| Re: Beach Wheels .......... question ??????
[Re: northsea junkie]
#268638 01/21/14 11:52 AM 01/21/14 11:52 AM |
Joined: Jan 2007 Posts: 139 Hernando, Florida Mlcreek
Posts: 139 Hernando, Florida | How about a spring loaded cradle for the boat to sit on. You stand on the cradle to lower the boat and lock in location. When returning you step on the release and springs bring the cradle up under the boat. The whole cradle is mounted on beach wheels that can be towed by your trax. Just thinking.
Forrest I-20 USA 645
" There ain't enough rum in the drum!"
[Re: bacho]
#268644 01/21/14 02:10 PM 01/21/14 02:10 PM |
Joined: Jun 2009 Posts: 524 Petten Netherlands northsea junkie
Posts: 524 Petten Netherlands | It seems to me that building a retractable system to bolt to the beams would not be all that difficult. They could include a linkage to turn them sideways as they are pulled up. The design in my head suffers greatly though when such a wide tire is required. It seems it would have to weigh at least 50lbs.
My greatest problem is: where do I leave the wheels during sailing. They ought to be onboard for my purpose, but sailing at sea and in a break with these big things sideways extended is impossible. The only place seems to be flat, in front upon the tramp, but then I have to have a mechanism that not only retracts them but also turns them 90 degrees.
ronald RAIDER-15 (homebuilt)
#268671 01/22/14 10:08 AM 01/22/14 10:08 AM |
Posts: 5,590 Naples, FL | deflate the tires for transport. Can you adapt them to those dual-stage hand pumps I see the kite-boarders use?
[Re: Pirate]
#268683 01/22/14 02:05 PM 01/22/14 02:05 PM | MN3
| MN3
Unregistered | just add foils, no need to retract | | | Re: Beach Wheels .......... question ??????
#268766 01/24/14 04:37 PM 01/24/14 04:37 PM |
Joined: Apr 2013 Posts: 858 Victoria Australia Pirate OP
Posts: 858 Victoria Australia | My greatest problem is..... Been turning this over in my head and can see all the issues you face with traditional gear.... Then I remembered seeing a pics of a hobie that had the beach wheels set into the hulls as a fixture, this was several years ago that I saw it and I have spent a couple of hours searching for those images again but with no luck.... From what I can recall, he cast a basic box into the bottom of the hull and then made a 2nd box that held the wheel and this box slid inside of the cast in box.... add a bit of silicone and it was installed and sealed. the only images I could find are largely from aircraft wheel pants or wheel spatsbut you get the idea.... I'm sure you could design a simple yet effective setup that would work well, I don't think that the exposed tyre would cause that much grief if it was set in to minimise water turbulence ...... it would also mean no more lost/stolen beach wheels or exotic Lamborghini style door hinge setup so you can fold the wheels up onto the deck and take up room etc etc etc etc ..... just thinking out-loud  Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
Kingy started with Impara Cadet #3 / Mosquito #245 & now Mosquitos #1182 & #1740 | | | Re: Beach Wheels .......... question ??????
[Re: Pirate]
#268768 01/24/14 05:37 PM 01/24/14 05:37 PM |
Posts: 833 St. Louis, MO, | Perhaps we are going about this wrong. Perhaps not a wheel but a set of tracks (like a bulldozer) of some kind that could either retrack into the hull or remove and store on the hull.
Mike Hill N20 #1005
[Re: Pirate]
#268775 01/25/14 02:56 AM 01/25/14 02:56 AM |
Posts: 524 Petten Netherlands | Thanks guys for presenting these visualised ideas.
Kingy, the problem with retractable wheels is the size which I momentary use. They are too large, especially for my Prindle like hull shape. ( I would choose for more reasons another hullshape now if I could do it again !)
Mike, I could make room for the retracted wheels behind my frontbeam by making a hole in my tramp (it's a net). But it's an interfering solution!
I will play further with all these ideas in my head, thanks again.
321
guests, and 55
