| Boards wanted #266255 10/14/13 06:27 PM 10/14/13 06:27 PM |
Joined: Aug 2011 Posts: 182 Grafton, NSW Greg/Debra OP
Posts: 182 Grafton, NSW | Hi all,
I am after a pair of boards for Mossie - Boyer, Taipan or similar. Can anyone help?
Thanks, Greg.
1140 Gadfly 1434 J.I.B.E. 1727 Atreus
| | | Re: Boards wanted
[Re: Greg/Debra]
#266306 10/15/13 03:29 PM 10/15/13 03:29 PM | Scarecrow
| Scarecrow
Unregistered | There is a set of boards on the A-class website. Before you hand over your cash get them to confirm they are at least 20mm thick.
If you're really desperate I have a spare set of Taipan boards but they need work and aren't for sale so I'll want reasonable funds for them. | | | Re: Boards wanted
[Re: Greg/Debra]
#266338 10/17/13 05:04 AM 10/17/13 05:04 AM |
Posts: 182 Grafton, NSW | Hi Scarecrow, I have sent you a PM regarding the boards.
Greg.
| | | Re: Boards wanted
[Re: Greg/Debra]
#266388 10/20/13 10:13 PM 10/20/13 10:13 PM | Scarecrow
| Scarecrow
Unregistered | this foil from Fastacraft would make an awesome Mossie daggerboard. Only issue is it won't fully fill the case when pulled up. | | | Re: Boards wanted
[Re: Greg/Debra]
#266552 10/29/13 09:59 PM 10/29/13 09:59 PM |
Posts: 6 | is there any other suppliers out there at all need new daggerboards asap
chug-a-lug 1682
| | | Re: Boards wanted
[Re: Greg/Debra]
#266553 10/30/13 02:09 AM 10/30/13 02:09 AM | Scarecrow
| Scarecrow
Unregistered | Try posting wanted adds on the a class and taipan websites. Otherwise AHPC is probably the quickest and easiest. How big are viper boards? You could also try brett at wind rush, he has a few random foil moulds. | | | Re: Boards wanted
[Re: Greg/Debra]
#266569 10/30/13 02:43 PM 10/30/13 02:43 PM |
Joined: Jan 2007 Posts: 81 To windward of you! Sixth Element
Posts: 81 To windward of you! | JK Fibreglass in Bendigo would be able to do something for you, he makes the new mossies and associated boards. he also has a variety of other boats, a class, taipan etc.
"Sixth Element" 1782 MK2 w/spinnaker. Lake Bonney Y.C. National Sec. / S.A President / S.A Measurer / Commodore LBYC
| | | Re: Boards wanted
[Re: Greg/Debra]
#266571 10/30/13 07:14 PM 10/30/13 07:14 PM | Scarecrow
| Scarecrow
Unregistered | Just noticed in a post over at sailing anarchy that the original nacra infusion boards were 9" (230mm) chord which with normal ratios would make them between 20.5 and 23mm thick (smack bang in the middle of your class limits). They will be too long, but it is very easy to cut the top of a board. The advantage with these boards is when they were upgraded the chord reduced (unlike the C2) which means that boats that have been changed to suit the new boards can't use the old ones as a spare without first taking a grinder to the boat so anyone who has upgraded should be willing to let them go at a reasonable price. It would be worth contacting the Brisbane catamaran centre to see if they know of any sitting around and/or posting a wanted ad on the F18 forum. | | | Re: Boards wanted
[Re: Greg/Debra]
#267933 12/21/13 07:22 PM 12/21/13 07:22 PM |
Posts: 182 Grafton, NSW | I saw those boards, but too late and missed out on them.
331
guests, and 55
