Page 1 of 4 1 2 3 4
Interesting New Sheaveless Block #261889
07/31/13 08:30 AM
07/31/13 08:30 AM
RickWhite Offline OP
Take a look at this new sheaveless block by Ronstan.., extremely light. Only can handle line up to 3/16" or 5mm. Could be utile for some lightweight rigging stuff.
http://www.catsailor.com/store/pc/SHOCK-SHeaveless-blOCK-very-lightweight-392p34835.htm
Rick White
www.onlinemarinestore.com
Re: Interesting New Sheaveless Block [Re: RickWhite] #261892
07/31/13 09:19 AM
07/31/13 09:19 AM
interesting. For you engineering types out there, what is the easiest way to measure working loads on a line? For instance, a jib-sheet or rotator line?
Re: Interesting New Sheaveless Block [Re: waterbug_wpb] #261895
07/31/13 11:15 AM
07/31/13 11:15 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Back on the imaginary boat build I see. Please keep us updated with pictures.
I'm freaking hilarious!
F18 USA 242
http://www.solarwind.solar
Re: Interesting New Sheaveless Block [Re: David Ingram] #261899
07/31/13 12:05 PM
07/31/13 12:05 PM
At least you are alive....was starting to wonder.
Re: Interesting New Sheaveless Block [Re: RickWhite] #261900
07/31/13 12:17 PM
07/31/13 12:17 PM
wildtsail7 Offline
wildtsail7  Offline
These have been discussed quite a bit on Sailing Anarchy.
Ferrules such as those from Antal and Schaefer make a lot more sense as they are stronger, ligther and if they fail the failsafe is still in the eye splice.
The Shockblock is cool but is limited to a very light load applications which there aren't to many of on our boats. And there is no failsafe if it breaks unlike a ferrule.
If you want the easiest way to test loads, spinlock makes a load cell for measuring road loads. https://www.spinlock.co.uk/en/load-analysis/zs-ropesense-2/10-tonne-wireless-load-cell
I've used it, nothing super fancy but easy to use. I'd love to try it on the F18 one of these days.
Re: Interesting New Sheaveless Block [Re: RickWhite] #261902
07/31/13 12:30 PM
07/31/13 12:30 PM
I think it could be a good alternative to small stainless rings like we use under the tramp and inside the beam, or anywhere else some line guidance it needed.
Re: Interesting New Sheaveless Block [Re: Jake] #261907
07/31/13 01:03 PM
07/31/13 01:03 PM
Clermont, FL, USA
Clermont, FL, USA
I'm still trying to get over THart unfriending me on Facebook. It has been a difficult time for me.
F18 USA 242
Re: Interesting New Sheaveless Block [Re: David Ingram] #261910
07/31/13 01:45 PM
07/31/13 01:45 PM
Oh, I probably started that. I don't think he's gotten over me unfriending him yet. You were probably just there at the wrong place, wrong time. Innocent casualty.
(why is beheading the act of removing a head but befriending is an act of friendship?).
Re: Interesting New Sheaveless Block [Re: wildtsail7] #261911
07/31/13 01:47 PM
07/31/13 01:47 PM
Sure, I'll pick one of those up crazy ... $4,500? I would rather have a set of sails.
Re: Interesting New Sheaveless Block [Re: David Ingram] #261915
07/31/13 03:45 PM
07/31/13 03:45 PM
Closer than you think if the bank dude wasn't such a pr*ck
I'm too fat for an F18 anyway...
Re: Interesting New Sheaveless Block [Re: waterbug_wpb] #261933
08/01/13 08:01 AM
08/01/13 08:01 AM
M
MN3
MN3
M
Do they make a f19 for "plus sized skippers"?
Re: Interesting New Sheaveless Block [Re: RickWhite] #261942
08/01/13 08:29 AM
08/01/13 08:29 AM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
These look kinda cool, but I'm trying to imagine an application for them on my boat.
I think the inexpensive rings underneath the tramp are lightly loaded and work just fine as they are.
Perhaps the cunningham blocks up by the tack? Jib sheeting purchase? Spin halyard (up top)? Traps?
Haven't had trouble with any of these areas yet.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Interesting New Sheaveless Block [Re: rehmbo] #261944
08/01/13 08:52 AM
08/01/13 08:52 AM
I can see how they might be useful in some of the bunji routing systems for the spin sheet take up and trap lines...but these are more expensive than Harkan's 16mm blocks and I would much rather use the real block with a sheave and bearings.
The advantage to this thing, however, probably is with entanglement. If it's in a system that often has slack in it I can see how this would be less likely to mis-orient itself. Perhaps on something like the mast rotation limiter or something.
Re: Interesting New Sheaveless Block [Re: RickWhite] #261952
08/01/13 03:23 PM
08/01/13 03:23 PM
Scarecrow
Scarecrow
Hey Rick, any chance you're about to add the antel type rings to your shop? I'm about to order some other stuff of you and need a couple of small ones (no I don't want the shock blocks).
Re: Interesting New Sheaveless Block [Re: Jake] #261953
08/01/13 03:42 PM
08/01/13 03:42 PM
oh, wait. That $17 is for a pair of those. That's not too bad and would start to be an idea in bunji or other shallow angle line systems
Re: Interesting New Sheaveless Block [Re: Jake] #261956
08/01/13 04:38 PM
08/01/13 04:38 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
Think pretty highly of yourself much ? Unfriending me because you can't support your argument with facts doesn't bother me in the least, just shows poor character.
Maybe you need to plan another addition to the garage mahal to make room for your swelled head. wink
Ding, I thought you unfriended me. Damn, NSA spiking sailing buddies now.
And to stay on topic, I'd guess these "blocks" are geared toward kite boarding, like their little plastic ones.
Isak Dinesen
E. B. White
Re: Interesting New Sheaveless Block [Re: Team_Cat_Fever] #261958
08/01/13 09:23 PM
08/01/13 09:23 PM
Argument? Nah..that never happened. I just got tired of the endless drivel of hateful political stuff in my newsfeed.
Re: Interesting New Sheaveless Block [Re: ] #261962
08/02/13 06:02 AM
08/02/13 06:02 AM
Scarecrow, what is antel type rings
Rick
Rick White
Re: Interesting New Sheaveless Block [Re: RickWhite] #261967
08/02/13 07:01 AM
08/02/13 07:01 AM
The French solo racers started using these where possible a few years ago on shallow angle leads (barber haulers and the like) to replace blocks with moving parts that could fail. These are lighter too. There are a couple of different varieties now - Hall makes a version as do Schaefer and Holt. It's a polished aluminum ring.
Re: Interesting New Sheaveless Block [Re: RickWhite] #261976
08/02/13 11:59 AM
08/02/13 11:59 AM
Scarecrow
Scarecrow
What he said. Great for low angle or high load cascades.
Page 1 of 4 1 2 3 4
0 registered members (), 2,778 guests, and 504 spiders.
Yesterday at 10:10 AM
