| Rule question.....carbon #26208 11/15/03 01:17 AM 11/15/03 01:17 AM |
Joined: May 2003 Posts: 139 Daytona Beach FL TheoA OP
Posts: 139 Daytona Beach FL | If I start replacing components on my 5.5sl with ones made of carbon, what will the impact be on the rules (assuming I maintain min weight....
-Carbon mast... not nessicarily from performance, as I can get one from AU for less than half PC cost -Carbon beams -Carbon crossbar, tiller-extension, over-rotator, etc..
What can I replace, what can I not??
94 N5.5SL
| | | Re: Rule question.....carbon
[Re: Cookie Monster]
#26210 11/15/03 11:39 AM 11/15/03 11:39 AM |
Posts: 139 Daytona Beach FL | I should have clarified my position.
I don't care about racing in class, as I've never come across a class of 5.5sl's.
What I do care about is taking a hit in PN. If I get a carbon mast exactly like a 5.5uni, but it isn't made by performance and offers no advantage other than price, does that lower my PN ?
94 N5.5SL
[Re: TheoA]
#26211 11/15/03 12:31 PM 11/15/03 12:31 PM |
Posts: 139 Daytona Beach FL | Some points that I picked up.
I can't do crap to the boat unless I pay performance or a dealer for their overpriced parts (most). It says that spin is OK for distance, doesn't specify the chute size, but it specifies a pole length. ????? When I look at DPN, it doesn't say anything about pole length, or chute size, only that a spin on that boat will drop the # by XX points.
The mast is what I'm really interested about.
94 N5.5SL
[Re: TheoA]
#26212 11/15/03 02:49 PM 11/15/03 02:49 PM |
Posts: 371 Michigan, USA | The Uni mast is taller than the Sloop mast. That will cause a new and probably larger mainsail. I always thought the Uni mast and mailsail with a sloop jib would be a pretty high horsepower boat. I would be concerned about the stock jib having the same relationship to it's running rigging and blocks. I think the hounds on the Uni are higher than on the sloop.
I don't know if the carbon is accounted for in Portsmouth, but I do know that the carbon mast makes the Uni faster than it was with aluminum. The Michigan Uni fleet found that it was necessary to have the carbon mast to remain competitive. Portsmouth should have a correction for it, even if it doesn't. You might contact Darline Hobock and ask for a provisional number.
Les Gallagher
[Re: TheoA]
#26213 11/15/03 09:48 PM 11/15/03 09:48 PM |
Posts: 217 | Strictly speaking, a carbon mast on a 5.5 sloop means you're not sailing class legal configuration, so the RC can penalize you anyway they feel is fair. If you want get a Portsmouth number, what I would recommend is to rig it that way, race a few races with the understanding you are not racing for a trophy, only racing generate times for Darlene so she can generate a provisional number. Make sure the RC & regatta chair know what you are doing, announces it to the other competitors, and submits the data to Darlene. An alternative is to buy a 5,5 uni carbon mast, and race it as a uni.
[Re: jcasto1]
#26214 11/16/03 04:51 PM 11/16/03 04:51 PM |
Posts: 98 | one correction is the current Nacra rules are located at Nacra Class I saw a modified 5.5 sailing on a Lake in Madison, Wi. Motored over to the owner, boat was a 5.5uni with carbon mast, special light rudders, & large jib ( I think it was a new 5.8na jib)boat was modified by the Nacra dealer. There's a post on the old forum by Carl, he talks about another Modified 6.0 called the Cathouse 6.0/20 fair winds Ted | | |
221
guests, and 52
