Page 1 of 3 1 2 3
Center Sheeting #261998
08/03/13 07:02 AM
08/03/13 07:02 AM
SE MI / NE IN
rehmbo Offline OP
rehmbo  Offline OP
SE MI / NE IN
I acquired a C2 late last year with center sheeting. Looks like the same setup as in this pic:
(is that you John?)
I'm still not sure if I like it or not.
Pluses:
- Sheeting angle for the crew is nice.
- 8:1 purchase is responsive in light and medium air
- Line management during tacks seems a bit easier.
Negatives:
- Difficult to uncleat in certain conditions - especially lighter air. I can probably blame several blown tacks on this.
- Seems like a lot of force on the center of the tramp - is this going to cause premature failure?
- Sheeting load in heavy air is pretty high. My 17yr old son who's in decent shape was dead after two races.
Noticed that this has not caught on - only the A-Cats seem to do center sheeting these days.
Replacing it with a more standard setup is going to kill my beer budget.
Let me know what you think.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Center Sheeting [Re: rehmbo] #262003
08/03/13 11:11 AM
08/03/13 11:11 AM
Hey Jeff - Yes, that's me and Dennis Key on a C2. I had the center sheeting on all three of my F18s. I loved it.
Mine was a 9:1 and I never used a cleat - just a Ronstan ratchet block. The first time I used it, I couldn't take my eyes off the tramp. But in practice, I never had any pucker, stretch, wear or damage there, so I just quit worrying. The tramp for center sheeting should be reinforced at the point where the block attaches. AHPC uses fabric straps, but I've seen a Nacra with an eye-strap on a backing plate sewn in, too. I had my first tramp worked on to add the reinforcement, and ordered the next two boats with the option.
I think it is fast. Without a cleat, I worked harder, but it made us faster as a result. It was still a lighter load than the kite - as you can see in that pic, we're double trapped and I could easily hold the sheet with one hand. Dennis never had to worry about the sheet in the tacks, and I was surprised that the block in the center of the tramp never really felt like the obstacle I thought it would be.
You need consistent crew if you're going to use this setup, I think. Managing the main in a tack is a new skill for some crews, and teams will need a couple of tacks to sort out the timing.
If I were buying another boat as crew, I wouldn't hesitate to add the option again. If I were a skipper and knew I didn't have steady crew, I'd probably not.
It was great to break the tension on the boat after a bad race - I could look at Dennis and say, "You had ONE job."
Here's the same setup on a Cap.
Re: Center Sheeting [Re: rehmbo] #262041
08/04/13 08:23 PM
08/04/13 08:23 PM
SE MI / NE IN
rehmbo Offline OP
rehmbo  Offline OP
SE MI / NE IN
Thanks John. Indeed - I sail with a lot of green crew, so that probably explains my bad cleating habit. Fortunately, cleating from the trap is pretty much impossible, so at least we have that.
I'm going to have Collin (my primary crew) try some different ideas and look more closely at his sheeting technique.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Center Sheeting [Re: rehmbo] #262043
08/04/13 10:06 PM
08/04/13 10:06 PM
Goodall taught me a great main trim mantra: half as much, twice as often.
Good luck, and stick with it if you can. Once it is working, it is like beer flavored boobies.
Re: Center Sheeting [Re: rehmbo] #262063
08/05/13 09:06 AM
08/05/13 09:06 AM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
We have the stock 10:1 system on the Infusion. Unlikely to change it ($$), though I like 9:1 myself as it's less line than 10:1. For what it's worth we don't use the cleat either. Couldn't find a spot where it was easy to re-cleat and uncleat, so now it's in a spot where it's impossible to cleat going upwind but can be cleated coming in off the wire during a tack. That is how the pros do it anyway (we are NOT pros but we can try).
My question on the center sheet without a cleat:
1) How does the skipper cleat the main going downwind?
2) Is the traveler still tied/spliced to the end of the main sheet? It hard to tell in the photos.
3) Does the center block interfere with the spin sheets/crew in a wire-wire gybe?
Scorpion F18
Re: Center Sheeting [Re: rehmbo] #262084
08/05/13 12:12 PM
08/05/13 12:12 PM
SE MI / NE IN
rehmbo Offline OP
rehmbo  Offline OP
SE MI / NE IN
I can answer #2 - yes, at least in my setup, its still tied to the traveler line.
For #1, I have a cleat, so obviously I use it. Good question if there's no cleat. I prefer to use the traveler downwind (especially when I'm overstood smirk ), so trying to manage the main sheet, traveler, and tiller ain't going to work too well. I have a hard enough time with just one of the three.
As for #3, we really haven't had conditions this year for wire-wire gybing. I'm a little-bit embarrassed to admit I hadn't really thought that one through yet. Not sure there'd be enough room behind the center block for both guys to cross at the same time. I assume crew would go first and there would have to be hand pass of the spin sheet around the front of the main sheet.
Let's see what JW says.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Center Sheeting [Re: rehmbo] #262093
08/05/13 01:20 PM
08/05/13 01:20 PM
samc99us Offline
samc99us  Offline
Thanks Jeff. I assume your cleat is on the block in the middle of the boat?
I already crown my 125 lb, 5' 4" helm in the gybes, but part of the issue is the board location is pretty far aft. Maybe it isn't an issue. I like the idea of getting the mainsheet of the helms hands in the tack. That would make her job easier.
Scorpion F18
Re: Center Sheeting [Re: rehmbo] #262098
08/05/13 02:08 PM
08/05/13 02:08 PM
SE MI / NE IN
rehmbo Offline OP
rehmbo  Offline OP
SE MI / NE IN
Yes. The cleat is attached to the block. Don't have the boat with me, but I'm pretty sure its a Ronstan RF56121. Its installed loop end to the tramp. Cleat angle is fairly high so you don't accidentally engage while your out on the wire.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Center Sheeting [Re: rehmbo] #262118
08/05/13 06:55 PM
08/05/13 06:55 PM
Hi Guys -
Jeff, do you have the Adventure Wines boat? That's the only one I know of that was ordered with center sheeting and a cleat. Hell of a coincidence if it isn't Ian and Paulo's old boat (USA 222). That thing is fast. Right-click and open in a new tab or window for more detail. HERE is the link to the first event that boat was raced. Ian raced with Bobby Kleinschmit, who has been working on ETNZ for the last couple of years. There are multiple high-res shots in that album that show the center sheeting clearly.
Obviously, because the standard center sheeting system has no cleat, the skipper hand-holds it on the run. As with the beat, not cleating forces the team to work the main much more often, which is faster. Squeezing the main in the puffs when you have the kite up is very effective. The main traveller is a gross adjustment and less effective in trimming. When we overstood the gate, Dennis would put the mainsheet in his tiller hand to keep our backstay, and drop the traveller with the other hand. It never looked like much of a headache from my perspective. I drove for a couple of years (2006-2008), and only infrequently since, and I don't recall ever having a problem dropping the traveller when needed.
AFA the traveller line, I have sometimes used a separate line (tied to the mainsheet), and Trey once made me a gorgeous, tapered mainsheet that was a split-tail on the end for the traveller. We liked that line best and used it up. We just had a figure-8 knot on the traveller side to keep the car from hitting the stops.
Finally, gybing: there's several different ways to run the spin sheets these days, most of which will not be a problem with the center sheeting Jeff pictured above. One of the recent (last two years?) setups that I tried and liked was the one where the spin sheet isn't spliced or tied together, but instead the ends are taken up on bungees run through the tramp. That method of rigging certainly wouldn't be in the way for the skipper or crew.
Re: Center Sheeting [Re: John Williams] #262145
08/06/13 10:37 AM
08/06/13 10:37 AM
SE MI / NE IN
rehmbo Offline OP
rehmbo  Offline OP
SE MI / NE IN
Interesting - all 3 C2s in the pic are using center sheeting. I appear to have the same stack as USA 70 - 4 on top, 4 on bottom, with a tie-off through the center of the bottom.
BTW - I can see the downwind sheet management a bit as you described in your pic here
As for the boat, you're close - mine is hull #224. Purchased from Dan K out of Omaha, NE. He did a nice job getting it dialed in for me smile it has proven to be really quick upwind. Still working to get my downwind technique perfected though.
You guys are obviously at a different level than I. I'm still well on the learning curve regarding the finer aspects of getting the best VMG out of the downwind run (but that's a whole 'nother thread).
Curious about the spin sheet takeup method you mentioned. Do they cross the tramp at a diagonal, diving under the aft part of the tramp? Which grommets do you use?
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Center Sheeting [Re: rehmbo] #262158
08/06/13 01:00 PM
08/06/13 01:00 PM
samc99us Offline
samc99us  Offline
Jeff,
I'll start another thread on the downwind VMG. We have work to do upwind in over 13kts of breeze and downwind in big waves.
Relevant to this thread, the cross the tramp spin sheet method I've seen on the Falcon and tried on the Infusion crosses the sheets on the tramp, in your case right in front of the center sheeting block. One corner goes to a grommet that is on the aft starboard side of the tramp and the other to a grommet on the aft port side of the tramp. I think on the Infusion these may be used to tie off the tramp to the boat, but I'm not using it for that purpose. From left to right, the shockchord gets tied to the starboard spin sheet on the port side of the boat, goes through the port side grommet, forward to a ring under the mast, then back aft to the starboard side grommet and then tied to the port spin sheet that is sitting on the starboard side of the boat.
I have since dumped this setup and gone back to tying the tails on my spin sheet together on the tramp with a single shock chord holding them. With the crossed setup above life was great while sailing upwind. It was not happy when we gybed, my feet ended up tangles in the spin sheet mess.
Scorpion F18
Re: Center Sheeting [Re: samc99us] #266395
10/21/13 12:05 PM
10/21/13 12:05 PM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
We use the crossed spinnaker sheet setup and like it a lot. It keeps the sheet on the boat better than if it were end to end. I did not like the sheets tied back to the boat with a bungee so had them loose on the boat. Now that they are crossed they do not fall off the side and I can always get to it around the weather mark so I can hand it to my crew without her (Eileen, the super crew) looking for it. If you do this I think it best to have the one on top from the port side to aid in the usual first mark rounding.
Later,
Dan
Re: Center Sheeting [Re: rehmbo] #272178
05/05/14 05:37 AM
05/05/14 05:37 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
How far back from the front beam is the block in the tramp mounted?
I'm considering going to a center sheeting setup as I do all of the sheeting on our boat from the crew position.
Re: Center Sheeting [Re: rehmbo] #272181
05/05/14 06:49 AM
05/05/14 06:49 AM
SE MI / NE IN
rehmbo Offline OP
rehmbo  Offline OP
SE MI / NE IN
Won't be able to measure until the 16th. Perhaps somebody else has this setup.
Basically, its pretty close to the middle. I don't think exact position is critically important as long as it matches up with the block on the middle of the boom. If you right click the pics on the 1st page of the thread and open in a new tab, you might be able to zoom in a bit more and get a good idea.
Will post an update when I set up for our first regatta on the 16th. Can't wait!!!
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Center Sheeting [Re: rehmbo] #272184
05/05/14 07:16 AM
05/05/14 07:16 AM
samc99us Offline
samc99us  Offline
Hey Jeff,
Would love some detailed measurements, location is critical IMO. Yours was in a good spot, easy to access for both helm and crew.
Likely to modify our next boat for center sheeting, though I have one question left. In bigger breeze when tacking, the helm takes the main and has complete control of the boat through the tack. This frees up the crew to quickly cross the boat, and most importantly ease the jib a little to prevent getting stuck in irons. As crew, I'm a little concerned I'll have too many lines in my hands with both main and jib to make a smooth crossing??
Scorpion F18
Re: Center Sheeting [Re: rehmbo] #272195
05/05/14 04:25 PM
05/05/14 04:25 PM
I always thought the crew taking the sheet made the most sense. Allows the skipper to maintain good control of the rudders and not have to worry about passing a sheet behind yourself. Especially one that doesn't have a cleat on it.
Re: Center Sheeting [Re: rehmbo] #272196
05/05/14 05:31 PM
05/05/14 05:31 PM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Jeff, Are you using a stand up spring on the tramp? Do you notice any less freedom for the main to travel out while still being sheeted?
I have a spare 10:1 system I could use with this, that way I could switch back easily if I needed to.
I'm at a point now that I am replacing much shock cord under the tramp before the next event and it would be a great time to get the reinforcement installed.
Re: Center Sheeting [Re: rehmbo] #272198
05/05/14 08:55 PM
05/05/14 08:55 PM
SE MI / NE IN
rehmbo Offline OP
rehmbo  Offline OP
SE MI / NE IN
Bacho - I don't have a stand up spring in my setup. 95% of the time the tension of the main sheet is enough to hold things up. However in super light air one might be helpful as I've had a few instances of the main getting cleated and was not able able to flick the sheet to release it.
Sam - I didn't have Collin messing with the jib during tacks (although I realize its a good idea for a bit more acceleration out of the tack). I had him manage the main sheet all the way through. Sheeting out as he came in off the wire and then slowly sheeting in as he went back out again.
Also, I have the tail tied in to my traveller which means clearing the sheet has to go behind the cleat on the tramp. I had a thought that separating them might be an interesting idea.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Center Sheeting [Re: rehmbo] #272246
05/08/14 08:10 AM
05/08/14 08:10 AM
samc99us Offline
samc99us  Offline
Jeff,
Seem to recall your boat being OK in super light air but a little spring up would help for easing the sheet.
In the tacks, it is critical to ease the jib sheet about 2" in big air w/ waves, just about the same time you pop the main sheet. This relives the pressure the jib puts on the bows and lets you drive through the tack more easily. If you don't do this, it is easy to screw a tack. Part of the reason it's more important in breeze than any other time is the amount of sheet tension on the jib is ridiculously high to trim for proper upwind sailing.
In these conditions, I suspect it would be fastest for the helm to grab the main through the tack, still very possible with center sheeting. The traveler part was annoying if I recall correctly, forcing the main to still be passed around aft of the block. Maybe running the traveler to the helms trap wire would work, or a few other creative solutions.
Scorpion F18
Re: Center Sheeting [Re: rehmbo] #272265
05/09/14 06:57 AM
05/09/14 06:57 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
I'm working on the thought of a traveler system that lead to the trap wire. Seems like it might be difficult to use downwind sitting on the boat.
Page 1 of 3 1 2 3
1 registered members (vasil), 453 guests, and 46 spiders.
