rig as you go over waves, different areas of the sail are picking up slight shifts in the wind as the sail "tomahawks". With that much twist, the top of the main usually starts to get more power as the boat slows down into the next wave - this causes the driving force to climb higher up the mast which turns into more pressure on the bows and drives them deeper. The F18 has a lot of sail up high - you need to contain it in breeze and waves.
Jake Kohl | | | Re: Sail setting and sailing techniques
[Re: Arjan13]
#258908 04/12/13 08:52 AM 04/12/13 08:52 AM |
Posts: 6,049 Sebring, Florida. | Also...since you are now using a new jib and a new self tacker, make sure there is enough of a slot between the jib leach and mast/backside of the main. If the jib is in tight but the main is out, you will choke off the flow from the jib to the backside of the main.
If the slot is closed off, or too small, this will cause the feeling that you are overpowered, but not going fast, as you described above.
If you are not sheeting the main tight enough, as Jake said, that will close off the jib/main slot as well.
The quick and easy fix is to ease the jib a little, and sheet in the main, that will open the slot. See if that helps with the speed/overpowered feeling.
Blade F16 #777
[Re: Arjan13]
#258909 04/12/13 08:57 AM 04/12/13 08:57 AM |
Posts: 932 Solomon's Island, MD | Arjan I concur with Jake and Jeff's suggestions above.
A few things:
Mast rake depends on crew weight. In those conditions if you attach a line to the trap wire, take the wire forward to the bridle attachment point on the hull, mark the line, then take it aft to the rear of the hull you should be about half way down the transom. Further forward if you're two big guys, i.e the upper rudder pintail.
Tension your rig by putting one guy on the trap wire, yanking hard and moving the sidestays. Both stays should be even at the end.
Which boom system are you using? Round or square? On my Infusion the outhaul places the clew of the main about 2" from the stern end of the boom. I basically leave it tight unless in light air. The main sheet connects to a strap that runs through the sail and around the boom. Basically you are putting 10:1 sheet loads directly on the leach of the sail. Like Jake mentioned, sheet in, get both guys on the wire and start trucking.
Let the jib traveler all the way out in heavy air. It's experimental on the crossover for traveling in some.
You probably need more downhaul than you think. Hard to say with a loose mainsheet. Sheet hard, take excess power out with the downhaul then start playing main in the puffs. I let the crew have the main upwind in breeze if they are responsible.
Scorpion F18
[Re: Arjan13]
#258910 04/12/13 09:05 AM 04/12/13 09:05 AM |
Posts: 932 Solomon's Island, MD | I'll point out again you need to check your side stays are equal. That would explain the more bagged out jib on the opposite tack, i.e you've lost forestay tension because your port side stay is looser than your starboard side stay.
Also, may need more jib downhaul but it's likely forestay sag in the video.
Scorpion F18
[Re: samc99us]
#258911 04/12/13 10:24 AM 04/12/13 10:24 AM |
Posts: 12,310 South Carolina | Arjan I concur with Jake and Jeff's suggestions above.
A few things:
You probably need more downhaul than you think. Hard to say with a loose mainsheet. Sheet hard, take excess power out with the downhaul then start playing main in the puffs. I let the crew have the main upwind in breeze if they are responsible. I'm pretty sure that's an inter18
[Re: Arjan13]
#258914 04/12/13 01:39 PM 04/12/13 01:39 PM |
Posts: 932 Solomon's Island, MD | An issue may be they are using the main sheet with the fixed points on the inter18 boom. it may be too long/too short to properly apply main sheet tension to the leech of the new F18 sail. The main should be attached to the loop they are using to attach the clew to the boom.
Scorpion F18
[Re: samc99us]
#258932 04/13/13 01:16 PM 04/13/13 01:16 PM |
Posts: 5,590 Naples, FL | are they beam or broad reaching? with the main that bagged out, you'd think it's about time to hoist the spin?
Rig tension does look a little slack...
Is your traveler centered? Can't tell because the jib is blocking the view. It may help to reduce the draft of the mainsail by sheeting in (a LOT more) and moving the traveler to leeward a bit more.
If you're getting overpowered, you can drop the traveler some as well (when you're beam reaching)
[Re: Arjan13]
#258936 04/13/13 05:12 PM 04/13/13 05:12 PM | Scarecrow
| Scarecrow
Unregistered | You need to work slowly and sort out one or two things at a time. Start with rig tension. After checking the stays are equal tighten the rig until it becomes hard to rotate (by hand) the mast to 95 degrees
Next is the outhaul on the boom.
Point your mast spanner (rotator) at the side stays and pull your downhaul, traveller and mainsheet on as hard as you can. Now pull the outhaul on as hard as you can. Tie it off there and until your on top of everything else just leave it.
Jib traveller takes a bit of playing. Most people sent it for upwind andleave i there (kite is more important down wind) and on modern courses we don't do much reaching. The basic setting is achieved by cranking main sheet, traveller and jib sheet and the adjusting the jib traveller so that when you pinch up the windward wind indicators on the jib lift just before the ones on the main.
Reaching on and F18 is quite difficult as the boats and sails have evolved away from that point of sail. You need to really drive the boat. If it is being flightly pull the centreboards up a bit. You also need to be be able to properly control the main without moving too much sheet. This is achieved by using the traveller.as a gear stick and the main as an accelerator. When viewed from behind your main sheet should rarely be more than 20 degrees of vertical.
[Re: ]
#258943 04/13/13 11:25 PM 04/13/13 11:25 PM |
Posts: 2,844 42.904444 N; 88.008586 W | You need to work slowly and sort out one or two things at a time. Start with rig tension. After checking the stays are equal tighten the rig until it becomes hard to rotate (by hand) the mast to 95 degrees
Nothing about 'playing' the main downhaul, for the crew, as in the puffs?
F-18 Infusion #626- SOLD it!
[Re: Todd_Sails]
#258946 04/14/13 04:10 AM 04/14/13 04:10 AM | Scarecrow
| Scarecrow
Nothing about 'playing' the main downhaul, for the crew, as in the puffs? Worrying about basic setup at this stage, not techniques. | | | Re: Sail setting and sailing techniques
[Re: Arjan13]
#259388 05/07/13 09:27 AM 05/07/13 09:27 AM |
Posts: 524 Petten Netherlands | Arjan, though not being the expert on trimming, I remember me a case in which I had a sail which did't fit with the mast. That looks a bit on your situation. Sailing with two men in 20 kts, should be no problem. Also not in half-wind (the official English is "reaching", but here on this forum they like to speak of jib-reaching or beam-reaching).
It seems to me that your sail cannot loose all the wind in it, which results in an (inefficient) force forwarddown. In fact it's a twist-problem.
So, take your sail one time on the ground with you holding the cunningham hole and your mate holding the top of the sail and stretch out (but not so far that the sail is curling upwards). Then you take a rope and make a straight line also from the top to the cunningham. You can now see the pre-cutted luffcurve of the sail and also measure how much it is on the deepest point.
If this curve is too deep for your mast, you have a problem.
So, in that case I would certainly give the mast much more pre-bent with the spreaders. (For your cat I don't know the appropriate figures for the pre-bent and the prescribed luff bent in the sail.
Last but not least I would fix the mast-rotator to zero.
16,935
guests, and 1,240
