| Chicken Lines #259440 05/09/13 06:57 AM 05/09/13 06:57 AM |
Joined: Jan 2007 Posts: 139 Hernando, Florida Mlcreek OP
Posts: 139 Hernando, Florida | Hey all,
I read reference about chicken lines in heavy weather and seas. Having lost two crews in high winds, I'm thinking I need to tie them to the boat. Would you all be so kind as to comment about yours. What size line, how long, when you would use it, and what do you connect to on both boat and person? Thanks
Forrest I-20 USA 645
" There ain't enough rum in the drum!"
| | | Re: Chicken Lines
[Re: Mlcreek]
#259451 05/09/13 08:21 AM 05/09/13 08:21 AM |
Posts: 12,310 South Carolina | I don't have the time at the moment to put a sketch together but I've used two different systems.
System 1) (simple - crew only). I have a bunji that is doubled up inside the beam (little blocks tied to the castings on either side that the bunji goes through). On the bitter ends of the bunji there is another small micro block. I have a 3/16" line that goes through the blocks on the ends of the bunji and terminates on the rear beam. On the end of that line is a stainless steel hook and a v-jam cleat. The bunji pulls this line, doubled over, into the rear beam and pulls the v-jam cleat/hook up tight to the hole in the beam end cap. When the crew is on the wire he can bend down, grab the hook, extend it and hook it somewhere onto his harness. This won't keep him at the very back of the boat but it will keep him from going much forward of the beam if we stuff.
System 2) crew and skipper (but more difficult to use at deep wind angles). The other system terminated similarly in the rear beam but the line carried forward and tied solid to the front beam. Both crew and skipper have cam cleats on their harnesses (I had plates welded to the spreader bars for the cleats).When on the wire, you both step under the chicken line (which is pulled tight from the rear beam to the front beam) and drop it into one of the cam cleats on your harness. As skipper, I usually depended on my crew to hook me into this system. The nice thing about it is that if push really came to shove, the cam cleats would let go if you put them at a really bad angle so you would be less likely to be dangling from the top of a capsized boat.
Jake Kohl | | | Re: Chicken Lines
#259466 05/09/13 02:53 PM 05/09/13 02:53 PM |
Joined: Sep 2003 Posts: 97 Williamston, sc h18catsailor
Posts: 97 Williamston, sc | System 2) crew and skipper (but more difficult to use at deep wind angles). The other system terminated similarly in the rear beam but the line carried forward and tied solid to the front beam. Both crew and skipper have cam cleats on their harnesses (I had plates welded to the spreader bars for the cleats).When on the wire, you both step under the chicken line (which is pulled tight from the rear beam to the front beam) and drop it into one of the cam cleats on your harness. As skipper, I usually depended on my crew to hook me into this system. The nice thing about it is that if push really came to shove, the cam cleats would let go if you put them at a really bad angle so you would be less likely to be dangling from the top of a capsized boat. [/quote]
This is the system Jake set us up with at the Tybee and it worked GREAT!!
David Strickland Hobie 18 HEAVY air crew on a J22
| | | Re: Chicken Lines
[Re: Mlcreek]
#259471 05/09/13 03:26 PM 05/09/13 03:26 PM |
Joined: Jun 2009 Posts: 524 Petten Netherlands northsea junkie
Posts: 524 Petten Netherlands | I have an extra bar going from transom to transom of each hull, but instead of that you can also use a fixed line instead. In the middle of that bar there is a ring which is conected to each end of the bar with a bungee cord. So the ring can move freely over the bar but wll always return in the middle. My safely-line is a standard leash line from a kite-equipment (infact it is a so-called handlepass leash, because they are longer: 2 meter). So the leash is connected to the ring and the other end to my harness, both with caribiner hooks. The trick of that leash is that there is a safety release on it. So I can always detach myself, also under load!!!!!!!
The line goes over the tillerbar but under the joystick.
ronald RAIDER-15 (homebuilt)
2,646
guests, and 512
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online7,715 9 hours ago | | |
