Page 2 of 3 1 2 3
Re: And so it begins....the boat graphic wrap [Re: Jake] #263090
09/02/13 04:06 PM
09/02/13 04:06 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
I have a sneaking suspicion that what little free time you used to have is going to be used up filling all the orders you're gonna get for this. That's a good thing. Now you need to do a slug graphic on the side of the J-22. grin
Isak Dinesen
E. B. White
Re: And so it begins....the boat graphic wrap [Re: Jake] #263091
09/02/13 04:07 PM
09/02/13 04:07 PM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Looks great to me.
Re: And so it begins....the boat graphic wrap [Re: Team_Cat_Fever] #263092
09/02/13 04:13 PM
09/02/13 04:13 PM
Jake Offline OP
Jake  Offline OP
Now, that's funny. We've been talking about doing something on the J22 when I get it to the house for some attention this winter. I'm not sure about a slug but you have me thinking.....
Re: And so it begins....the boat graphic wrap [Re: Pirate] #263093
09/02/13 04:19 PM
09/02/13 04:19 PM
Jake Offline OP
Jake  Offline OP
Originally Posted by Pirate
Originally Posted by Jake
This image shows roughly where I stopped down the curvature of the hull. I could slide this boat onto the beach if I wanted to, but I shouldn't be flying a hull too high or it might get into the graphic. But, this boat only sees the ground by accident. If I had planned on doing a Tybee 500 or Great Texas campaign, I would design the graphic a little higher and incorporate the hull color into the bottom of it to make a clean transition to keep it out of harms way.
DSC_3886 by Green Room Graphics, on Flickr
yeah it should be ok on the beach/sand.... but what about on the trailer cradles ????
is the wrap good enough to withstand the ride on the trailer without being damaged.....
confused
As you said, you'd not go as far down next time, I'd also hint at incorporating the trailer cradle aswell in the design layout so it blends in somewhat better for the higher number of road users that will see the boat being transported over those that will see it on the water at a distance
wink
We learnt this years ago with the race cars, more people see the car on its way to the track than actually see it on the raceway, we also found placement of sponsors signs was also effected during transport, major sponsors signs became less visual on the trailer.
simple solution for you at this stage would be to wrap the cradle supports to match up with the boat..... then it would be sweet as
just my "view"
other wise..... top job
Kingy
Regarding the cradles, I think I'll be OK..my cradles are pretty flat bottomed and I have my trailer tires balanced (yes, I'm that guy). It's really not a big deal to get the graphic high enough up the hull where the cradles won't be a problem. If I get some damage there, I'll just trim the graphic a little higher and re-seal it. I'm more worried about the blistering I discovered on the hulls from the cradles! I'm going to get a Todd Hart paint booth to put on my boat storage pad so it can stay mostly dry.
Re: And so it begins....the boat graphic wrap [Re: Jake] #263094
09/02/13 04:31 PM
09/02/13 04:31 PM
Jake Offline OP
Jake  Offline OP
I'm also helping someone restore an old Ski Tique that doesn't want to spend the time refinishing the hulls...I'm probably not going to blog that work but pictures will be on our Flickr site at in the Graphics Works set (man, I need to get our website finished):
http://www.flickr.com/photos/teamseacats/sets/72157635308360963/
Re: And so it begins....the boat graphic wrap [Re: Jake] #263095
09/02/13 04:52 PM
09/02/13 04:52 PM
Have you thought about wrapping the boards/rudders as well?
As long as it doesn't affect the performance of the boards this could be a real eye-catcher.
Re: And so it begins....the boat graphic wrap [Re: Jake] #263101
09/02/13 07:31 PM
09/02/13 07:31 PM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
Very cool result Jake. Are you running a vinyl print business - or did you just buy the printer for your own projects? Any advice on buying a vinyl printer like this (size, manufacturer etc) for boat and sail projects?
Chris.
Re: And so it begins....the boat graphic wrap [Re: flumpmaster] #263105
09/02/13 09:52 PM
09/02/13 09:52 PM
Jake Offline OP
Jake  Offline OP
Chris.
I have an "on-the-side" business that my wife and I have been running and I keep toying with making it a full-time proposition for me. We've got a solid industrial customer base that has kept this viable for a while. For most of that time we had a 20" vinyl cutter and a 12" printer/cutter machine. A couple of years ago we re-invested into the business to build the garage (and office space) and increase our capability. With the wider/larger format capability comes a considerable savings in consumables. I've always used Roland DGA equipment because it's built like a tank and just works for year after year. What we're doing now is a bit beyond the hobby level (for me, anyway) but if you are interested, you can find out more about the printing equipment at the Roland site. The main printer we use is a VP-540i which was only made for a short while. It's a combination printer/cutter with large/double print heads for accelerated printing. The sister machine that they offer today is the SP-540i which is the same machine but with 1/2 the print speed. They split the product lines with the VersaCamm and Soljet when they developed a method to print with metallic flake inks. The VP series was dropped to make a clear line of distinction between Soljet and VersaCamm models.
Roland VersaCamm Website
Our laminator is a Royal Sovereign 1401C
Re: And so it begins....the boat graphic wrap [Re: Jake] #263106
09/02/13 10:05 PM
09/02/13 10:05 PM
Jake Offline OP
Jake  Offline OP
Originally Posted by Darryn
Did you work out the weight of the graphics?
Darryn
Mosquito
1782
Interesting question. I weighed a sample scrap piece this morning and it works out to be 1.65 lbs of material per hull. I guess I need to diet for a week. ;-)
I rechecked my measurements and I had assumed an average height of 24" on the graphic. It's actually 22" at the bow and a little less than 12" at the stern. Assuming the average is closer to 18" (probably a little less than that), the overall weight is closer to 2.5 lbs for both hulls.
Re: And so it begins....the boat graphic wrap [Re: Jake] #263108
09/02/13 11:27 PM
09/02/13 11:27 PM
Scarecrow
Scarecrow
Jake,
I don't want to teach you to suck eggs, but thought you might be interested to know (but probably already do) that the guys doing wraps on power boats paint over the seams with a clear varnish. It helps with stopping water getting under and lifting the seam.
Re: And so it begins....the boat graphic wrap [Re: ] #263111
09/03/13 06:09 AM
09/03/13 06:09 AM
Jake Offline OP
Jake  Offline OP
Originally Posted by Scarecrow
Jake,
Sure, Ive seen that. It comes in a big felt tipped pen. The 3M edge sealing tape I used is supposed to be better for that and remain more removable later.
Re: And so it begins....the boat graphic wrap [Re: Tony_F18] #263112
09/03/13 06:12 AM
09/03/13 06:12 AM
Jake Offline OP
Jake  Offline OP
It would definitely be cool but I doubt it will withstand the wear from sliding in the trunks for long. It would be tough to get the seam to not affect foil performance and I'm not sure it would survive complete submersion under those circumstances. Gelcoat definitely has a purpose there.
Re: And so it begins....the boat graphic wrap [Re: Jake] #263116
09/03/13 09:27 AM
09/03/13 09:27 AM
Those are some mad skilz you're building there... Kind of like window tinting, from hell.
Re: And so it begins....the boat graphic wrap [Re: Jake] #263121
09/03/13 11:56 AM
09/03/13 11:56 AM
I'd bet that machine would cut window tint too.
Might be a niche market there..... Window tint with something printed on it?
Re: And so it begins....the boat graphic wrap [Re: Jake] #263123
09/03/13 12:09 PM
09/03/13 12:09 PM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
Really hot looking boat Jake! Sent you an email on the EVA decking. Totally jealous of the man shed that must make these projects SOOO much easier!
Scorpion F18
Re: And so it begins....the boat graphic wrap [Re: samc99us] #263124
09/03/13 12:24 PM
09/03/13 12:24 PM
Jake Offline OP
Jake  Offline OP
Originally Posted by samc99us
...Totally jealous of the man shed that must make these projects SOOO much easier!
Give it a month, I've got 5,000 lbs of porcelain tile in a corner waiting to be installed. I'll finally have a finished floor that I can clean!
Re: And so it begins....the boat graphic wrap [Re: Karl_Brogger] #263125
09/03/13 12:26 PM
09/03/13 12:26 PM
Jake Offline OP
Jake  Offline OP
It would cut window film but I doubt that film will retain the ink. We can, however, print on the perforated window film but I'm not sure you want that on anything but back windows.
Re: And so it begins....the boat graphic wrap [Re: Jake] #263424
09/09/13 01:09 PM
09/09/13 01:09 PM
Williamston, sc
h18catsailor Offline
Williamston, sc
The GRG boat looked AWESOME on the water and it was painfully obvious that the wrap did nothing negative to speed. I am working on a design drawing for mine! of course it will not be all fancy and computer generated like jake's.....more likely crayons, construction paper and glue sticks... laugh
David Strickland
Hobie 18
HEAVY air crew on a J22
Re: And so it begins....the boat graphic wrap [Re: Jake] #263551
09/10/13 07:53 PM
09/10/13 07:53 PM
Jake Offline OP
Jake  Offline OP
Here's a shot of the hulls finished (with my sailing crew, Ted). Replacing and putting graphics on the sails are the next project.
DSC_3888 by Green Room Graphics, on Flickr
Re: And so it begins....the boat graphic wrap [Re: Jake] #263554
09/10/13 08:56 PM
09/10/13 08:56 PM
samc99us Offline
samc99us  Offline
I don't know Jake, those sails look damn new to me...funny your boat was built 5 ahead of mine, if that's your original sail number on those not so 08' sails...I'm 885.
Boat looks really good and I know you guys are quick, it'll be fun racing...where's your America's entry?
Scorpion F18
Page 2 of 3 1 2 3
0 registered members (), 2,496 guests, and 620 spiders.
Yesterday at 10:10 AM
