| Nacra 6.0 Deck Ports #26366 11/21/03 10:12 PM 11/21/03 10:12 PM |
Joined: Oct 2003 Posts: 118 St. Louis, MO JoeLeonard OP
Posts: 118 St. Louis, MO | I'd like to put deck ports (for inspection and small storage) on the decks of my 6.0...likely a few inches behind the front crossbar. Any issues???
Thx in advance...
JL
JL
N20 # 1041 "Lucille"
A-cat USA 44
| | | Re: Nacra 6.0 Deck Ports
[Re: JoeLeonard]
#26367 11/22/03 12:15 PM 11/22/03 12:15 PM |
Joined: Jul 2001 Posts: 290 Pensacola, Florida / Katy, Tex... Cookie Monster
Posts: 290 Pensacola, Florida / Katy, Tex... | If you don't absolutely need ports, don't put them in. This is a last resort to make repairs or access the inside of the hull. The strength of the material (deck) that you remove is never the same when you replace it with a port. If you have to put a port on the deck, you're picking the better location behind the front crossbar. The deck in front of the beam can be put into compression when the hull flexes, and especially closer to the crossbeam.
Don Cook
ARC22 #2226
ADRENALIN
[Re: JoeLeonard]
#26371 11/23/03 01:00 PM 11/23/03 01:00 PM |
Posts: 12,310 South Carolina | The big 8" ports, I think they are standard on the H20, have a reputation for breaking when put under direct pressure from someones foot. The more common 4" ports don't have the same kind of problem, however, you can knock the threads out of whack with pressure and they can be a reall Bitc* to open if you sat on 'em.
West Marine carries a different brand of 4" ports that have much more sturdy threads. However, they aren't compatable with the more common lids.
Jake Kohl | | | Re: Nacra 6.0 Deck Ports - Do it
[Re: JoeLeonard]
#26372 11/23/03 04:08 PM 11/23/03 04:08 PM |
Posts: 131 Ohio | Joe,
I have put deck ports in both of the 6.0s I have owned. Properly installed they are as strong or stronger than the deck around them, will add to the overall strength and life of the boat by improving air circulation while the boat is stored, make great storage places for distance racing, and give you access to the board trunks , shroud anchors, and front beam area should you need to make any repairs.
I would recommend the Beckson 6 inch portals. I liked the ones with the textured non-skid surfaces.
west marine part number 106260 or 106254 depending on whether you like white or black.
I would place them exactly half way between the daggerboards and the front beam.
At a high level the installation process is:
1.) mark your decks 2.) cut your holes 3.) test the fit of the portal (always using the ring with the lid in place in it, otherwise the ring can be out of round) 4.) mix up some epoxy resin 5.) "paint" the foam and glass around the hole with resin, allowing it to soak into the foam core around the hole. 6.) add either micro-balloons or hardware filler to the epoxy until it is peanut-buttery consistency. 7.)glue the portals in. (make sure that the lids are in the rings when you do this or as I said previously you can end up with rings out of round, then you are in trouble. Make sure you do not glue the lids into the rings.) 8.) fillet the area around the rings using the thickened epoxy. (do not attempt to screw the rings down. The screws are not necessary and will only tend to bend the rings out of plane)
Once the epoxy hardens you are good to go. I additionally liked epoxying a small eyestrap to the inside of the hull somewhere near the portal. The Beckson portals have a fitting in the lid for a screw-eye. put a stainless steel screw-eye in the portal lid, and then tie a piece of light line from the screw eye to the eye-strap. Then, when you remove a lid on the water, you don't have to worry about losing it.
When storing your boat, leave the portal lids off and cover the portal with something that will let air circulate, yet keep rain and vermin out. Your fiberglass hulls will appreciate the extra air circulation. | | | Re: Nacra 6.0 Deck Ports - Do it
[Re: Jamie Diamond]
#26373 11/23/03 06:15 PM 11/23/03 06:15 PM |
Posts: 12,310 South Carolina | someone posted a while back about screwing a dowel to the center of a frizbee and placing it in the port so that the frizbee is slightly elevated. This will let air flow but keep the rain out. I thought that was a great idea.
[Re: Jamie Diamond]
#26378 11/24/03 01:02 AM 11/24/03 01:02 AM |
Posts: 118 St. Louis, MO | Thanks Jamie....I think you have convinced me...thanks for the great directions as well!!
JL
A-cat USA 44
[Re: Jamie Diamond]
#26379 11/24/03 09:05 AM 11/24/03 09:05 AM |
Joined: Apr 2002 Posts: 349 Fort Loramie, Ohio jmhoying
Posts: 349 Fort Loramie, Ohio | Jamie, Here's a photo of inspection holes in your old H16. By the way, the boat is now living on Folly Beach, NC. Jack
Jack Hoying
Fort Loramie, Ohio
[Re: jmhoying]
#26380 11/24/03 09:49 AM 11/24/03 09:49 AM |
Posts: 12,310 South Carolina | Folly Beach is in South Carolina is it not (are there two)? (great place to sail from too - if you can get your boat to the beach).
[Re: Jamie Diamond]
#26382 11/24/03 11:46 AM 11/24/03 11:46 AM |
Posts: 12,310 South Carolina | Also keep in mind that most epoxies have a hard time with UV exposure - they turn yellow/hazy and eventually get brittle. You will need to put a coat of paint on the epoxy or maybe some sealant to help block the sun if you use epoxy to fill any the difference in curvature.
Secondly, if you coat the plastic with some sort of a mold release, you will be able to remove the plastic port once the epoxy has cured. PVA mold release would work well - but that's an extra expense. You can also use wax paper, any kind of polypropoline plastic (like cheap drop sheets), or even grease as a barrier between the port and the epoxy. I haven't tried this but I believe if you put a skim coat of silicon sealant on the plastic, it will also provide a good barrier. This way you get a good solid mount but can still remove the port easily should it ever be damaged or deteriorate.
Jake Kohl | | | Re: Don't Use Screws
[Re: ibesailing]
#26385 12/01/03 09:25 PM 12/01/03 09:25 PM |
Posts: 12,310 South Carolina | Sure - I use catbags all the time (fat bags). I permenanly leave a tube or two of sunblock in them and it's a great place to store several bottles of water (except in my case, my only ports are at the stern - not usually where I want more weight). The truck key goes in there too if I'm out day sailing. I've never heard them bang around.
Jake Kohl | | |
2,883
guests, and 311
