broke my crossbar bolt.advice please #264015
09/17/13 08:40 AM
09/17/13 08:40 AM
brobru Offline OP
brobru  Offline OP
preparing to ship my I17 from st.croix to tampa.crossbars have bolts all came out except 1, i sheared the damn thing atthe deck,..they are very tall bolts..suggestions?,..yes it is stainless.i suspect salt water seiezed it.i want to fix it now, for i do not know anyone in tampa.bruce
Re: broke my crossbar bolt.advice please [Re: brobru] #264198
09/18/13 05:29 PM
09/18/13 05:29 PM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
I think you mean you have sheared a bolt for your beam, which beam front or rear? There are a few threads on this forum covering this but I can't find them. First step is to spray some CRC, Inox or similar around the sheared bolt now so it can try to soak down the thread, then get a very sharp punch and tap a centering hole in the exact middle of the bolt, then use a very small drill bit to drill a hole in the exact middle of the bolt, then use a drill bit big enough to get an easy out in. An easy out is square in shape and you tap it into the hole then turn the bolt. Once your easy out is in try to turn it the wrong way first then the right way with small movements. If the problem is with the bit of the bolt exposed inside the hull having build up on it you may be able to keep winding it down until it drops inside the boat. If the easy out doesn't work you can keep drilling your hole bigger then rethread it for your bolt. The success of that depends on your first punch mark and drill hole. Good luck
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: broke my crossbar bolt.advice please [Re: JeffS] #264656
09/23/13 08:49 AM
09/23/13 08:49 AM
brobru Offline OP
brobru  Offline OP
hey jeff, thank you,....i call it a cross bar...what nags me is1.]i got 3 out...fine..even with the EASY OUT.threads are still seized...i pray a chemical can penetrate,logically it should,..plus a little percussion...tap.tap.tap...but it sheared the darn bolt just at the threads.if it was not stainless i could quarter it and pick it out..we will see.
ugh....maybe over the years i should have worked the bolt a bit, but i tend not to mess with things that are ok.bruce
Re: broke my crossbar bolt.advice please [Re: brobru] #265236
09/25/13 11:32 PM
09/25/13 11:32 PM
JeffS Offline
JeffS  Offline
If the easy out hasn't worked, another thing I have seen in workshops but never used is a spray that freezes the bolt, it's used to extract bolts from engines. The theory is you spray the bolt and the contraction cracks it away from the thread
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: broke my crossbar bolt.advice please [Re: brobru] #270428
03/20/14 09:13 AM
03/20/14 09:13 AM
brobru Offline OP
brobru  Offline OP
shipping boat easter week, going to let tackle shack get it out!this time i will get new bolts and lube them on assembly.
tampa bay here i come!
bruce
original year inter17(2000?)
Re: broke my crossbar bolt.advice please [Re: brobru] #273352
06/21/14 09:04 AM
06/21/14 09:04 AM
Albenarle NC
jackbr549 Offline
jackbr549  Offline
Albenarle NC
Did you get this fixed?
0 registered members (), 2,458 guests, and 328 spiders.
