Page 1 of 3 1 2 3
H20 spin #26552
11/29/03 06:04 PM
11/29/03 06:04 PM
San Francisco bay area
Brad Offline OP
Brad  Offline OP
I have a H,20 with a comptip.
What would be the best way of attaching a spin halyard?
Also would a "trumpet" from a tiger work?
Re: H20 spin [Re: Brad] #26553
11/30/03 09:14 AM
11/30/03 09:14 AM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
I will post some pics on my homepage for you. First, locate a small mast tang, perhaps for a H14 or Laser, place it between 36" and 37" abov the end of the aluminum portion of the mast on the comptip. See address bekow
http://www.msnusers.com/EricsSailingPics
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: H20 spin [Re: arbo06] #26554
11/30/03 09:26 AM
11/30/03 09:26 AM
arbo06 Offline
arbo06  Offline
Brad, click on the documents button on the left side of the page to see the two pics of the tang set up.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: H20 spin [Re: arbo06] #26555
11/30/03 02:40 PM
11/30/03 02:40 PM
Brad Offline OP
Brad  Offline OP
Hi Eric, thanks for the info. your boat is beautiful.
Now I need to figure out a snuffing system.
I have a tube from the tiger, but it may be too short.
Re: H20 spin [Re: Brad] #26556
12/01/03 09:53 AM
12/01/03 09:53 AM
arbo06 Offline
arbo06  Offline
Brad, I am working on it as you speak. I am on vacation until Jan 5th so I will have lots of time to make something. I have some preliminary designs already. I'll put the pics on my home page this morning some time. I am starting with an extra mainsail bag and the top 4" od a 5 gallon bucket? "El Cheapo Engineering Co. Inc."
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: H20 spin [Re: Brad] #26557
12/01/03 03:46 PM
12/01/03 03:46 PM
arbo06 Offline
arbo06  Offline
Brad, what is the inside diameter of the Tiger Trumpet? And what is the overall length...also what is the tube made of? Looks like poly plastic?
Thanx
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: H20 spin [Re: arbo06] #26558
12/01/03 05:29 PM
12/01/03 05:29 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
I'm not sure of the exact dimensions. It looks to me to be about 10" wide tops. It also seems to taper back to a smaller diameter down the tube. The tube is made out of fibreglass. It looks like it is very thin. It also breaks and cracks quite easily. All of the friction comes from turning the corner on the top side of the hoop. One key is to have a flat turning piece so that the rope doesn't always burn to the same spot. I've seen tennis rackets used and just some homemade hoops.
Mike Hill
H20 #907
Mike Hill
N20 #1005
Re: H20 spin [Re: Mike Hill] #26559
12/06/03 12:37 AM
12/06/03 12:37 AM
Brad Offline OP
Brad  Offline OP
Hi guys,
The tube is made out of vinylester, and is kinda oval.
It is 6.5 x 7.5 inches inside at the mouth.
The top of the mouth is aluminum that is glassed in and faired. It is about 7` 3" long
The whole thing weighs aprox 2lbs and as mike said is very breakable. My kite came with 2 bellybuttons but I think I need to add one more.
Re: H20 spin [Re: Brad] #26560
12/09/03 09:17 PM
12/09/03 09:17 PM
arbo06 Offline
arbo06  Offline
OK guys,(and Brad) we are getting ready to make our first mold for "El Cheapo Engineering Snufalufagus spinnaker thingamabob.TM, copyright,patent pending (or not pending) etc. Inc., Co. LLC. please see prospectus for actual risk that was probably not disclosed by the snakeoil sales punk.
Anyway...this should be interesting..gimme a Bud so we can start with the glass work
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: H20 spin [Re: arbo06] #26561
12/12/03 02:02 PM
12/12/03 02:02 PM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
I should have been asking my questions here! I'm looking at putting a spin on my 20, after having done it for my 18.
I noticed the halyard tang is just pop-riveted into the comptip. What length rivets did you use? Any tips to keep the action of riveting from making cracks in the comptip?
What size spinnakers are you guys using? Are they the Tiger spin that Hobie seems to be selling for the 20 now? Or something else?
In the Chesapeake Bay area the 20 sailors are starting the debate of whether to add chutes, and if so, what size. Maybe someday we'll have a spec, something like the NE N-6.0 sailors.
Re: H20 spin [Re: Keith] #26562
12/14/03 10:46 AM
12/14/03 10:46 AM
arbo06 Offline
arbo06  Offline
Keith, the comp tip is very strong, don't worry about it breaking. I can't remember what length rivet I used but after you drill the holes you can see the thickness of the material and go from there. Make sure to use the rivet "sleeves" and sealant to keep your comp tip watertight.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: H20 spin [Re: Keith] #26563
12/14/03 10:50 AM
12/14/03 10:50 AM
arbo06 Offline
arbo06  Offline
some pics of the mast spi/tang
click on "breakin wind III"
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: H20 spin [Re: arbo06] #26564
12/15/03 10:43 AM
12/15/03 10:43 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
Cool! My fears of the comptip may be going away...
Now, for the other question again. What are you all using for sails? Custom-made, used from some other boat, or factory (Tiger)?
Re: H20 spin [Re: Keith] #26565
12/18/03 10:48 AM
12/18/03 10:48 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
Ok, let's try the question a different way!
Is anybody out there using the spinnaker that Hobie now sells for the 20, which appears to be the chute from the Tiger? What are your impressions of this sail on this boat? Just right, under-powered, etc. etc.?
Any info on this would very helpful, so even if you know a friend of friend who knows somebody who heard a story about it from somebody else...
Re: H20 spin .. Ask Brad Stephens [Re: Keith] #26566
12/18/03 03:03 PM
12/18/03 03:03 PM
Annapolis, MD
Mark Schneider Offline
Annapolis, MD
Hi Keith
Call
Brad Stephens
www.sunjammers.com
Authorized Hobie/Vanguard Dealer
Division 15 Chairman
Panama City Beach, FL
brad@sunjammers.com
850-235-2281
He announced that the was testing the Tiger chute against the usual Hobie 20 chute on the open forum.
Don't know the outcome and I would be interested.
Take Care
Mark
crac.sailregattas.com
Re: H20 spin [Re: Keith] #26567
12/19/03 09:04 PM
12/19/03 09:04 PM
arbo06 Offline
arbo06  Offline
Keith, I just bought the spin for my H20. I don't know if it is the same spin for the Tiger. i can tell you that the foot is long enough that I have to sheet from the rear beam. I have ony flown it once so I can't at this point make comment. I hope to get it out again soon. I will post my experience.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: H20 spin [Re: arbo06] #26568
12/19/03 10:37 PM
12/19/03 10:37 PM
Chelmsford, MA
Barry Offline
Barry  Offline
Chelmsford, MA
Keith
If you want to try an I20 Spinnaker I have a few hanging around. I could sent it to you to give it a try and just send it back when your done. [Linked Image]
Re: H20 spin [Re: arbo06] #26569
12/21/03 01:50 AM
12/21/03 01:50 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
Eric,
The catalogs up through '02 show a sail specific to the 20. The '03 catalogs show the same spin as the one shown for the Tiger. This is my basis for saying the current sail sold for the 20 is the Tiger sail. I could be wrong...
Re: H20 spin [Re: Barry] #26570
12/21/03 01:52 AM
12/21/03 01:52 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
Barry,
Thanks, I might just take you up on your offer. Any idea what the luff measurement is for the I-20 spin?
Re: H20 spin [Re: Keith] #26571
12/21/03 09:17 AM
12/21/03 09:17 AM
arbo06 Offline
arbo06  Offline
http://groups.msn.com/EricsSailingPics
I just posted a pic of my spin on page 4 of the "pictures" tab on the link above.
I took some rudimentary measurements....
tack to clew = 17 feet
tack to head = 26 feet
clew to head = 24 feet
can someone make a determination from these rough numbers?
I would also like to know what I was sold....
Eric Arbogast
ARC 2101
Miami Yacht Club
Page 1 of 3 1 2 3
0 registered members (), 1,070 guests, and 51 spiders.
