Page 47 of 202 1 2 45 46 47 48 49 201 202
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261534
07/21/13 07:54 PM
07/21/13 07:54 PM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Great start. LR has shown improvement. . . right up to the boundary penalty.
Here is the full replay and the edit of the jib incident.
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261536
07/21/13 10:13 PM
07/21/13 10:13 PM
brucat Offline
brucat  Offline
ETNZ impresses me more every time they hit the water. Sure hope Oracle can answer. These guys are ridiculously fast...
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261538
07/22/13 06:35 AM
07/22/13 06:35 AM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
check out the high tech hobie bob.
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: Dlennard] #261539
07/22/13 06:45 AM
07/22/13 06:45 AM
Originally Posted by Dlennard
I think the chase boat was keeping Prada from running over the sail, which would not have been good for Prada. When you sail around a capsized boat or a boat stuck on the mark do you protest them for being in the way?
Good point...but they're not throwing stuff in the water that I have to dodge as we proceed up the course. Consider if LR had been closer and they couldn't avoid hitting the jib and got fouled up in it. What then?
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261540
07/22/13 07:05 AM
07/22/13 07:05 AM
brucat Offline
brucat  Offline
Of course there are rules to cover this. LR would have wasted no time protesting had there been a foul.
It would have been nice if the announcers walked us through the rules that applied. If they did, I missed it.
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261541
07/22/13 08:20 AM
07/22/13 08:20 AM
That'll be useful when the top half of the wing breaks off. I can't see it doing much more than that.
Re: AC72 Oracle Team USA Spaceship has landed [Re: brucat] #261542
07/22/13 08:37 AM
07/22/13 08:37 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
So now dropping stuff in the water is actually a valid strategy.
All that teams need to do is get a roll of cellophane, and drop it to leward to try and foul the opposing boat?
Isn't there a rule that says that you cannot discharge anything off of your boat according to the RRS? They had to stop using rubber bands on spinnakers because of it.
Re: AC72 Oracle Team USA Spaceship has landed [Re: ThunderMuffin] #261543
07/22/13 08:45 AM
07/22/13 08:45 AM
I know in the 45s you could drop a crew member and not have to come back. We've seen the old AC monohulls drop kites and stuff off the boat with no penalty. I would presume the rules allow you to drop stuff on the 72s (clearly since NZ received no penalty) but I would hope it limits the James Bond devices. ;-)
Re: AC72 Oracle Team USA Spaceship has landed [Re: Jake] #261547
07/22/13 09:24 AM
07/22/13 09:24 AM
Hence the new term "drop it like a bad jib".
Maybe Snoop Dog will re-make his song for that....
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261550
07/22/13 09:34 AM
07/22/13 09:34 AM
brucat Offline
brucat  Offline
Yes there is a rule in RRS. No, the AC does not use all of the rules we do...
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261552
07/22/13 10:23 AM
07/22/13 10:23 AM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
Just watching the replay. It seems Tucker and Andy have never heard of A and C class cats and really don't have a concept of what headsails do. Stating they won't be able to go as HIGH without the jib. Clueless.
Isak Dinesen
E. B. White
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261554
07/22/13 10:50 AM
07/22/13 10:50 AM
Any body have any more info about the "strings" in the wheel that Andy Green said control ride height?
Isak Dinesen
E. B. White
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261559
07/22/13 11:51 AM
07/22/13 11:51 AM
M
MN3
MN3
M
I have thought for years they should have full contact cat racing on the X-games... that would get people back interested in the sport ...
kidding aside, amazing foil to foil gybe's without the headsail...
Re: AC72 Oracle Team USA Spaceship has landed [Re: Team_Cat_Fever] #261560
07/22/13 11:54 AM
07/22/13 11:54 AM
I had wild visions of green and red yarn attached to the wheel trying to figure out how in the heck they would use this, attached to a wheel no less, to control anything.
I think I remember seeing someone (Oracle) with some sort of wire that went around the inside perimeter of the wheel - I thought it was structural to keep the wheel as light as possible but maybe it's part of this string system they mentioned.
Re: AC72 Oracle Team USA Spaceship has landed [Re: Team_Cat_Fever] #261561
07/22/13 11:57 AM
07/22/13 11:57 AM
I agree - but our group will be a tough crowd to get the details up to our standards while appealing to the masses!
I was astonished at how little (if anything) NZ lost without the jib. It looked like NZ got hooked into a big puff on their first jib-less downwind run but LR wasn't going to catch them anyway. Jibs will be important to maneuverability at the pre-start but maybe we see them put them on furlers and just get them out of the way as the wind builds?
Re: AC72 Oracle Team USA Spaceship has landed [Re: Jake] #261566
07/22/13 12:44 PM
07/22/13 12:44 PM
LR and oracle both have a line around the inside of the wheel, but like you, I can't see how it controls anything. I've heard it mentioned twice. Plus ,I thought all that foil stuff had to be fixed/ non-adjustable.
The only use I see for the jib is getting out of irons if you got luffed up in the pre start, and the drag penalty may not be worth it. You'd have to believe with all the money dumped into R&D they'd have this figured out. C's and A's use only mains/wings because it is the most efficient use of the allowed sail area. Marstrom also advocates this on their cats big and small.
The other idea is maybe ETNZ dumped the jib on purpose to give their sister ship a chance at getting a point and not being behind the 5 min. cut off. crazy laugh
Isak Dinesen
E. B. White
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261570
07/22/13 01:09 PM
07/22/13 01:09 PM
CT
I
itbvolks Offline
itbvolks  Offline
I
CT
Rudders are fixed but daggers are fully adjustable.
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261573
07/22/13 01:48 PM
07/22/13 01:48 PM
brucat Offline
brucat  Offline
From the camera angles shown, I was very impressed by how aggressive ETNZ was during the final minute before the start.
Re: AC72 Oracle Team USA Spaceship has landed [Re: brucat] #261576
07/22/13 02:51 PM
07/22/13 02:51 PM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
I'm not a fan of the 2 minutes of time in the box. That just is not enough for any real jostling for position. You pretty much seal your fate in your initial positioning.
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261577
07/22/13 02:57 PM
07/22/13 02:57 PM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
It's wet.
Let's wish them good luck.
Artemis Racing Launches Blue Boat
Philip
USA #1006
0 registered members (), 21,417 guests, and 762 spiders.
Yesterday at 04:54 AM
