Boat Re-Spray Options #261849
07/30/13 06:27 AM
07/30/13 06:27 AM
Port Vincent, SA
Hack Offline OP
Hack  Offline OP
Port Vincent, SA
Hi all,
I'm a few weeks away from being ready to re-spray #1769. She will soon have new livery and a new name!
My big question is, what type of paint is the best option???
So far I've heard everything from automotive enamel right through to the 2-pack polys and other expensive options. I'm not averse to spending to get the right result (good finish,durability, flexibility etc) but what have folks out there used?
The current drab grey paintjob is flaking and peeling and cannot stay!
All suggestions helpful...
Hack
'Goodnight Nurse'
#1769
#1636
Re: Boat Re-Spray Options [Re: Hack] #261850
07/30/13 06:42 AM
07/30/13 06:42 AM
Portarlington, Victoria
Haz_Mann Offline
Haz_Mann  Offline
Hi hack,
I painted my last boat in two pack paint, i used two types. On the deck i used two pack marine,which did not allow for any flex and movement in the timber. The two pack polyutherane (black ) which i used on the underside, appeared to buff up much nicer in the end result. It was also cheaper than the marine grade product and you got more in the tin. Try a bristols paint shop. Just be wary that painting in winter can really present its own difficulties, so you will need to find some way of heating up the boat after it has been painted.. But two pack is defiantly the way to go if you have the $$$ and equipment to do so.
Harry
Harry Mann
Mosquito 1720
"2 B ADVISED"
Re: Boat Re-Spray Options [Re: Hack] #261854
07/30/13 07:27 AM
07/30/13 07:27 AM
Port Noarlunga, SA, Australia
Darryn Offline
Darryn  Offline
I just used protec duratec 600 on my boat, its a polyurethane enamel. Doesn't like the cold, dodgy compressors and has to be shot perfectly. Rubbing out orange peel is not an option. Adhesion and flexibility are the best I have used and its the most wear resistant paint have come across. Costs about $65 litre with hardener.
I wouldn't recommend it for home use but if you get a spray painter with a booth to spray it I doubt there is a better paint out there.
Darryn,
Bullet1782
Re: Boat Re-Spray Options [Re: Haz_Mann] #261865
07/30/13 04:36 PM
07/30/13 04:36 PM
Victoria Australia
Pirate Offline
Pirate  Offline
Victoria Australia
Originally Posted by Haz_Mann
...... you will need to find some way of heating up the boat after it has been painted ......
Preheating works better, the boat will hold most of the heat whilst the paint is applied so flash-off is quicker, a shorter flash-off deminishes the risk of dust etc contaminating the fresh paint, re-fire the heat once the paint has tacked off.
A few tips if your doing this at home ;
Jet-fire heaters:
awesome heat source but they have a drawback, they stir up the dust in your shed which then falls onto your paint mad
solution pre-heat the boat / allow a short period to let the air become still / spray / wait for tack-off and then re-heat
radiant heaters:
another excellent heater but they usually don't heat large areas that well, fine for a car door for example but useless for the entire side of the car, so a 16foot hull will be unevenly heated resulting in patchy paint.
DUST mad
simple solution really..... hang a large plastic sheet over your work area and wet the floor down with water before spraying, also pays to wipe down air-lines etc, and your clothing needs to be clean and dust free too...... don't forget the hair-net grin
when I set up my "booth" I have 3 wires across the shed which form a 'tent' over my work when the plastic sheet is slid over them, I usually pre-heat first and wet the floor at the same time, once I have the heat in my work I shut down the heater and then draw the sheet over my work, then spray ..... once it tacks-off I re-dampen the floor & run the heater again
Dust and airborne particles are your biggest killer, preparation work to minimise this is just as important as the prep work on the boat itself.
wink
Kingy
Kingy
& now Mosquitos #1182 & #1740
Re: Boat Re-Spray Options [Re: Hack] #261870
07/30/13 10:06 PM
07/30/13 10:06 PM
Matt_Stone Offline
Matt_Stone  Offline
when have a jet heater it is good, but when spraying need the extraction fan on (bunnungs) and draw the air out and no dust or overspray. Over the years my old man, sprays the boats in 2 pac expoxy, and in the winter it is hard to get a good finish as it will tend to run. so heat the inside of hulls too. More thinner coats equals shiny off gun finish.
Re: Boat Re-Spray Options [Re: Matt_Stone] #261871
07/30/13 10:15 PM
07/30/13 10:15 PM
G
Got Wood Offline
Got Wood  Offline
G
I've used Dulux products, primer is Luxepoxy 4 White Primer and the topcoat is Luxeathane, its coming up to 5 years on my boat and still a great finish and I would not hesitate using it again.
If you can find a Dulux Trade Centre nearby its much cheaper than other outlets, as it would special order for most places outside of Dulux.
Both are 2 pak paints, and I'm far from from being a spraypainter, but it came up pretty good.
Taipan AUS329 'Got Wood'
Mosquito 752 'Sticky Finger'
HARDWOOD RACING TEAM
Re: Boat Re-Spray Options [Re: Hack] #261872
07/30/13 11:34 PM
07/30/13 11:34 PM
Matt_Stone Offline
Matt_Stone  Offline
And Marine paint is the same as industrial paints, you just pay more for marine
Re: Boat Re-Spray Options [Re: Hack] #261881
07/31/13 05:15 AM
07/31/13 05:15 AM
Port Vincent, SA
Hack Offline OP
Hack  Offline OP
Port Vincent, SA
Thanks for all the info provided guys!
I do have access to a mates spraybooth and I was intending to wait for some warmer temps before attempting the job. I've had some info that 'Norglass' two pack is as good as anything on the market and much cheaper than brands like International.
I'll look into the heating options though-hadn't heard that before.
cheers
Hack
'Goodnight Nurse'
#1769
#1636
Re: Boat Re-Spray Options [Re: Hack] #261959
08/01/13 09:48 PM
08/01/13 09:48 PM
Rye, Melb, Vic, Australia
Peter_Lyons Offline
Peter_Lyons  Offline
I brushed the Norglass product onto 1655 and the results were ok but obviously brushed. In regard to heating things up, I found that keeping the paint in the warm part of my house overnight before painting produced better results than leaving it in the cold shed.
Mossie 1822
The Unsent Letter
Put one foot after the other, cos that's how we roll.
Re: Boat Re-Spray Options [Re: Hack] #262046
08/05/13 03:05 AM
08/05/13 03:05 AM
Port Vincent, SA
Hack Offline OP
Hack  Offline OP
Port Vincent, SA
Cheers. At this stage I think I'll go with Norglass, preheated and sprayed...
Thanks for all the input.
Hack
'Goodnight Nurse'
#1769
#1636
Re: Boat Re-Spray Options [Re: Hack] #262048
08/05/13 04:15 AM
08/05/13 04:15 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
I made a tent in my shed out of the orange plastic builders use to stop moisture travelling through slabs, put an oil heater in it and left it going. Sprayed 2 mozzys in june no problem
A big bonus is the plastic contains the overspray so you don't have to empty the shed
Mozzy respray.jpg (135 downloads)
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Boat Re-Spray Options [Re: JeffS] #262109
08/05/13 04:07 PM
08/05/13 04:07 PM
Victoria Australia
Pirate Offline
Pirate  Offline
Victoria Australia
A few mates over recent years have used these for car resprays, absolutely ideal .......
they seal out the weather really well, let in lots of light, no dust, & set it up anywhere !!!!
tent
buy one outright....
http://www.ebay.com.au/itm/NEW-GAZE...DefaultDomain_15&hash=item5895cb69c4
or hire one......
http://compare.ebay.com.au/like/221...i=y&lpid=45&item_id=221260158358
NB:
if you hire one they'll want a 'bond' for damage, none of my mates have asked for the bond back....
whistle
Kingy
0 registered members (), 2,499 guests, and 502 spiders.
Yesterday at 10:10 AM
