mainsheet line? #261348
07/14/13 08:29 PM
07/14/13 08:29 PM
brokenrinker Offline OP
I just put a Sta-set 1/2 mainsheet on my hobie21. I'm not happy with it. It wont run through the blocks easily and it's slippery. It's the same diameter athe old line.Any suggestions? What's a good choice for amainsheet?
Re: mainsheet line? [Re: brokenrinker] #261349
07/14/13 08:45 PM
07/14/13 08:45 PM
New England Ropes - Salsa brand.
Re: mainsheet line? [Re: brokenrinker] #261350
07/14/13 08:50 PM
07/14/13 08:50 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Re: mainsheet line? [Re: brokenrinker] #261352
07/14/13 09:06 PM
07/14/13 09:06 PM
Arizona
AzCat Offline
AzCat  Offline
Arizona
Years ago when I first got I to the sport, I tried the stay set, only because it was readily available at the blue box. Stayset has no redeeming qualities. none. I didn't know what I was missing till I got a new boat and tried the Robline Racing Sheet. Awesome line! Great in the cleats, great In the hand, doesn't t knot up on the tramp, runs around the blocks straight, wears great. Get it, use it, don't look back!
Auscat MKV 444 A class
NACRA I-20- 440/CATHATKA
Re: mainsheet line? [Re: brokenrinker] #261353
07/14/13 09:57 PM
07/14/13 09:57 PM
It looks like the largest dia Robline comes in is 8mm. Is that large enough for gripping comfortably?
Re: mainsheet line? [Re: brokenrinker] #261355
07/15/13 06:50 AM
07/15/13 06:50 AM
catman Offline
catman  Offline
!/2" is too big. 3/8 or 9mm is right. All line is going to be slippery out of the box. Salsa is good for the money but you really can't use it anywhere else like for the jib because it's mostly white with a different color tracer. The Robline racing sheet does come in 9mm. I like the Maffioli Swiftcord. The colors are nicer and it's a bit cheaper than Racing Sheet.
Re: mainsheet line? [Re: brokenrinker] #261356
07/15/13 07:28 AM
07/15/13 07:28 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
I have a big 1/2" salsa spin sheet. I really like it.
Re: mainsheet line? [Re: brokenrinker] #261358
07/15/13 08:01 AM
07/15/13 08:01 AM
M
MN3
MN3
M
robline racing sheet - 8 mm
want to get fancy ... taper the end
Re: mainsheet line? [Re: brokenrinker] #261376
07/15/13 03:27 PM
07/15/13 03:27 PM
ccat Offline
ccat  Offline
We use this 7/16 in a ratchamatic 8:1 0n a C Class, nice on the hands and runs out instantly;
http://www.shopsoundboatworks.com/maswli.html
Re: mainsheet line? [Re: ccat] #261377
07/15/13 03:54 PM
07/15/13 03:54 PM
RickWhite Offline
RickWhite  Offline
Salsa is awesome. It is Dyneema, non stretch, with no core, thereby allowing it run quickly through blocks, easy on the hands, won't kink or knot and is the least expensive sheet line on the market.
Here is the Link:
http://www.catsailor.com/store/pc/N...6mm-8mm-9-5mm-Red-or-Green-243p15783.htm
Rick White
www.onlinemarinestore.com
Re: mainsheet line? [Re: brokenrinker] #261383
07/15/13 05:16 PM
07/15/13 05:16 PM
It appears that the committee is pretty equally divided between Salsa and Robline with one strong argument for Maswli. While I'm deciding can I interest anyone in about 65ft of red sta-set?
Re: mainsheet line? [Re: brokenrinker] #261396
07/16/13 09:15 AM
07/16/13 09:15 AM
M
MN3
MN3
M
I have both robline and salsa on my cat
robline feels softer and nicer, salsa has a slight plastic feel to it.
the main drawback to salsa (as Catman mentioned) is it's colors are limited and you don't want multiple lines onboard with the same color/ look (see images for the 2 choices) ... to easy to confuse them
Re: mainsheet line? [Re: brokenrinker] #261397
07/16/13 09:18 AM
07/16/13 09:18 AM
Did you throw it in the washing machine with some detergent? I had some slippery line that got a little better when I washed it..
Re: mainsheet line? [Re: brokenrinker] #261399
07/16/13 09:36 AM
07/16/13 09:36 AM
Hillsborough, NC USA
I
Isotope235 Offline
Isotope235  Offline
I
I use 5/16" Samson Trophy Braid for my mainsheet. It's an inexpensive polyester double-braid with a fuzzy cover that is soft and easy to grip. It's stretchier than the dyneema blend lines, but I don't think that matters. A hand-tensioned sheet simply doesn't take enough load to show significant elastic elongation.
The biggest downside to Trophy Braid is that (being polyester) it absorbs water. So, when fully wet, it might add (probably less than) a pound to the weight of the boat. For me, that's not a big deal.
Re: mainsheet line? [Re: Isotope235] #261401
07/16/13 10:01 AM
07/16/13 10:01 AM
catman Offline
catman  Offline
The weight of Double Poly also makes it easier for my crew to throw the line out of the cleat. Less messed up tacks.
Re: mainsheet line? [Re: brokenrinker] #261402
07/16/13 10:10 AM
07/16/13 10:10 AM
Thanks for the tip on the machine washing. The thing is, the lack of grip is one problem the unwillingness of the line to run through blocks is probably a bigger deal. Capsizing a H21 is a pain. The enthusiasm for Salsa is intriguing but frankly I'm not feeling real warm and fuzzy towards New England Rope right now since that's who makes my Sta-set. 65 ft of line represents a significant amount for my meager sailing budget. I just can't afford to experiment too much with different line.
Re: mainsheet line? [Re: brokenrinker] #261451
07/17/13 09:41 AM
07/17/13 09:41 AM
Anacortes
Sloansailing Offline
Anacortes
Well Robline and NER are owned by the same company so feel warm and fuzzy about whoever you want! Sta Set is fine for what it is, which is a cheap double braid. Use Racing Sheet PRO and taper it where it runs through the blocks, you will be very satisfied. Or, if you can't splice, call a rigger who can do it for you smile
Anacortes Rigging.com
Rigging and Yacht Services
Re: mainsheet line? [Re: Sloansailing] #261454
07/17/13 10:24 AM
07/17/13 10:24 AM
RickWhite Offline
RickWhite  Offline
Salsa really is the answer and NE makes a lot of variety of line for all purposes. However,
Here is the link for Robline sheet
http://www.catsailor.com/store/pc/s...amp;pageStyle=H&incSale=&IDSale=
Rick White
0 registered members (), 2,833 guests, and 296 spiders.
