Mozzie Daggerboard Cleats #267203
11/21/13 06:00 PM
11/21/13 06:00 PM
M
Matt Warne Offline OP
M
Hey Guys
Does anyone know were I can find some cleats that are used to hold the dagger boards up. I have some that are worn out and need to replace them.
Thanks
Matt Warne
Re: Mozzie Daggerboard Cleats [Re: Matt Warne] #267220
11/22/13 06:56 AM
11/22/13 06:56 AM
South Oz
Phillip Offline
Phillip  Offline
South Oz
Photo of the cam cleat I use, placed on the inner side of the box. This enables the boards to be lifted from the opposite hull, cleating immediately. SS plate under it is to prevent wear on the edge of the timber from the 3mm lift line.
Line ends in the c/board hole, i.e. single purchase. Some bring the line up to the deck on the outer side giving a 2:1 purchase, but more line required and pull through.
A small piece of quality (rubber) non-skid tape placed on the side of the board at a strategic point at the top creates sufficient friction at the deck level to hold the board down. It only need a quick pull on the line to break that friction and lift the board. Keeping the line cleated at all times, even when down, prevents the board falling out of the case in the event of capsize.
Mozzie Aldebaran VI
1827
Re: Mozzie Daggerboard Cleats [Re: Matt Warne] #267224
11/22/13 07:25 AM
11/22/13 07:25 AM
Victoria Australia
Pirate Offline
Pirate  Offline
Victoria Australia
I've been doing some buying from this eBay seller of late and I have found them to be excellent in customer service....
http://www.ebay.com.au/sch/psmarine...amp;_from=&_ipg=25&_trksid=p3692
cool
Kingy
& now Mosquitos #1182 & #1740
0 registered members (), 382 guests, and 345 spiders.
