Carbon Trailing Edge Repairs #260013
06/04/13 03:14 PM
06/04/13 03:14 PM
SE MI / NE IN
rehmbo Offline OP
rehmbo  Offline OP
SE MI / NE IN
Forgive me if this topic has already been covered. Did a couple of searches and didn't find anything substantive.
What is the material of choice and best technique to manage the near constant chips and chunks that my trunks are eating out of the @#&^%! gybing boards? Any hints on how to minimize the damage in the first place?
Not knowing any better way, my method for now is with a clear 2-part hobby epoxy with some graphite mixed in for color. Using some 12"x3" and 16"x3" lexan strips and wax paper on top/bottom with clamps to mold it to shape while it cures. Then I go back and trim the flash, sand, polish, etc.
Only concern I have now is the gelcoat over epoxy issue if I ever decide they need it. Although it would be easy enough to remove the epoxy if I was going for a full-blown refurbish- they're pretty new so that's a long way off (I hope).
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Carbon Trailing Edge Repairs [Re: rehmbo] #260014
06/04/13 03:27 PM
06/04/13 03:27 PM
I think most have gone away from the gybing boards by fairing in the daggerboard trunks.
You've pretty much got the repair down.
Don't worry about the gelcoat over epoxy - it's not really an issue in small patches like that. Just rough sand (150 grit) the epoxy patches before gelcoating so it can get a decent mechanical grip (same goes for the rest of the recoat). Some of that gelcoat over epoxy is blown out of proportion based on the fact that there will not be a chemical bond between gelcoat and epoxy (which is true)...but you're not going to get a chemical bond between cured 5 year old gelcoat and new gelcoat either.
Re: Carbon Trailing Edge Repairs [Re: rehmbo] #260019
06/04/13 05:46 PM
06/04/13 05:46 PM
Check the bottom of your trunks. Where the trailing edge touches the trunk that needs to be a nice smooth surface. Sometimes when the boats are new, whatever glue they use when they are putting everything together isn't properly removed. I didn't check this on a new Viper I had, and it mauled a set of boards in basically a day. I'm sure it's something that Dan would've taken care of, but easier things have been missed, or the board has worn a notch into the glass.
A small file is all you need to fix it. If the board has worn into the hull, just fill it in with epoxy, and file that to shape.
Re: Carbon Trailing Edge Repairs [Re: rehmbo] #260034
06/05/13 01:30 PM
06/05/13 01:30 PM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
That's essentially what I'm doing. I did it with carbon laminate and that broke out quickly, simply not enough material. I'll probably add some milled fibers along with graphite and do a straight 2-part epoxy, either Resin Research or Pro-Set. The hobby grade epoxies aren't great and resin research is very inexpensive per quart (though it takes a week or 2 to ship usually).
My boards have gelcoat all the way to the TE, but I'm not going for looks more for hydrodynamics. Might suggest spraying a clear lacquer post repair, just to keep the epoxy from yellowing.
Any tips for fixing dinged tips? Looks like a lot of epoxy+milled fibers in that area and much more difficult to shape. It'd be easy if Nacra just sent me the molds...
Scorpion F18
Re: Carbon Trailing Edge Repairs [Re: rehmbo] #260117
06/07/13 09:50 AM
06/07/13 09:50 AM
Houston
carlbohannon Offline
Houston
When you just fill in a small gap on the edge, there is not enough contact area between the repair and the board. It is not as strong as the original so it is going to pop out or crush when it gets hit. If you want to do this I suggest Loctite(Hysol) or 3M premixed epoxy (http://www.scottsales.com/structural_adhesives.html, Look at the table or call the company to see which one is best) This is a lot easier than mixing it yourself. You can also try filled poly carbonate or urethane. They are more flexible and deform rather than pop out or crush.
The ugly truth is if you want a small repair like this to hold up, you have to use techniques you would use for a big hole in your hull. Grind a ~8 to 1 taper back from the damage (This area is so thin, you can probably only taper one side) Clean the area thoroughly with isopropyl alcohol. Apply a thin coat of epoxy directly to the repair. When that epoxy starts to kick, apply fabric or fibers with more epoxy to fill the damage and the taper(You want 70% fiber/30% epoxy by volume). Then use peel ply and plastic film and apply pressure (vacuum bag preferably or wood blocks and clamps). When it hardens, sand it smooth and apply a thin coat of epoxy to fill in any hole/gaps/etc. Finally the final sanding.
If you have room, bonding some very very thin nylon webbing to the back of the dagger board trunk with 3M 5200, helps a lot.
Re: Carbon Trailing Edge Repairs [Re: carlbohannon] #260118
06/07/13 10:08 AM
06/07/13 10:08 AM
SE MI / NE IN
rehmbo Offline OP
rehmbo  Offline OP
SE MI / NE IN
Totally agree on this point. Just did some 2nd-gen repairs with better tapering. Hope they hold up better.
Will check out the materials. Really appreciate the detailed procedure. Will also check on the room at the back of the trunk. Putting the boat together tonight for some sailing over the weekend!
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Carbon Trailing Edge Repairs [Re: rehmbo] #260124
06/07/13 11:00 AM
06/07/13 11:00 AM
samc99us Offline
samc99us  Offline
Thank you for the details! Looking at that list we should be using Hysol 9433 me thinks, but that isn't very available, at least I have to go through a sales rep to get it.
I'll try a higher taper ratio using my "normal" methods, this time I'll stick the board in a vacuum bag.
Scorpion F18
0 registered members (), 331 guests, and 55 spiders.
