Hi Joe
It takes some thought to walk through all the variables ,
but think the 04 rule version serves its purpose,-
to establish the basis of a F-20 class ,
and can be further defined if needed -
The idea of dispensation in Formula classes when established is to accomodate existing similar boats with set up of their preference , this eliminates any expensive change needed until normal periodic sail replacement, then the sailing team still has a choice to update the platform with newer modern sail plan .
All cat designs change over time ,-the only exception being the H-16 due to shear numbers ,--all others have changed or evolved -the Tornado -A-Class cats -etc ,-or become dead boat classes .
Some differences between the older existing boats and more modern class model are the much heavier rig of the 6/0 or the H-comptip ,-that effects moment .
The 6/0 also has the added stay wires -shorter mast -pin top main -and more area in the jib .
6/0 sailors selected that particular spin which on the actual race course between similarly skilled teams seems very close ,-both boat types winning line honors in events with numerous good teams of both types ,--
Also the H-20 winning distance events in good mixed fleets ,that is the intent ,-to keep them competitive and grow a larger F-20 class that includes as many as possible.
The H Fox and other iF-20 EU version 20s are close now to the I-20 US version in speed ,--Now add the larger spin for weight and add the 15 sq ft in the main and these boats should be nearly identical and would rationally rate the same given the same teams ability on each .
The benifits of Formula classes are numerous ,-no more dead boat classes ,-no more having to purchase a complete new boat every two years to be competitive ,-no more having to purchase only brand class gear hardware parts or sails.
Being able to make improvement and changes to any 20 to suit your liking ,-add a mid pole snuffer system ,-better rudder system ,- better hardware set-ups ,-add a reef system ,-floatation ,-safety lines ,trap gear etc ,that make the boat fasater and safer .
Best of all it brings numerous brand types together to race in large class events which creates more partisipation and much more interest which in turn benifits all involved.
