Page 50 of 202 1 2 48 49 50 51 52 201 202
Re: AC72 Oracle Team USA Spaceship has landed [Re: Team_Cat_Fever] #261667
07/24/13 12:37 PM
07/24/13 12:37 PM
I'd have to guess aero drag is bigger once on foils.
Yeah, I was struggling with the physics on this but if you take it to the extreme and consider a surface with absolutely no friction, you really don't care how fast that surface is moving as long as it isn't tied to your motive force. So, as your friction on your running surface is reduced, the amount it moves is less important to your true motion...you guys are right. I think the foil drag is still significant so current does come into play (most definitely upwind) but it is significantly less a factor than it would be on a 6knot SB. If the effect of water current on the old slow monodulls was 90%, I suspect it's closer to as little as 25-30% on the 72 cats.
What I do think was interesting is the commentator's statement that the maximum windspeed allowable for racing was adjusted by factoring in current...funny, this.
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261669
07/24/13 12:47 PM
07/24/13 12:47 PM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: Jake] #261670
07/24/13 12:48 PM
07/24/13 12:48 PM
As I consider this further, I think the current still does have some impact on different points of sail - consider reaching when the current and the wind are in the same direction and you are moving perpendicular to them both...the water movement does subtract from the overall wind here because the boat is having to directly compensate for the additional slip to leeward that subtracts from (or push to windward that adds to) the wind. On this point of sail, if the boat doesn't have any friction in the water, they're just sliding down the course.
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261678
07/24/13 02:43 PM
07/24/13 02:43 PM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261679
07/24/13 02:44 PM
07/24/13 02:44 PM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261680
07/24/13 02:46 PM
07/24/13 02:46 PM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261681
07/24/13 02:48 PM
07/24/13 02:48 PM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261688
07/24/13 05:06 PM
07/24/13 05:06 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
So the big question is will they race Sat.? I sure hope so, even if it's a rout.
Isak Dinesen
E. B. White
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261690
07/24/13 05:20 PM
07/24/13 05:20 PM
Panama City, Florida
Redtwin Offline
Redtwin  Offline
What is the skin on that rear beam made of. It has the same look as the wing.
[img:left]http://photo.americascup.com/index....mp;FolioID=1358&numpage=31&pre=g[/img]
Edit: How do I enable HTML on my posts?
Rob V. Nacra 5.2 Panama City
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261691
07/24/13 05:22 PM
07/24/13 05:22 PM
CT
I
itbvolks Offline
itbvolks  Offline
I
CT
Based on comments above - I see very little chance of them being out this weekend other than to shake the boat out...
That said - I'm excited to see them out there and wish them luck!
Re: AC72 Oracle Team USA Spaceship has landed [Re: Redtwin] #261692
07/24/13 05:24 PM
07/24/13 05:24 PM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Watch this.
Originally Posted by mummp
Good stuff. So Oracle hints that their jib if flat enough to assist the wing.
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: Team_Cat_Fever] #261693
07/24/13 05:28 PM
07/24/13 05:28 PM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Agreed. I doesn't really matter until semi-finals August 6, but TOW, starts, etc. can only help.
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261694
07/24/13 05:34 PM
07/24/13 05:34 PM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261695
07/24/13 05:36 PM
07/24/13 05:36 PM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261696
07/24/13 05:39 PM
07/24/13 05:39 PM
CT
I
itbvolks Offline
itbvolks  Offline
I
CT
I would guess based on the images we're seeing today - testing is going pretty damn well!!! Those guys - that crew, they've gotta be so stoked... Testament to the whole operation....
Great image find Philip!
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261697
07/24/13 05:59 PM
07/24/13 05:59 PM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
Great to see a 3rd boat. I hope they race even if it's a take it easy lap around the course.
Scorpion F18
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261700
07/24/13 08:44 PM
07/24/13 08:44 PM
CT
I
itbvolks Offline
itbvolks  Offline
I
CT
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261706
07/25/13 06:55 AM
07/25/13 06:55 AM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
The smile tells it all . . .
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261707
07/25/13 06:55 AM
07/25/13 06:55 AM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #261708
07/25/13 07:09 AM
07/25/13 07:09 AM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
"Artemis will miss its seventh scheduled race in the Louis Vuitton Cup challenger series Thursday, so Luna Rossa will sail unopposed. It is not known when the Swedish team will enter the regatta, but it probably won't happen until the semifinals start Aug. 6."
Artemis-happy-with-initial-test-run-in-new-boat
Philip
USA #1006
0 registered members (), 20,780 guests, and 1,475 spiders.
Most Online22,490
Yesterday at 08:14 AM
