| Twisty spin halyard #261217 07/11/13 01:11 PM 07/11/13 01:11 PM |
Posts: 1,152 tampa, fl | The last couple of spin halyards I used have had a nasty habit of twisting up throughout a day of racing to the point that there are issues with the halyard running through some of the micro blocks. I can only remedy this (on the beach) by untying the snuffer end of the kite, unrigging the halyard back to the mast and manually untwisting the halyard before re-rigging. Any thoughts on causes/solutions? It is a real pain in the a$$! I am using a tapered halyard. Please don't ask me what name the line is, I am really bad about that, but it has happened with the last couple of halyards that were all made with different types of line.
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Twisty spin halyard
[Re: dr5e14w]
#261251 07/12/13 07:40 AM 07/12/13 07:40 AM |
Posts: 1,152 tampa, fl | No, there is only cover and core for a couple of feet where the line is cleated when the spin is hoisted.
[Re: ksurfer2]
#261253 07/12/13 08:33 AM 07/12/13 08:33 AM |
Posts: 5,590 Naples, FL | Please don't ask me what name the line is, Let me guess.... it's the round-kind...
[Re: ksurfer2]
#261260 07/12/13 09:17 AM 07/12/13 09:17 AM |
Posts: 932 Solomon's Island, MD | Lol. We've been having this issue with the untapered cored halyard that comes stock with the non-race Infusion. I can't find the line type either but it is too stiff. Part of my reason for going to a tapered halyard is to avoid this issue. We'll be doing a double taper with Amsteel Blue on both ends and FSE Racing Sheet in the middle. APS had everything on the sale rack so mega score.
Scorpion F18
[Re: ksurfer2]
#261266 07/12/13 09:53 AM 07/12/13 09:53 AM |
Posts: 3,293 Long Beach, California | Karl, it may be the way you're storing the line, espesh if it gets coiled up and put away wet. That might explain the issue's persistence across different lines. Try putting it in a line bag (mesh sports bag) and running it through the wash once. Then hang it to dry between two trees or something.
[Re: ksurfer2]
#261270 07/12/13 10:48 AM 07/12/13 10:48 AM |
Posts: 172 Anacortes | Might be rubbing against the side plate of one of the blocks in the system, like the block at the masthead. If it rubs on the side plate that can force the braid of the line to distort over time and cause twisting. If its happened with multiple halyards this might be the issue. Harken micro at the masthead? Try a block with plastic side plates instead, the micro has relatively sharp stainless edges that can do this. Might also not have enough travel on the athwartship strop at the masthead which would cause rubbing on the side plate.
Anacortes Rigging.com Rigging and Yacht Services
[Re: ksurfer2]
#261276 07/12/13 12:10 PM 07/12/13 12:10 PM |
Posts: 186 | Karl, I'm sorry to say but it's gotta be how your rigging it. As Ian said maybe it's rubbing on the sidewalls of a block. But like I said, we have used 4 spin halyards out of excel matrix with no problem and have other guys that have used the same. I've also used the fse racing sheet and will probably be going back to that when it's time for a new one. When you figure it out I'll make a new halyard for you since you cut up the other one I made. -Todd | | |
464
guests, and 95
Mod | | Forums26 Topics22,404 Posts267,055 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
