Re: Does Jay really have a boat? [Re: ] #269538
02/19/14 01:32 PM
02/19/14 01:32 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Originally Posted by MN3
Galvanized Trailer w/Lunchbox ?? come with a sandwich press too?
If a sale is contingent on a sandwich press, I'll have it installed.
Re: Does Jay really have a boat? [Re: Jake] #269540
02/19/14 02:22 PM
02/19/14 02:22 PM
Originally Posted by Jake
You'll have to come out and see us on March 1st. We should (hopefully) be cruising past Marco island in the afternoon. Note; we might duck behind Ten Thousand Island and cut the corner if the wind is right.
if your boat draws less than 3 feet, you should be fine almost everywhere. You can see the bottom = time to turn smile
if you cut in at Big Marco pass, there are two fixed bridges (I think 40+ feet clearance).
with that speed demon, I think the straight shot on the outside route might work best. Cut a left at Romano between the sand bars, keep Gullivan bay marker on your left, and it's a straight shot to Cape Sable.
I guess the strategy call would be to continue directly to Duck Key and run north (ala Steeplechase) or hang a left at Cape Sable and run that route ...?
You going to have a spot transponder or anything I can keep an eye on your progress? It would be nice to watch that thing fly by... while I work on my tan and drinking muscles smile
Re: Does Jay really have a boat? [Re: ThunderMuffin] #269544
02/19/14 03:31 PM
02/19/14 03:31 PM
I can just picture a Foreman grill screwed down somewhere bouncing open/closed as it goes down the road. laugh
Good conversation piece at the very least.
Re: Does Jay really have a boat? [Re: waterbug_wpb] #269546
02/19/14 03:59 PM
02/19/14 03:59 PM
There will be a spot tracker page but Alan has all of that info. I'll have to get him to give me links to share.
Florida bay is an option but it's risky...apparently the water can drain away for miles should the wind switch and blow out of the north. Two dudes were stranded on a 12 foot boat for three days trying to cut through Florida bay in one of the recent events.
That method works only works when the sun is up ;-)
Re: Does Jay really have a boat? [Re: pgp] #269549
02/19/14 05:31 PM
02/19/14 05:31 PM
Punta Gorda, FL
jkkartz1 Offline
jkkartz1  Offline
Punta Gorda, FL
I don't remember a lot of details, we were racing. Wind 15-18. I'll ask A Florida Redneck if he wants to further elaborate.
The dome houses?
Re: Does Jay really have a boat? [Re: jkkartz1] #269719
02/26/14 10:50 AM
02/26/14 10:50 AM
Well, Jake, if you believe the NOAA forecast I don't think you're in for a record-breaking year, but it could be a very nice sail in your light air rocket.
Weak front appears to move through Thursday night with Atlantic High dominating the rest of the weekend. Easterly direction (ENE / ESE) and light (5-10 kts) which should keep the water pretty flat near shore.
A bit more breeze as you near Cape Sable, mainly out of ENE which might make your Steeplechase routing a bit more feasible?
Sunny and warm, too.
Re: Does Jay really have a boat? [Re: pgp] #269721
02/26/14 12:48 PM
02/26/14 12:48 PM
M
MN3
MN3
M
With water in the gulf in the low 60's and air temps in the upper 70's ... I am expecting a nice sea breeze all weekend long in my neck of the woods, don't know why it would be any different south of here.
Re: Does Jay really have a boat? [Re: ] #269722
02/26/14 01:16 PM
02/26/14 01:16 PM
water temperature at "the turn" (Naples/Marco) is closer to 73 F, which isn't that much cooler than the air temperature.
Current temp near Cape Sable is 77
Re: Does Jay really have a boat? [Re: pgp] #269723
02/26/14 03:42 PM
02/26/14 03:42 PM
M
MN3
MN3
M
wow, I had no idea it was that much warmer there.
Re: Does Jay really have a boat? [Re: ] #269724
02/26/14 04:00 PM
02/26/14 04:00 PM
yes, I walked south until no one I spoke to knew what "frost" meant.
smile
Re: Does Jay really have a boat? [Re: waterbug_wpb] #269728
02/26/14 07:14 PM
02/26/14 07:14 PM
smile
The frost is seven feet thick in exposed areas around here. I've never heard of it going that deep. The septic lines at the shop have had to been blasted three times this winter to clear ice and keep the drains working.
Only two more months left!!! sick
Re: Does Jay really have a boat? [Re: pgp] #269733
02/26/14 09:47 PM
02/26/14 09:47 PM
brucat Offline
brucat  Offline
You're blasting your septic lines? I don't even want to know what that could possibly mean.
We have about a foot of snow left from the past few weeks of storms. It warmed up over the weekend, thawing the top of any exposed areas and making a muddy mess as the two feet of snowpack starting thawing. Now we're back to single digits at night, just in time for March.
At least Madcatter is less than 3 months away!!!
Re: Does Jay really have a boat? [Re: brucat] #269740
02/27/14 09:23 AM
02/27/14 09:23 AM
Just means lunch at Taquito #3 here...
Re: Does Jay really have a boat? [Re: waterbug_wpb] #271056
04/02/14 04:03 PM
04/02/14 04:03 PM
Finally figured out how to rig the screecher.
Touched 8 knots in what looked like 5 TWS (barely ripples on the water).
Too bad the pole's too short to leave the jib up.
Re: Does Jay really have a boat? [Re: pgp] #271178
04/05/14 12:09 PM
04/05/14 12:09 PM
I saved a track on google earth. how do I post a snapshot of it here?
0 registered members (), 15,648 guests, and 460 spiders.
Most Online22,490
3 hours ago
